Question about Robinair Cool Tech 34700Z Recovery, Recycling, Recharging
When under vacuum down machine started pulling oil front injection bottle
    President:
  • 180 Answers
You need to Change ''Oil inject" solenoin from small manifold assy.
Note:Green dot OR blue label denotes are oil injectoct solenoid.
Posted on May 11, 2010
Do I pre mix the 2 stroke fuel on a peewee 50 or does the petrol go in the tank an oil in the bottle in front of forks
the 2 stroke oil goes in the bottle at the front but i would check its bled at the oil pump and working by checking it is pulsing from the oil injection pipe before playing on it.otherwise premix it in the fueltank to be on the safe side.
Sep 12, 2015 | Motorcycles
Where is the toner bottle on the minolta dialta located at?
It is on the back right hand side of the machine, under a cover that flips down out of the machine, you can then just pull the bottle out.
Nov 17, 2012 | Konica Minolta DiALTA Di200 Copier
CANON IR 3570 eror code E000019
E019-0000 ? Waste toner bottle full for 2000 copies. Empty or replace waste toner bottle.
This is aimed at the office worker who is handy with a screwdriver.
Open toner cover. To the right of the toner bottle is a screw. Remove this screw fully. The next screw is tricky to describe. It's on the outside of the copier, under a rubber disk. To the left of the toner bottle. If you have both screws removed you should now be able to pull the toner cover to the left and pull towards you. The whole front cover should come away. The waste toner bottle is the big thing in-front of you, full of black powder.
Best to wear a P2 dust mask. Toner is not toxic. Otherwise you would not be able to touch a copied document. Toner is about seven microns across and can cause respiratory distress, or an asthma attack.
Do not use a vacuum cleaner to **** up toner. Most vacuum cleaners do not have sufficient filters to remove toner. All you will do is spread it around the office for others to inhale. This type of toner can also damage your vacuum cleaner.
To replace the front cover. Put the pegs on the right of the cover into the frame. On the bottom left of the cover is a wide hook. This needs to locate into the metal frame. The white peg with the hole is where the screw goes in.
Good luck
Oct 03, 2010 | Canon ImageRUNNER 3570 Copier/Printer
How to drain oil from fryer
Most fryers have a valve right inside the front door that you can place a bottle under and drain the oil right into it...
If not then get a small diameter plastic hose from a hardware store and siphon the oil out...**** the oil up the hose till it is over the side of the fryer, then hold the vacuum and drop the hose over the side and lower then the oil level and the oil will start to siphon out...
heatman101
Sep 03, 2010 | Imperial IFS40 Deep Fryer
ROBINAIR 347002K WON'T INJECT OIL
I think you'v try to inject the oil from ''WRONG'' side,as you say RECOVER/VACUUM which is LOW side manifold valve. You should inject the oil from HIGH side ( Turn the high side valve to CHARGE/OIL INJECT after vacuuming & low side vulv to CLOSE possition ) with pressing F1 key. once you press it then hold the key as long as you wish to inject the oil. If you try this way & you still have problem with oil injection then you may need to check oil injection CHECK VALVE or oil injection SOLENOID ( Both located under Hidg side panel mountin valve). NOTE: UV Dye is not a problem for oil injection! I hope this will help you to solve the problem,Good luck. Don't forge to vote for my solution!
Jul 10, 2010 | Robinair Cool Tech 34700Z Recovery,...
My ricoh 2232 is telling me that waste oil bottle is full what are the steps to empty
open the front door and in the left down part you will see a bottle with oil, pull the bottle toward you and it will open as a door towards the left side, empty the bottle good and return it in the machine while the machine is on do not turn the machine off.
Jan 19, 2010 | Ricoh Aficio 2232C Color Copier
Robinair 34788 not pulling a vacuum
It's seems to be problem with your unit relay board,vacuum pump or pressure transducer.Most of Robin air 34788 machine having same problem.You can try as follows 1# Open vacuum pump oil filling cap to release extra pressure from pump.2# Replace new relay board & follow the on screen message(do not skip any option).3# Check pressure transducer is working properly.I hope this will help you.
Jun 06, 2009 | Robinair Cool Tech 34700Z Recovery,...
Change fuel filter on 2000 ford focus
Put in a bottle or two injection cleaner 80% of all problems with fuel injection no one uses this enough it does work wonders,only tkes aspeck of dirt to cause problems
Jan 22, 2009 | 2001 Ford Focus
DISPENSER WILL NOT DRAIN
Waag, pull that dispenser drawer out of there, push down on the tab-left side in the back. Now take your index finger and see if you have something blocking the water feed hole to the tub. It will be on the inside front. Sometimes I find bottle cap disks blocking the inlet. Start a cycle with the drawer out of there and observe the water flow, if it's backing up, you have something blocking that inlet. You can always pause/cancel. Catriver.
Jan 01, 2008 | Kenmore 46462 Front Load Washer
Robinair  Cool Tech 34700Z Recovery, Recycling, Recharging Logo
13,636 people viewed this question
Top Robinair Measuring Tools & Sensors Experts
Mike
Jay Finke
Jay Finke
Are you a Robinair Measuring Tool and Sensor Expert? Answer questions, earn points and help others
