Question about Dell Inspiron 5150 Notebook
When i plug the charger into my dell 5150 the led's on the front instantly flash once and will not charge a battery or run. if i install a precharged battery the unit opperates perfact until the battery discharges.
  • 3,940 Answers
Try a different AC adapter, if no change the charger unit on the motherboard is bad
Posted on May 11, 2010
Mini 1012. new battery. charger led working, battery wont charge. when plugged in charger works for about 30 seconds
Seems like you may have purchased the incorrect battery or they shipped you one that is NOT for your unit, if you purchased an "aftermarket" battery this could be the issue. Not saying aftermarket parts are bad, they are just massed produced and sometimes you get a bad one. Return it for refund or replacement. Try E-Bay for a reseller for this product, much less cost.
Jan 28, 2013 | Dell Inspiron Mini 1012 Netbook...
I'm borrowing a Jet 3 Ultra from the local Am. Legion for my Mom to use. They know nothing about it except they were told it had a new battery. I plug it in and all the LED's light up with the...
The batteries need charging and when you plug in the charger and the power is on the lights wil flash indicating that the charger is plugged in. Now look at the rear of the chair near where the charger cord plugs into the chair and you should see a voltmeter. With the charger plugged in the voltmeter will indicate about 5-6 amps and after charging overnight the voltmeter should be reading 0 amps. If when you plug in the charger cord and the voltmeter indicates 0 amps then I would suspect that the charger is not working or that the fuse is blown in the charger circuit. The only way to see if the batteries charge would be to borrow or find an offboard charger that will plug into the charger port located under the front of the joystick and after charging for 10-12 hours see if the battery level lights show full charge Hope this helps
Jun 25, 2011 | Pride Used Mobility Jet 3 Power Wheel...
My compaq presario 2200 wont boot up...when i press the on/off switch without the a/c charger (battery alone), the amber led flashes twice....if i plug the charger in with the battery, the led blinks once...
If the computer is not turning on, there is a big chance of hardware failure and normally there is no easy fix for this rather than a motherboard replacement.
May 03, 2011 | HP Compaq Presario 2200 Notebook
Only amber light is on when start...no green lights...
its a power problem. Your power supply is not giving enough power
Dec 08, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Orange battery light on, but computer says its running on electrc
Hi, the orange light is meant to show a charging status, so if you have orange light and its running on electric it just means its plugged in and charging.
Mar 09, 2009 | Dell Inspiron 6000 Notebook
Dell Inspiron 5150 no power, no lights
it could be that the ports where you plug in the charger is damaged. if you have an identical or a known good battery that is charged, try to install that and check if it works. you need a motherboard replacement if the system works with a charged battery.
Sep 24, 2008 | Dell Inspiron 6000 Notebook
WON"T WORK
sounds like a dead battery. Plug the origional charger into it and the front led (below the flash) should flash red. If the red led in the back of the camera flashes or stays lit, then you have the wrong charger plugged in. (the camera won't power up if the back red/green led is on when plugged in)
May 08, 2008 | Jazz DV-179 Digital Camera
Can't charge battery or run off AC
You may have a problem in the DC charge circuitry. These parts are located on the moatherboard directly and can't be bought separately and repaired. You must send your Dell to a specialised service to have it fixed by them. Sorry, I can't see no other way for this problem to be solved.
Jan 20, 2007 | Dell Inspiron 5150 Notebook
Dell Inspiron 5150 Notebook Logo
303 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
