Question about Brother XR-65t Mechanical Sewing Machine
I can't get the pressor foot on the silver part came off and the actual pressor foot
Place the foot under the arm while arm is in up position. Put arm in down position and foot should snap into place (line it up where it is supposed to go together before lowering the arm).
Posted on May 13, 2010
Need. Help getting pressor foot to go all the way down?
have you checked to see if the pressure foot itself has a height adjustment, or even try a different pressure foot.
Aug 04, 2017 | Sewing Machines
How to adjust pressure on presser foot
Depends on your machine brand and model. Some machines have that capability, others do not. Consult your owner's manual.
Aug 25, 2015 | Sewing Machines
Bar that sewng foot is attached to for raising & lowering suddenly will not drop sweing foot all the way down to plate. Any suggestions on how to fix?
Perhaps you accidently moved the switch that enables free hand embroidery? It's up and under next to the pressor foot lever. Slides forward and backward. Forward the pressor foot will go all the way down to the feed dogs. Slid back and it keeps the foot up off the feed dogs but allows the thread tension to work properly. It would be easy to accidently move it when operating the pressor foot raise/lower lever.
Aug 31, 2014 | PfaFF Sewing Machines
Problem with striaght stitch pressor foot
it's possible that the needle bar is out of alignment and needs to be fixed at a sewing machine shop
Mar 18, 2014 | Kenmore Sewing Machines
Needle hitting pressor foot
Presser foot not correctly mounted, or needle bent, or needle bar loose or bent are the most likely.
Where to find a not snap-on 1/4" with edge pressor
Go to www.allbrands.com and you can buy a low shank screw on presser foot. I am assuming that it is a low shank. (I looked up your manual on www.singerco.com for free) It is $14.95, I think. Good luck
Nov 20, 2010 | Singer 4830
Hi I have a Husqvarna 1+ when the pressor foot is in the down position a warning indicator states that the pressor foot is not down and the machine will not function.Any sugestions would be greatly...
The problem could be caused by a couple of issues. It is either with the switch that is located above the foot, that tells the circuit board when the foot is up or down, or with the circuit board itself. It could also be the lever you lift the foot up and down with. Inside the machine that lever has a plastic "fin" on it that touches the switch. It is possible that the lever is broken. Either way, you need to take it in for service.
Dec 29, 2009 | Husqvarna Sewing Machines
How can my wife tell what a quilting foot looks
it is like regular pressor foot but is wider
Nov 22, 2009 | Husqvarna Rose
Simplicity 4 thread EZLock 880 pressor foot settings
Easiest way to get the tensions right, use 4 different coloured threads
Make sure the tension disks are clean........run a length of fabric in a see saw fashion through each tension unit.
....set all the dials to 3 or 4 then sew test.......take a look at what needs attention, make a small adjustment and test/adjust until the needle threads are firm and the looper threads meet neatly at the edge of the fabric with just the absolutely tiniest hint of being loose.
Jul 16, 2008 | Sewing Machines
Pressor foot
Go to this link on the Brother website to order:
http://www.brother-usa.com/homesewing/modeldetail.aspx?PRODUCTID=LS2125&tab=optional
Jul 05, 2008 | Brother LS-2125 Mechanical Sewing Machine
Brother XR-65t Mechanical Sewing Machine Logo
48 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
