Question about Sony Playstation 3 (PS3) Console
On our PS3, when you press the soft power up button, it tries to start but th blue light changes to yellow and it stops, leaving the Red power off light flashing
    President:
  • 1,469 Answers
You can try the steps below. Its from PlayStation Forum:
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System
If the above steps still does not solve the problem, then I think will have to update your Ps3.
Update your PS3 (in the settings menu the 1st option).
Go on the internet browser on the PS3 then go on the menu press triangle then on one of them there are delete cookies and the delete the others as
well as cookies.
You could also try this as well: put the PS3 on then press the eject button (with no disc in) then hold it and switch the PS3 off at the back with your finger on the eject button still holding it, then put it back on and the fan test should be working this may cool it down. It might be over heating.
But if your problem is not still solved, then maybe you should call sony for further assistance.
I wish you good luck
Posted on May 12, 2010
My playstation 3 console wont turn , when i try to it stops and a blue then yellow light flashes , what can i do to fix this.
source: http://www.edepot.com/playstation3.html#PS3_Model_Differences Yellow Light of DeathThe "Yellow Light of Death" or YLOD is the common phrase people use to describe the following sequence when they try to turn on their PS3:
  • Press Power Button
  • Red Light Flashes Three Times
  • Yellow Light Flashes
  • Green Light Flashes
  • Beeps Three Times
  • Red Light Flashes
The sequence above may vary a bit but you do see the flashing yellow light (sometimes shows up as orange) that normally you would not see when operating your PS3. The YLOD is a general hardware fault that can mean a lot of things. However, one of the problems is cracked solder that leads the PS3 to think one of its internal chips is not connected or is broken somehow. Cracked solder can happen when the chips get too hot (RSX most likely) and leads the motherboard to start bending, which may crack the solder. Changing the power supply (lower the average wattage going to the chips to lower the heat) and better thermal compound (heat dissipates faster to the heatsink) may prevent this error from occurring. However, if your PS3 has already had the YLOD, then you can reflow your motherboard every few months to keep it working (but it is not a permanent fix as the YLOD usually comes back).
Oct 10, 2010 | Sony Playstation 3 (PS3) Console
When my PS 3 is powered on the red light stays on. When I press the ON button to turn it on, the red light blinks, turns yellow and then goes back to red.
  • The interior of the system has become unusually hot. Check whether the system is being used in a hot location or whether the vents are blocked. Stop using the system and leave it unused until it cools down. Continuing to use the system in the above condition will cause it to stop functioning.
  • The temperature inside the system has risen too high. Check whether the system is being used in a hot location or whether the vents are blocked. Touch the system's power button to stop the flashing, and then leave the system unused until it cools down. After it cools down, turn on the system again.
  • Feb 21, 2008 | Video Game Consoles & Games
    After pressing the on button it turns green for 5 seconds then it flashes yellow/orange for a second then it flashes red.
    • Beeps Three Times
    • Red Light Flashes
    Oct 09, 2010 | Sony Playstation 3 (PS3) Console
    PS3 turned off on its on, now won't turn back on
    "When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly over heated. This may be caused by poor ventilation or the vents may be blocked."
    "If this happens:
    • Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
    • If the PS3 system is in an enclosed area like a bookshelf or entertainment center, move it to a more open area.
    • Leave the PS3 system off for 30 minutes to let it cool down.
    • If you continue to have issues, you will have to send the system in for service."
    Hope this will help...
    May 31, 2010 | Sony Playstation 3 (PS3) Console
    My playstation has the light trun green yellow flashing red light
    With your PS3 turned off, press and hold the Power button on the front of the PS3 for about 10 seconds (the system will beep as normal as it starts up but after 7-10 seconds it will beep again). The video settings should now be reverted. Doing this will also reset any theme settings. try this? seems to fix alot of issues.
    Jan 22, 2010 | Sony PlayStation® 3 (80GB) Console
    I have playstation 3 model # CECHH01, a game is inside, when i power on the light goes green, then quickly goes blue then yellow and goes back to red and powers off leaving the red light blinking. What do...
    well sounds like your PS3 needs to be reflowed or reballed. I would highly recomend you have a professional do the repair. as fas as having a game stuck inside the machine you can get it out in under 10 seconds by doing this.<br /> <br /> 1) turn off power switch in back of ps3<br /> 2) place finger on eject button and hold there while ps3 is off ( no red light) <br /> 3) while holding finger on the eject button turn power switch on the back of ps3 on , hold finger on eject button untill the disk ejects.<br /> 4) turn power switch off and have unit repaired or replaced. <br /> <br /> if unit is covered by warranty and you send it to sony you must get your disk out of the system as you will NOT get it back if you send it to sony. Most reputable repair shops will return your disk with the system or give it to you before they take the system in for repairs. I ALWAYS give the game disks back before a customer leaves my shop as it leaves me with less to keep track of.
    Jan 04, 2010 | Sony Playstation 3 (PS3) Console
    When i power on ps3: light goes green to blue to red (3 beeps)?
    This is the yellow light of death i got it some time ago and had to buy a new ps3 there is a way to fix it but i costs more than a new ps3 i had to buy a new one so your screw lol.
    Dec 06, 2009 | Sony Playstation 3 (PS3) Console
    Wii Console will not turn off. After pressing the Power off button the console light goes from green to yellow (not red.) After about 5-10 minutes the blue light will start to cycle on and off and the game...
    try turning it off on the console and not with the controller. turning it off with controller turns it yellow. press and hold the power button on console for 5 seconds it should turn red.
    Jun 30, 2009 | Nintendo Wii Console
    PS3 light turns GREEN, w/ blinkin BLUE, to YELLOW, to flashin RED
    it is fried and needs repairs if you break the seal by trying it yourself you void the warrany
    Mar 15, 2009 | Sony Playstation 3 40GB System Console
    Pairing mode for headset with PS3
    On your PS3 XMB menu. Go to settings. Scroll down to accesories. Then click on manage bluetooth devices. There you will find the autodetect for the bluetooth headset. While the bluetooth headset is off, press and hold th on button until the LED stays on. The quickly use the PS3 to detect the blue tooth. It will ask for a pin to pair the units up. The pin is four zero's.
    Jan 09, 2009 | Ubi Soft Entertainment Tom Clancy''s...
    Sony Playstation 3 (PS3) Console Logo
    Top Sony Video Game Consoles & Games Experts
    shaun taylor
    marley mcelhinney
    juanmireles1
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
