Question about Visioneer Strobe XP 300 Pass-Through Scanner
My paper comes out black after i scan it - Visioneer Strobe XP 300 Pass-Through Scanner
Try to calibrate the scanner, go control panel, scanner and fax, properties.. and calibrate with the calibration paper.. you can clean also with the cleaning paper..
Posted on Jan 31, 2011
Why-print-comes-all-black-all-over-paper/
Check the scanning lamp, when copying see if the scanning is not working,,it should be turn on when copying, if yes, then replace the scanning lamp, or drum unit, drum unit have certain life span or copying yield about 100 to 300 thousand copies produces. Check your counter reader in your machine. If yes, then replace drum unit, hope it help.....
Jun 15, 2014 | Kyocera Mita Office Equipment & Supplies
My HP laserjet 3050 when i copy a page the paper prints black
Symptom: Black or Blank image while copying or scanning.
Part suspect rating: Scan head..70%
Scan head cable...25%
Formatter...5%
For tech guys only: Remove ADF unit from the printer, remove both side covers of adf, remove & replace scan head, check...
Replace scan head
Jul 21, 2012 | HP LaserJet 3050 All-In-One Printer
Copies nothing but solid black paper
Printing from system is OK? Do scan and check.not proper ? check CCD unit & cable..
Suspecting 80% CCD unit(Unit under flat bed glass moves while scan or copy with lamp)
20% cable(flat ribbon cable connected between CCD unit & Formatter) see the snap shot for easy recognition of CCD7_15_2012_3_12_34_am.jpg
Jul 13, 2012 | HP Officejet Pro 8500 Wireless All-In-One...
Scan and copy produce a black page
Scan head faulty(which is moving while scanning & copying) , replace it..
Nov 16, 2011 | HP Officejet 6500 Wireless All-in-One...
Black line 1 inch wide right side ,when copies are made and faxing
When the paper is fed through Automatic Document Feeder (ADF) is is scanned before copy or fax. The scanner is fixed type and is located just below the ADF.
The lines are due to dirty scanner mirror. The printer/ scanner design is based Sheet-Fed Scanner. Open/Lift the Control Panel (scanner top )(by pulling it up from front - the area from where the paper to scan comes out). Look out for the horizontal mirror and use a soft, damp, lint-free cloth to gently clean the scanner mirror, rollers etc. and enjoy clear scanning and copying!
Inspect for any tron pieces of paper dirt etc.DONT USE PAPER, CHEMICALS OR ANY ABRASIVE CLOTH as it may damage the parts.
Also note that your machine can scan an image only 8.15 inches wide, regardless of how wide the paper is.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
May 31, 2011 | Brother 5750E Fax
Sharp AL-1551CS Scan Problem
hi do u have set tha adf limet for 8"x14" just set the corect size of origlan from adf
thanks
May 11, 2010 | Sharp AL-1551CS Copier
When scanning color document, blue tone is present as background shade
Have long experince with PixEdit program using Kodaks. PixEdit usually comes around it after a firmware upgrade on the scanner. Not sure about this specific model but at least OK on other models of Kodak.
Sep 25, 2008 | Xerox DOCUMATE 510 Flatbed Scanner
Black area above the scanned image.
If you set Automatic brightness/Contrast this happens. Try manual setting. Adjust different settings and select the best suited for a particular type of drawing. The scanner takes couple of milliseconds to judge the best lighting, by then the paper has moved little. This area appears black. This is easily solvable.
S. Mohan, Chennai, India
Dec 06, 2007 | Canon DR-9080C Path-Through Scanner
Scans Black
The optical lamps aren't turning on. Check all connections inside for the optics. Most likely the LED bar has blown and the only solution would be replacement.
Oct 13, 2007 | Sharp UX B700 Plain Paper Inkjet Fax
When printing a scanned object, paper is all gray
Whatever scanning utility you are using, set it to Black and white, not grayscale nor colour! regards, babb
May 05, 2007 | Umax Astra 610P Flatbed Scanner
Visioneer Strobe XP 300 Pass-Through Scanner Logo
294 people viewed this question
Top Visioneer Office Equipment & Supplies Experts
Jeff Hogancamp
Jeff Hogancamp
Cosma Papouis
Cosma Papouis
Are you a Visioneer Office Equipment and Supply Expert? Answer questions, earn points and help others
