Question about Kenwood Audio Players & Recorders
I need 5 indicator lamps for a kenwood kr 6030.can I buy them or modify lamps to fit. tham nk you.
5 Suggested Answers
  • 319 Answers
SOURCE: problem with playing my Kenwood KR-X1000
Unit apparently has problems. Check/replace batteries in remocom
Posted on Aug 14, 2008
  • 222 Answers
SOURCE: kenwood kr 3600 volume potentiometer is faulty
try google and it will give you some local electonic stores
Posted on Jun 08, 2010
dunnbiker
  • 8546 Answers
SOURCE: kenwood kr-v888d after "ON", through 3sec.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Posted on May 18, 2011
  • 1575 Answers
SOURCE: Kenwood kr-720 service manual
Hi Vanpost941,
You can download the manual in pdf by clicking here. or here.
Hope this helps.Thanks!
Please rate this answer.
Posted on Nov 24, 2011
Hi Vanpost941,
Nov 24, 2011 | Audio Players & Recorders
Can the Kenwood KR-4600 connect to an ipod?
Hi,yes you can connect Kenwood KR-4600 to an ipod.
Instruction..
You will need an coolken_9.jpgRCA cable .
Connect the RCA (red and black to the input of the Kenwood KR-4600...You have options of inputs to use..
Either input at the back of the Kenwood KR-4600,or tape A and tape B..which ever you wan to use..
After connecting the red and black RCA to Kenwood KR-4600, then connect the other jack end to the ipod, and go the front of the Kenwood KR-4600 to activate the input selection knob to the desired input being selected at the back of the Kenwood KR-4600..
And don't forget to turn on the volume of the Kenwood KR-4600 and also the iPod volume..
And after that your done..
Good luck to you..
Aug 10, 2011 | Kenwood Audio Players & Recorders
I have a Kenwood KR - V6080 receiver. I need to look at a manual.
The manual is available at retrevo: http://www.retrevo.com/support/Kenwood-KR-V6080-Receivers-manual/id/479bh942/t/2/ . You will need to enter a code to download the PDF.
I hope this helps.
Apr 30, 2011 | Kenwood Audio Players & Recorders
Kenwood kr 3600 volume potentiometer is faulty
Jun 07, 2010 | Audio Players & Recorders
Where can I purchase a flash for ricoh model KR 5 super2
prasadsu,
any camera store will have a flash for your KR5. buy a non dedicated type that fits on the hot shoe.
or try ebay for a used one.
Jan 30, 2009 | Ricoh KR-5 SUPER II 35mm SLR Camera
Reset
Try Removing SD Memory Chip From Unit, Remember What Side
of SD-Chip Faces Forward, Slide The SD-Chip, White Tab To
Unlock.
If This Fails
www.dvssale.com
Call Dan Kim 408-970-3387, DVS-Tech Santa Clara, CA
Email dankim@dvs.co.kr
Email kimus@dvs.co.kr
I Own One Myself, Just Upgraded to 2GB SD Chip, Reloaded Software w/Map Ugrade
Still Working Fine
jeffreydrescher@Bellsouth.net
Oct 03, 2008 | Digital Video Systems Plenio VXA-3000 GPS...
Have a kenwood KR-V990D and can't seem to bring the volume up
kenwood has always showed negative numbers 00 is as high as it will go
Jan 06, 2008 | Kenwood KR-V990D Receiver
Problem with playing my Kenwood KR-X1000
Nov 19, 2007 | Kenwood KR-X1000
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
