Question about Lakewood 2727 Heater
Can I lay the heater on its side for storage? Can I store it in sub zero tempatures over the winter?
  • Lakewood Master
  • 2,461 Answers
No keep it standing up.. no not in sub zero
Posted on May 11, 2010
Need a replacement door gasket for the refrigerator door of my Sub-Zero 690 side by side.
The part number for that is 7010573 is could be purchased at your local appliance parts store or online at; searspartsdirect.com
apdepot.com
repairclinic.com
assuredparts.com
applianceparspros.com
Gene
Aug 06, 2011 | Sub-Zero 690 Side by Side Refrigerator
Kitchenaid superba side by side fridgerator side is not working
Do you see frost built up on back wall of freezer if so it is not defrosting and this is what needs to be checked, remove back wall of freezer and check these;
Defrost heater-- it usually is at bottom of the evap. coil, to check it remove wires to it ,use a meter set to the lowest ohms setting and check for somewhere between 10-50 ohms if that is what yours is its good if meter reads OL replace defrost heater
Defrost thermostat-- if clips to the top of the evap. coil and is metallic,round , about the diameter of a quarter with a plastic side with 2 wires coming from it(do not confuse it w.thermister),remove wires and check for ZERO ohms WHEN TESTING IT MUST BE COLD so check it when frost is built up,IF meter reading is OL (WHEN COLD) its the problem
Defrost timer or defrost control if has digital display to show tempature
check timer(it could be anywhere except in freezer) by turning till you hear a click,the defrost heater should come on within 5 minutes if the heater does come on the timer is the problem and needs to be replaced,if the heater does not come on the above mentions parts (heater/t-stat) will be the problem.
defrost control is hard for unskilled lay persons to check so if heater and defrost t-stat are good replace control
Hope this helps,
Gene
Aug 03, 2011 | KitchenAid Superba Architect KSCS25INSS...
Squeaky sub zero side by side refrigerator door
Dear joeyh630,
I'm sorry to hear that you are having a problem with the hinges on your Sub-zero unit. I would recommend that you apply lithium grease to the hinges using a cue-tip. Lithium grease seems to work well and also holds up nicely. You should be able to find this grease at a home improvement store or auto parts store.
If you have any further questions or concerns regarding this or any other issue, please contact us directly. You can contact us via phone Mon-Fri. 8:00-5:00 CST at 800-222-7820. We can be reached via email at CustomerService@SubZero.com.
Thanks!
Customer Care Team
Sub-Zero/Wolf Appliances
Feb 05, 2011 | Sub-Zero 690 Side by Side Refrigerator
TV storage in sub zero temps
All electronics devices,can't be on exposer to cold 20 degrees or hot 110 degrees very long only a couples hours.Than the componnents on the pc board will malfunsctions or dies all together.Bring it with you and store it at 45-50 degrees should be no problems.
Apr 26, 2010 | Vizio VW22L 22 in. LCD HDTV
Ice making for sub zero 48
The sub zero should make ice soon after being installed. If there is ice around the door frame of the freezer there may be a problem with the door frame heaters. There should not be ice around the door frame.
Nov 09, 2009 | Sub-Zero 661/F Side by Side Refrigerator
Sub zero particles in ice from ice maker
This issue occurs if your Ice Maker is not clean or have dust particals inside, follow the below steps in order to clean it properly:
Step 1 Lift the power bar located above the ice maker storage tray.
  • Step 2 Unplug the refrigerator.
  • Step 3 Allow the refrigerator and freezer to defrost. This will melt any large blocks of ice that have accumulated in the ice maker.
    Clean the Ice Machine
  • Step 1 Remove the ice machine storage tray.
  • Step 2 Dump any water in the ice machine storage tray.
  • Step 3 Wash the ice machine storage tray using warm, soapy water. Rinse and allow to dry completely.
  • Step 4 Sanitize the lines of the ice maker. Consult your manufacturer's directions for steps to do this, because it's not available on all models.
    Reassemble the Ice Maker
  • Step 1 Replace the ice machine storage tray.
  • Step 2 Plug the refrigerator into the outlet to restore power.
  • Step 3 Lower the internal power bar located just above the ice machine storage tray. This allows the ice machine to make new ice.
  • Jul 20, 2009 | Refrigerators
    I have a 7 year old sub zero 632. The
    The sub zeros I have worked on have a compressor for each side. Is your fan blowing. You may have a defrost timer or heater. Possible low on gas but thats not very likely the sub zeros are made very well. Check to see if fan is blowing. Check condensor coils on top to see if they are clean. Check to see if your condensor fan is blowing. These are just possoble problem you can check if every thing looks good. Call a service tech ask for free estimate on repairs. Rus
    Jul 06, 2009 | Sub-Zero 632 / S
    Sub zero refrig - ice forming inside
    The solution posted previously is TOTALLY WRONG. A Sub Zero ref doesn't have a heating element in the fresh food section. Only in the Frozen food section. It has 2 totally separate systems for each section. 2 Compressors and 2 evaporators. They share a condenser. If you are having ice build up in the refrigerator then the problem you are having is a refrigerant leak in the fresh food evaporator. You need to have a certified tech come out and replace the evaporator in your refrigerator section of your Sub Zero. Not sure what you are asking about the thermostat.
    Oct 12, 2008 | Sub-Zero 661/F Side by Side Refrigerator
    Fuzzy picture
    what cain of tv you are talking about
    May 10, 2008 | Televison & Video
    ICE MAKER SUB ZERO REFIGERATOR
    Check water turned on. check ice button switch turned on in fridge. remove juice storage, ice container in freezer, check ice bucket full white plastic flapper to make sure not stuck on a white peg at top. flapper must hang down and be freely movable to signal ice maker to keep busy. If up high will turn off ice maker. Lots of other parts especially heater circuits involved also: fill tube supply heater not working then frozen supply line then no ice. Look for wiring diagram in ziplock behind compressor grille. can order parts at repairclinic.com. logical design, layout, easy to get to sensors, heaters. makes sense if look at it long enough.
    Feb 14, 2008 | Sub-Zero 690 Side by Side Refrigerator
    Lakewood 2727 Heater Logo
    88 people viewed this question
    Top Lakewood Heating & Cooling Experts
    Mack Baxter
    paulcarew
    jdthefixer
    Are you a Lakewood Heating and Cooling Expert? Answer questions, earn points and help others
