USB devices not seen
Hi. My usb devices are not being seen by my pc, but when I disconnect each one the pc states "one of your usb devices has malfunctioned." This happens on all of the usb ports. Sometimes I get the device to be seen after about the eighth re-start of the pc. The devices i have used include a Tom tom satnav, a Goodmans camera and a Lexmark 1100 series printer. At present the Lexmark disc is stating "you have not connected the printer." There is a Canon printer connected up too which has never given any problems. I am running windoze xp SP2 with about three registry problem fixer programmes. The problem was no better or worse before the registry programmes were installed. Thanks.
  • 3,587 Answers
Go through control panel/system/device manager, and see if the USB ports(should be at bottom) are good or not.
if not, remove them all
use scan for new hardware at top
see how that works.
Posted on Mar 28, 2008
Ace crystal eye webcam states camera not found. Device manager states that it is an usb video device.
there are two solutions for this.
1. Try defragment your C: drive & restart your pc.
if this doesnt work
2. uninstall the USB webcam sofware & reinstall it again.
(please check that you have the webcam softwaare before uninstalling)
Jan 03, 2011 | Acer Aspire AO5213530 101Inch Netbook Onyx...
I've had this HP printer for years with no problem using it most days. just plug it in when i want to print. but for some reason it has just decided that windows does not recognise this USB device. i have...
Disconnect the power cord from back of printer
Disconnect the USB cable from PC
Turn off your PC
Disconnect the power cord from wall outlet
wait for 10 minutes
Reconnect the PC Power cables
Power on the PC
When you see the PC desktop
Re-connect the Power cable to printer
Re-connect the USB cable of Printer to PC
This should resolve your issue
Sep 25, 2010 | Office Equipment & Supplies
When printer connected to pc is showing usb device not recgnised in windows xp
two things to try
  1. try using another usb port ( preferably one on the back of the pc)
  2. switch out usb cable with another
Sep 24, 2010 | Office Equipment & Supplies
I have a hp pavillion ze5170 and a belkin wireless dongle. the comp states that i need hi speed usb. what is that?
Ignore it, it just means it could run faster if you had USB 2.0 but almost all USB devices are backward compatible to standard (USB 1)
Sep 17, 2010 | HP Pavilion ze5170 Notebook
After startup my PC I got the BIOS screen stating in "Detecting IDE drives...".but it does not detect the drives and also not enter to the further startup configuration.please give a solution of this...
Shut down computer, disconnect from power outlet. disconnect all usb devices on the usb ports and just leave mouse and keyboard connected. disconnect harddrive cable from the motherboard and hard drive and reconnect cable again.
Restart system afterwards to see if the issue was resolved.
Should you have any other questions please just leave a comment.
Jun 26, 2010 | Dell Dimension E310 PC Desktop
What is the version of the usb port on a compaq presario 1200
Hi again, after extensively searching I believe your Laptop has a USB version 2.0.
Most PC's manufactured before 2001 were USB 1.0 and USB 1.1.
The Spec Guides for your PC indicate 2002 was the year of manufacture.
USB 2.0 is a faster USB connection than version 1.0 or 1.1. You might have trouble connecting devices that are USB 2.0 (which all new devices are now - since 2001).
To double check, use your Device Manager on the PC to look up the USB device and see what is written.
If you are using XP then do the following:
  1. Click Start
  2. Click Settings
  3. Click Control Panel
  4. In the Control Panel double-click the Systems icon.
  5. In the System Properties window click the Hardware tab.
  6. In the Hardware tab click the Device Manager button and you will see a list of devices.
  7. Click the + button next to the word the Universal Serial Bus controllers.
If it is USB 2.0 then it should say something like USB Enhanced or USB High Speed, this means it is USB 2.0 compatible.
I hope this helps. Please rate. Regards,
Feb 12, 2010 | Compaq Presario 1200 Notebook
Click on this and download the driver. Then wait and then when it say's that the installation is complete then try again.
Jan 03, 2009 | LG VOYAGER VX10000 Cellular Phone
My usb port is not 2 - I keep getting a message that states that I need to get a hi speed usb device host controller. Where can I get this? I have an ibm thinkpad r40.
On some laptops that are older (an IBM R40 is a bit older) there are no high speed usb ports but if you plug in a usb device that is USB 2.0 into a usb port that is not high speed, the operating system (Sounds like Windows XP) will display that message even though you don't have a high speed usb controller. The USB device will still work but at a slower speed. You can ignore this message without a problem
Nov 07, 2008 | IBM ThinkPad R40 2722 Notebook
Disconnect the USB drive
Boot to Safe Mode (F8 at boot), then open device manager (Right Click MY Computer, Properties, hardware tab, devicemanager button) then find the USB Root hubs and delete them
Reboot in the normal mode, go back to device manager, usb root hubs, right click each, properties, power management tab, uncheck the check box to let windows power off the hub (On by default)
reboot, connect drive, see if it detects.
If it doesn't. open Disk Management (Click Start, click Run, type compmgmt.msc, and then click OK.
In the console tree, click Disk Management. The Disk Management window appears)
and see if it is seen then but has a conflict with the drive letter.
If that doesn't resolve, try drive on another system.
Jun 24, 2008 | Computers & Internet
A-hi speed usb device is plugged into a non-high spped usb hub
this usually happens when you plug a 2.0 usb device into a 1.0 device. If your appliance works then i wouldn't worry about it but if you have older technology then it may be time to upgrade
Dec 24, 2007 | Computers & Internet
Computers & Internet Logo
63 people viewed this question
David Payne
David Payne
