Question about Dell Dimension 2350 PC Desktop
Blank Screen after WinXP Splash Logo
Whenever I turn this workstation on, it completes the post test without any issue and goes to the Windows XP splash screen. It then vanishes like normal, leaving a blank screen. The problem is that's as far as it goes.
It seems as though the login prompt is coming up, as I can have the user enter her password and it seems to allow her to login based on the startup sounds.
This is where I'm at:
It will not boot into Safe Mode, it gets hung on Mup.sys
It does not have an additional video card installed (this was my first inclination).
On-board video is enabled in the BIOS.
I tried installing a PCI video card whilst disabling the on-board, this achieved the same exact result.
She just installed a piece of financial software called Otter (I think). IIRC she had indicated she encountered a problem with this installation but I don't know if it's related. I can't really find any documentation on the software and I'm not really familiar w/ it.
Any idea's?
  • 7 more comments
  • Anonymous Mar 28, 2008
    Sure do. Where do I begin?
    Man I'm having trouble getting this thing to boot to a cd. Under the somewhat forward assumption one of the two cd roms should be functioning, I'm starting to wonder if maybe there isn't a larger problem here.
  • Anonymous Mar 31, 2008
    I hooked up another drive and that seemed to work for a little bit but it quit again. I was able to boot into System Rescue once but could not access the GUI, then tried again and the screen started blanking out again.
    I booted to the WinXP CD (or tried) and it started skipping it and going directly into Windows. Tried swapping ram as well thinking maybe I had a bad module with no success. I also tried the stupid Dell utility which got me nowhere. No big surprise.
    This seems like a stupid problem to have. Not stupid because I can't figure it out, mind you...
    Found a ruptured cap on the mobo... I don't think I'm wrong to tell her the mobo is beginning to fail regardless of whether or not that's the root cause. At some point the rest of 'em are at risk of puking.
    If I can get this drive to boot in another machine, I'll try sysprep and see if I can get it to work elsewhere. Thanks for the help everybody.
  • Anonymous Apr 01, 2008
    Update:
    @ Psionics: I hit F12 to get into the boot menu, as well as changing the boot order to the CD ROM first, HD second. Both failed, however I was able to install a different drive and boot to it successfully. I guess both drives that are installed are not operational after all :/. Strangely enough, the 3rd drive ultimately ended up failing in short order, this could have been a coincidence. I didn't see anything regarding a timer for booting to another device in the BIOS but I'll take another look.
    After a little bit more research it looks like the video driver could have gone corrupt (from Dell's website). They give re-installation directions if you can get into Windows which doesn't help me at all. I don't know if there is a way I can go in with something like System Rescue and delete the registry key's that might be causing me drama -or- Windows repair or getting the HD to boot in another environment. I still have a few options that I need to exhaust before I throw in the towel. It's less about $ at this point and more about the challenge. I'll likely not charge this woman a dime either way.
    Mobo model #: Bluford E139765 - Intel chipset
  • Anonymous Apr 02, 2008
    The boot CD your referencing, would it let me run an install package? Like for a new driver? That might be easier -if- I can get it to boot to a CD again (going to try a different drive).
    Haven't tried anything else discussed yet, haven't had time in the day!
  • Anonymous Apr 15, 2008
    Sorry Psionics, I haven't had much time to invest into getting this thing back on it's feet. Work has been slammed!
    I'm downloading the UBCD as we speak. Unfortunately I'm on my way out the door to a conference and will not be back until the end of this week. I probably won't have time to work on this machine until the beginning of next at the earliest.
    I will keep you updated though! Thank you very much for your help w/ all this.
  • Anonymous May 06, 2008
    Well I don't know if your still following this or not, but she ended up buying another PC and she's keeping this one for parts :/.
    I never did get the UBCD to work yet but I only tried it the one time. Regardless it still sounds extremely useful.
    Thank you again for all your suggestions despite the fact that I didn't quite get it conquered.
  • Patrick Michaels
    Patrick Michaels May 11, 2010
    methinks you are suffering from re installtion pre events..do you have the install cd, handy?
  • 236 Answers
Sounds like an issue with the software or a windows update that caused it. Seems to occur more with versions of windows that are not genuine.. Have you tried booting from the XP disk, running microsoft recovery console, and then running chkdsk /r
Hopefully that will fix it.. Otherwise you might have to re-install windows.
Posted on Mar 28, 2008
  • 3 more comments
  • Dave MacPhee
    Dave MacPhee Mar 28, 2008
    Check the bios and in the boot settings, see if CD is before HDD, if not, move it up in the list
  • Dave MacPhee
    Dave MacPhee Apr 01, 2008
    what is the mobo model #?
    Sounds like a bad mobo as well, but for the booting to XP CD, there may be a setting in the bios that delays the "boot to cd" option, and is set to 0 seconds.. If that's the case, you won't even see the option to boot to cd, as it will go by so fast, but not do it automatically..
  • Dave MacPhee
    Dave MacPhee Apr 02, 2008
    There is boot software out there that will let you get into a windows interface and change the registry.. Problem is, you can't really boot from CD....
    Have you yet tried the drive in another PC?
