Question about Zooper Boogie Jogger
Wobbly Wheel One of the tires got "hit" during air travel, and now it wobbles. Can I get a replacement wheel?
    Problem Solver:
  • 5 Answers
Take it to your local kwik fit, they will sort it out.
Posted on Apr 30, 2008
How do I fix wobbly tires on my
have the front end and suspension checked for worn out parts and repair then do a wheel alignment. if its a defective tire replace.
Apr 10, 2015 | Cars & Trucks
WOBBLY WHEEL ON A HONDA
sound like you have tire out of balance or possibley a bent rim. i would jack the passenger side up grabbed the tire and see if it wobbles, if not then you have something wrong with the tire i would also turn the tire and look to see if you see any metal on the inside of the tire and feel for large knots. these factors will make the vehicle ride really rough let me know how this works out for you..
Jul 08, 2012 | Honda Civic Cars & Trucks
My daughter has a 2006 nissan sentra about 6 months ago she hit a curb with the front passenger side tire we replaced the tire rim but its making a loud humming noise any advise would be greatly...
That loud humming noise you are hearing is the wheel bearing. After hitting the curb the bearing took a hit and became a little wobbly and over time the grease has seeped out and started causing the humming.So just replace the wheel bearing and anything else that might be loose or damaged like the tie rod and ball joints. if those issues are not corrected it might happen again down the road. good luck and glad to shed some light on your issue
Aug 02, 2011 | 2006 Nissan Sentra
My left front tire is wobbling and I don't know why. I have attempted to take the tire off and put it on again. What could be wrong?
WOBBLING TIRE IS A BAD WHEEL HUB BEARING.REMOVE WHEEL CHECK HUB BEARING WHERE FRONT AXLE MESH INSIDE HUB.SHAKE HUB BEARING SEE IF IT REAL LOOSE AND WOBBLY. IF YES HUB BEARING BAD.
Dec 04, 2010 | 1996 Saturn SL
Wobbly steering wheel , started yesterday, no big hits or potholes , or no bigger than normal. tires haves some tread but all 4 need to be replaced. is it an alignment issue or something more costly?
If it wobbles at higher speeds like 55-60 mph or so probabley just worn and out of balance tires,If it wobbles at like 25-30mph or so at a lower speed it probabley mean you have a tire seperating and it could blow out at anytime and you would definitely need new tires,at least more than likely the front two.
Apr 20, 2010 | 1998 Chevrolet Blazer
Side to side wheel play
It could be an indication of a bad wheel bearing assembly. Did you check the lug nuts to be sure they are tight? It could also be the tie rod assembly. I would take off the wheel and try to move the just the hub assembly. Do you hear any screeching/squealing noises? Any popping while you are driving? Are your tires wearing? All these are classic signs of a bad wheel bearing. Any decent tire/auto shop can put your car on a lift and check the wheel bearings.
Jul 24, 2009 | 2001 Dodge Stratus
2001 hyundai santafe very wobbly wheel
If you've hit a pot hole hard then the wheel could simply be buckled. Remove the wheel and place it flat on the ground if it wobbles on the ground problem solved: buckled wheel!
Apr 28, 2009 | 2001 Hyundai Santa Fe
Wobbly drivers side tire 1990 chevy tahoe
I Think you should post this in the Car problem forum, and not in the security forum, you might have better luck finding an answer.. prolly wheel bearing though, or loose lug nuts :)
Oct 23, 2008 | 1995-1997 Chevy Tahoe Ignition Starter...
Zooper Boogie Jogger Logo
284 people viewed this question
Top Zooper Baby Gear Experts
Jennifer Rock
Jennifer Rock
thegtw
Dorel UK
Dorel UK
Are you a Zooper Baby Gear Expert? Answer questions, earn points and help others
