Question about Braun Health & Beauty
JUST FOUND A NEW SHAVEMAN RAZOR IN MY HUSBANDS BATHROOM. HOW TO YOU USE IT?
How do I take apart razor to lubricate the motor?
Oster Classic 76 hair clipper - take apart to clean or fix ...
? 9:53
https://www.youtube.com/watch?v=nu8UaoCxtxo
Feb 20, 2010 - Uploaded by darwincollins
It is an amateur video demonstrating how to take apart a Classic 76 clipper. ... your clipper with Oster Kool Lube 3 Clipper BladeCoolant Lubricant Cleaner. .... Motor did not slide out but all wires shredded and motor was in pieces ... What's that little button just below the '76' for and how do you know exactly ...
MOTOR TEST Checking the motor on broken Hair clippers ...
? 0:32
https://www.youtube.com/watch?v=TaWUxcdGBSg
Mar 29, 2015 - Uploaded by You can Fix It!!!!
Testing motor on shears clipper trimmer razor shaver. How doyou know if the blades or motor are brok... ... oils oiling oileddisassemble disassembling take apart taking apart .... 3:21. How To ' Change Cord ' Change Switch ' How To Repair Wahl Clippers ' - Duration: 2:24. by ronsclassickuts 13,453 views.
How to sharpen a Norelco electric shaver - Instructables
www.instructables.com/.../How-to-sharpen-a-Norelco-electri...
InstructablesYou will need a small brush to clean shaver and heads, also a flat piece of ... I then take a tool I made from a broken Norelco razor and a writing pen which ... Mix a 1;3solution of White toothpaste [1] and Mineral Oil [3] on the back of a ... Disassemble[keep the screens & blades mated] and spray with Bathroom Cleaner. 5.
Taking Care the Right Way to Keep Electric Razor Like New
Dec 06, 2015 | Health & Beauty
Why would my washer and bathroom light not work
The washer and light probably are on the same circuit.
Feb 12, 2013 | Kenmore Washing Machines
How do you change the battery in the titanium quattro shaver trimmer?
Just twist the main body open.I love the quattro titanium trimmer. this razor is more on the expensive side for me. however, schick very often puts out $4 coupons on their quattro shavers and when i pair that with a drug store sale i can get these razors for very cheap. i was very excited to purchase this razor for my husband since it has the trimmer on it. my husband used the razor and said it did a good job as far as the razor part goes. his face felt smooth, but it should with four blades! we have used the trimmer end of it long after the razor part of it was of no use! that in of itself would have made...
Jun 11, 2011 | Schick-Wilkinson Sword Quattro Titanium
Yellow Spots on Bathroom ceiling/walls after showers
You will have to paint over your new paint with a primer called BIN which will dry in about an hour. Then you can put your color coat on that. Problem solved.
Dec 04, 2009 | Home
My husband owns a 370Braun razor-he wants to replace the top part
You can get the foil screen and the cutter block as a set, since it is recommended to replace them as a set, in case the blade cartridge had a damaged cutter blade that could ruin the new foil screen.
You can get them from Electric Shaver Store or look elsewhere for Braun Item#: 5774761 UPC: 4210201635000
Here's a link to them, they are temporarily out of stock, but they get them in frequently.
http://www.electricshaverstore.com/get_item_5774761.htm
Hope you find this Very Helpful and best regards!
Aug 25, 2009 | Braun 360° Complete 8985 Electric Shaver
Water damaged Moto razor
I know you don't want to here this, so be kind with your rating, but the best solution is a new phone. The reason is this: no matter what you do, water is a conductor and the dried residue it leaves behind will also short things out. And water will get to places that you can't.
Sorry, hope that helped save you some time...
Geno
Apr 03, 2008 | Motorola Mobility RAZR V3
Clean Cycle Never Ends
i have the same issue but the charge/clean light on the razor itself wont come on or charge at all. Braun said to send it in for repair/exchange and to find out whats wrong with it.
Mar 04, 2007 | Braun Flex XP II 5790 Electric Shaver
Health & Beauty Logo
311 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Joseph Hoffmann
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