    Also, in the bios (which I am currently looking up a manual for the mobo) is there a setting for "plug and play O/S" set to yes? If so, change it to no and reboot.. Perhaps the cd rom drives are not responding due to the OS not being able to load the drivers... Highly unlikely, but It's worth a shot anyways...
    Getting into the windows repair would work if there is a recovery drive on the HDD... Usually, accessed by pressing F10 (when you would normally press F8 for post options)...
    Looking into more options...
  • Dave MacPhee
    Dave MacPhee Apr 03, 2008
    Yes, the boot cd will let you access the internet and download drivers, as well as install them and access/edit the registry.. It is a little daunting to set up, but once done, can provide a vast array of useful tools..
    You can download it here
    Make sure you follow all the instructions carefully..
  • Dave MacPhee
    Dave MacPhee Apr 05, 2008
    any updates?
SOURCE:
My dell optiplex gx 260 has a blank screen when I turn it on. The windows xp professional screen comes up then when it goes to where the desktop should show up all I get is a gray screen
1. From reading your issue it seems the video card is defective.
2. If you have received the Windows XP splash screen and then the monitor displays a gray screen then only two things have happened here your drivers are corrupt for the video card or the video card itself has failed.
3. Suggestion: install a new video card compatible with Windows XP.
4. Most Dell Optiplex desktops have the video graphics card integrated to the the mother board.
Oct 14, 2011 | Dell OptiPlex GX260 PC Desktop
Just got cq56-115dx laptop this morning. turned it off after setting it up. Turned it back on and only have blank screen. Power shows lit up.
Hi.
Remove the AC power (charger) and then take the battery out. Plug in just the AC power supply and turn the laptop on, see if it boots up and shows a display on-screen. If it boots let it boot up and then shut it down as normal. Reinsert the battery and try as normal.
If you still get a blank screen can you then tell me if you get any post (splash) information like the Compaq Presario logo before it goes blank.
Good luck.
Jun 28, 2011 | Compaq Presario CQ56-115DX Laptop
Installed RAM and now monitor has no display. I
The splash screen with the LG Flatron logo is the monitor's splash screen not the PCs.
The machine is NOT booting up the splash screen is the monitor coming on.
Remove the 1Gb stick an see if the machine performs normally.
If it does then power it off, remove the power cord and CAREFULLY reinstall the new stick.
If it fails to boot you may have a defective memory module.
If the machine fails to boot with the new stick removed make sure you have the original memory seated properly and all cables securely attached
Jan 03, 2011 | EliteGroup Computers & Internet
Windows xp won't load. Displays computer brand logo. Logo goes off, then a blank screen.
This is often a hard drive based issue. I prefer to extract all DATA before continuing. Hook up the drive to a good computer and test the drive for malfunctions, after data recovery...
Nov 03, 2010 | Computers & Internet
Screen goes blank after booting with WinXP SP2 CD.
Hi, your will need to delete your windows XP re format that part of your hard drive, then re install XP
Jul 04, 2010 | Microsoft Windows XP Professional SP2
I have an ees pc 4 gb i can see the windows xp logo when i turn it on and hear all the sounds but then my screen is blank but i still hear windows help i'm not a computer whiz
Some systems may take a bit to boot at times. Windows has to do a number of functions during startup. Have you tried just leaving it run after you see the windows logo and wait several minutes? If not, give it a try. If after about 5 minutes you see nothing, get back to me.
Since the logo appears, you have video. Although the screen goes blank after this mostly means that Windows is still loading and has to perform some tasks and possible system correction issues. Let it run like I mantioned above and see what happens. Thanks
Jun 11, 2009 | ASUS Eee 4G Notebook
Dell 8400 Refurbished by with WinXP Pro preinstalled will not boot up. Gets past Dell XP Logo, then goes to blank screen with curser...however, keyboard locks up and can not get any further? What's th
windows is not loading properly.
if you're not worried about anything on the computer:
insert the recovery CD, boot the system to the CD, and reinsatll windows.
May 19, 2009 | Dell Dimension 8400 PC Desktop
Blank/black screen at power on
This is hopefully a possible fix. I have encountered a similar problem with windows xp and vista. the fix I found that will eliviate this problem and a startup-reboot-startup-reboot... If you have your original windows (xp or vista) CD lounch it like you would do to do a system install. As the installation starts it will show ask you if you would like to do a recovery using the recovery console, just press ESC and go on. Press the F8 to accept the license. If Windows is not completly broke, it will find the original installation on your hard drie. It will ask if you want to repair. Press the R key and windows will reinstall your operating system, without destroying your software or data. After it is done the system will go to the windows startup screen. You will need your windows product key located on your machine or on the original software packaging.
I hope this will fix your problem.
Mar 17, 2009 | Dell Inspiron 6000 Notebook
Monitor displays breifly then goes to blank screen
If tried the monitor on two other computers with the same result -- definitly your monitor is faulty. Take it to the repair shop. To make double sure, run your computer with another monitor. If everything is fine now; you can blame the monitor.
Dec 17, 2008 | Dell Dimension 4600 PC Desktop
Dell Dimension 2350 PC Desktop Logo
887 people viewed this question
Ekse
Clive
Clive
