Question about MSI Wireless-G RG54G3 Router
Port number how do i get the port number
    Genius:
  • 1,354 Answers
Port ip will be in your manual just see your manual
Posted on May 11, 2010
Trying to port forward a web port, media port, and phone port to an ip address for security camersa
1. Select Port Forwarding/Port Triggering under Advanced in the main menu.
2. From the Service Name list, select the service or game that you will host on your network. If the service does not appear in the list, see the following section, "Adding a Custom Service."
3. In the corresponding Server IP Address fields, enter the last digit of the IP address of your
local computer that will provide this service.
4. To the right of Server IP Address, click Add. The service appears in the list in the screen
To define a service, game, or application that does not appear in the Service Name list, you must first determine which port number or range of numbers is used by the application. You can usually determine this information by contacting the publisher of the application or user groups or newsgroups. When you have the port number information, follow these steps:
2. Click Add Service (see Figure 5-1 on page 5-7).The Ports-Custom Services screen displays.
3. In the Service Name field, enter a descriptive name.
4. In the Service Type field, select the protocol. If you are unsure, select TCP/UDP.
5. In the Starting Port field, enter the beginning port number.
• If the application uses only a single port, enter the same port number in the Ending Port
field.
• If the application uses a range of ports, enter the ending port number of the range in the
Ending Port field.
6. In the Server IP Address field, enter the IP address of your local computer that will provide
this service.
7. Click Apply.
See the rest of the manual here.
http://documentation.netgear.com/wnr2000/enu/202-10397-01/pdfs/FullManual.pdf
Dec 26, 2013 | NetGear WNR2000 Wireless Router
Does my Inspiron 9400 Laptop have build in microphones?
Yes It is. You can check them either in COntrol Panel > SOund or Start > Run > DXDIAG.
WIth regards
FIXYA team
Oct 09, 2010 | Dell Inspiron 9400 Notebook
How can i switch my phone number to another phone
I believe you can keep your number, but it depends on who you're porting to rather than porting from whether the port will work or not.
Also one page says:
Some service providers have applied for a waiver from number portability which is a request for a delay or exemption from providing the ability to port numbers. If your current service provider is one such company, then unfortunately Verizon Wireless will not be able to port your number at this time.
Finally, I would suggest report them to the fcc for not releasing the line if there's any problems. I would expect delays but threatening the porting dept with an fcc complaint will make you a priority port.
May 15, 2010 | LG ALLTEL AX145 Cellular Phone
Router port number
just open a port and then then type that port into the box which is asking for the port number. If you require further assistance please let me know. Thanks and have a great day.
Jan 19, 2009 | Edimax 4 Port Wireless AP Broadband Router...
Port number
Complete Port Number List:
http://www.iana.org/assignments/port-numbers
Dec 11, 2008 | Linksys Wireless-G WRT54G Router
Port Forwarding
at the time of portforwarding in that you have to give the port number of the device which ip address you put in means if ip cam is there you give the port number for that example 90 you give then you have to give the device.
Jul 24, 2008 | Linksys Wireless-G WRT54G Router
Netwoks
  1. A port number represents an endpoint or "channel" for network communications. Port numbers allow different applications on the same computer to utilize network resources without interfering with each other.
Port numbers most commonly appear in network programming, particularly socket programming. Sometimes, though, port numbers are made visible to the casual user. For example, some Web sites a person visits on the Internet use a URL like the following:
http://www.mairie-metz.fr:8080/ In this example, the number 8080 refers to the port number used by the Web browser to connect to the Web server. Normally, a Web site uses port number 80 and this number need not be included with the URL (although it can be). In IP networking, port numbers can theoretically range from 0 to 65535. Most popular network applications, though, use port numbers at the low end of the range (such as 80 for HTTP). The port number is included as a field within the header of each IP packet. Note: The term port also refers to several other aspects of network technology. A port can refer to a physical connection point for peripheral devices such as serial, parallel, and USB ports. The term port also refers to certain Ethernet connection points, such as those on a hub, switch, or router.
2.The protocol number is used to identify the machine and a port number to identify particular applications running on that machine and To allow applications to communicate with each other, either on the same machine (using loopback) or across different hosts, each application must be individually addressable
May 19, 2008 | Computers & Internet
How is Port Forwarding Configured?
To Enable Port Forwarding for MR314 or RP114 1. Type the router's address in an Internet browser's address bar. (By default the router's address is 192.168.0.1). 2. Enter the router's username and password. 3. Click Advanced > Ports on the left menu bar. 4. Enter the first port number in an unused Start Port box. 5. If only one port number is to be forwarded, enter the same number in End Port. To specify a range of ports, enter the last port to be forwarded in the End Port box. 6. Enter the IP address of your local server in the Server IP Address box. 7. Click Apply.
Feb 19, 2006 | NetGear (RP114NA) Router
Port Forwarding
Feb 19, 2006 | NetGear MR314 802.11b
Port Forwarding
Feb 19, 2006 | NetGear RP114 Router
MSI Wireless-G RG54G3 Router Logo
62 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
