Question about Samsung CLX 3160fn All-In-One Printer
Network Scan - Samsung CLX-3160FN
I am completely set up to print over the network.  Our network administrator has set up all of the network utilities on his Windows machine.  However, when Network Scan is selected, I receive the message "Not Available" on the printer's display.
A side problem, I am unable to access my printer's Smart Panel on my MacBook Pro 10.5.2
  • 3 more comments
  • Anonymous Apr 04, 2008
    I have a very similar problem on a Vista/Win2k system. Network printing is ok, but i have no chance to scan to network. (Scan to usb is ok), software does work, but i cant add the scanner to/thru the software.
  • Anonymous Jun 07, 2008
    I have the same problem!
  • sarunasb Jul 21, 2008
    the same
  • Anonymous Mar 31, 2009
    Printing works fine via network but scanning doens't work on one new Windows XP SP3 desktop. To other Win XP SP3 desktops it works.
  • Anonymous Apr 07, 2009
    Same problem,,, scan yellow lines all over page!
I have the same problem. Where I can find the solution?
Posted on Jul 26, 2008
Samsung tech support isn't much help either! what I found with their network card is that it is on and off. The smartthru panel on the desktop (XP Pro SP3), if you watch closely, it can't poll the information everytime.
Posted on Jul 25, 2008
Same problem here with windows xp pro, print ok, scan must use USB. andyone can help?
Posted on Jun 23, 2008
SOURCE:
Couldn't scan from the printer to the computer
I got the same thing when I tried it on my machine. I use the SmarThru web admin program to scan to the network. It should have come with your machine on a disk. If you can't find the disk, this link should allow you to download it. http://www.samsung.com/uk/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=06010100&prd_mdl_cd=&prd_mdl_name=CLX-2160
Hope this helps you.
Jul 09, 2010 | Samsung CLX 3160fn All-In-One Printer
My Samsung CLX-3160FN has stopped printing colour. I have changed all the cartridges and it will copy in colour, but prints in black and white.
You need to check your document print settings on your PC. Drill through the printer properties menu until you get to the colour settings. At a guess you currently have it set to "Greyscale" rather than colour or auto.
May 03, 2010 | Samsung CLX 3160fn All-In-One Printer
No communication between scanner and computer - Printer is ok
It may or may not work, but try installing as Administrator and setting the program's EXE into "Compatability Mode for XP SP2",and also, running as Administrator. Windows Vista often just doesn't want to support any hardware over like a a couple of years old... Drivers are a HUGE issue. Especially for older stuff. Compatability Mode is one way round it but not always.
Feb 12, 2010 | Samsung CLX 3160fn All-In-One Printer
My Samsung CLX-6200 Network MFP printer prints but does not scan
Hmm Tricky,
You could try temporaily disabling the windows firewall, and any anti-virus firewalls to see if they are blocking communications to the scanner.
(Please rate my answer thanks :)
Jun 23, 2009 | Samsung CLX 3160fn All-In-One Printer
Samsung CLX-3175FN Scanning Error
I think the laser part should be unplug in Data cable and power then plug again ..
Jan 15, 2009 | Samsung CLX 3160fn All-In-One Printer
CLX-3160FN SAMSUNG Printer/Scanner/Fax
Replace your USB cable with a good quality, thick USB cable that does not exceed 10ft. Let me know if the problem persists.
Be blessed.
Aug 25, 2008 | Samsung CLX 3160fn All-In-One Printer
Network scanning Samsung CLX-3160FN All-In-One Printer
You have to start Smarthru 4 and use it from there. First you have to find the scanner with Smarthu then scan. Play with Smarthru and the settings in it. It took some playing with it for me to get it set right. Now it works just fine.
Feb 27, 2008 | Samsung CLX 3160fn All-In-One Printer
Samsung clx-3160 won't print
1) You need to configure the IP address on the printer to get it printed thru network.
2) Scanner Locked, there's a lock underneath the scanner bed,make sure it's fully released.
Feb 25, 2008 | Samsung CLX 3160fn All-In-One Printer
Fax device I/O error
installed samsung scx-4521f multi function printer. can't fax from smarThru program. get message : Fax device I/O error
Jan 11, 2008 | Samsung CLX 3160fn All-In-One Printer
Samsung CLX 3160fn All-In-One Printer Logo
2,042 people viewed this question
Top Samsung Office Equipment & Supplies Experts
jasbo
jasbo
Steve Allison
Steve Allison
Lawrence Singapore
Level 1 Expert
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
