Question about Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc
Raypak 2100 pool heater won't heat, PRS and HL2 error codes.
I have a Raypak 2100 pool heater. The heater gives me a variety of error codes. Sometimes it comes on for a few minutes and then shuts off with the code HL2. Other times it won't come on and displays PRS. My filter baskets are all clean. When I turn on my filter I can hear water going through the heater with a swich sound. I suspect that this is cause by a low pressure problem or that some sort of valve is stuck close or only paritally open. At times it even sounded like something was banging around inside the heater. Does anyone know if there is an internal valve or some part that could have broken off or be clogging the heater?
Thanks
Well, I replaced the pressure switch with no joy. I tried all 5 levels of pressure 1-5 and every wiring combination. Finally, I returned the new $70 pressure switch and took the 2 wires and tied them together (jumped them). Here's the only downside...If you run your pump in backwash, recirc, waste, or any mode that would cause water to bypass the heater it MUST BE OFF. Otherwise, let it ride. It's working great and I hope to go into October weather permitting.
Posted on Sep 09, 2010
I have a raypak R266A the HL2 error comes on and heater quits. makes a whineing noise
check gas pressure if too low heater will overheat whining is valve starving for gas
May 24, 2012 | Raypak 266K BTU Digital Residential...
Raypak 2100 just get SPK then LO codes. won't ignite
if wired 120 volt check wiring and check gas pressure see if lines have cobwebs
Jan 02, 2012 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak 2100 pool heater " PRS " diagnostic reading What does it mean and how do i correct it
This is low pressure. Start by checking your baskets for clean then be sure to clean the filter. Then make sure the by-pass valve is closed and lastly if your pump basket is cracked or broken check to be sure nothing is clogging your impeller.
Sep 19, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Have an error code GVP
You didn't indicate what model heater you have, but here are some of the fault codes you might see. Could it have been GVO? You can download a manual for your exact model at www.raypak.com
BD1 Board failure
EEP Microprocessor error
FAN Blower pressure failure
FFL Flame sensing when pilot and gas
valves are closed
GVC Gas valve closed
GVO Gas valve open
HL1 High limit switch #1 open
HL2 High limit switch #2 open
IGN Ignition failure
ILO Ignition lockout - Propane units only
PRS Water pressure switch open
ROL Heat roll-out safety switch open
SNS Sensor failure, Water temp. below 36°F
or above 110°F
VNT Vent switch open
Aug 03, 2010 | Raypak Free Hydraulic Lift Gate Delivery -...
Raypak gas pool heater with error code HL2
Do you have power to the heater?If you do then I would look for a hi limit switch to reset.It might be the pump you have to reset.
Mar 16, 2009 | Bosch 1600H-LP Liquid Propane AquaStar...
Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc Logo
1,755 people viewed this question
Top Raypak Pool & Spa Experts
Paul Carew
Jim Goldsmith
Jim Goldsmith
Craig Butler
Craig Butler
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
