Question about Nortel T7316E 2-Line Corded Phone
Nortel T7316 - We have two phone lines on our network. We have set the auto attendant to come in after the secretary has two rings to give a live answer. The problem is, when the secretary is on the first line, the auto-attendant does not kick in for the second line. Example: We have two main areas for our phones:church offices & daycare. We want both to go through our secretary first. However if our secretary is busy on one line, we what the call to go auto-attendant so the other line can be used with options.
    President:
  • Nortel Master
  • 860 Answers
When you say "auto attendant" are you talking about a " press __ to talk to ___." or is it more like "please leave a message ..."? Also, what kind of voice mail system is your telephone system using?
Posted on May 11, 2010
  • george  peters
    george peters May 12, 2010
    Did you find out what kind of voicemail you have?
  • george  peters
    george peters May 18, 2010
    Was the problem resolved?
Nortel/Norstar ICS phone system - Calls go to wrong voicemail on calls forwarded with NA
Check the forward no answer setting for number of rings on each extension that has ringing lines. The number of rings should be more than the auto attendant is set to answer with.
Nov 01, 2013 | NorStar Lands Phones
I am using a Nortel T7208/T7316 sets (BCM 450 PBX) system, and I want to program a phone to ring when someone calls the main line. Most of our phones only ring when you type the extension internally. I...
The phone must be programmed with the target line assigned to the number you wish to have ring at that phone. This can be done with the BCM Element Manager interface. If your BCM450 is running version 6, I think this can even be done directly from the phone, but I'm not sure of that process.
Nov 09, 2012 | Nortel Business Series Terminal T7208 -...
Stop external calls ringing allow internal calls
The lines must be programmed to Appear Only instead of Appear and Ring.
This is done under Config/Sets/LineAccess/LineAssignment.
If unsure of Config password, programming navigation then call in a tech/vendor....1 hour min service call unlell your vendor has remote access via RAD or IRAD.
Sep 21, 2012 | NorStar T7316 Corded Phone
Nortel T7316. We use auto assistant. Message picks up immediately. I want the receptionist to answer live and if she does not answer after a couple of rings for auto assistant message to kick in. How can I...
To change the number of rings enter Feature 983, if your system has 2 digit intercom #s your password is 120000 if your system has 3 digit intercom #s your password is 1020000. once you have entered the password you will see 3 selections you can make .use the three soft keys under the display and select AA (auto Attendant).
The 3 soft key selections GRTG, TABLE, and LINES
Press the LINES soft key
Enter the line number on the line you want to change ringing on (probably Line 1) and press OK
Press the TABLE soft key then the RINGS soft key
Press the CHNG soft key and enter in the amount of rings you wantand press OK
Press the NEXT key to go to the next line
Repeat the procedure for the remaining lines
Press Rls when finished
May 09, 2010 | Nortel T7316E 2-Line Corded Phone
We have nortel t7316 phones in our office. one
Programming is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt,
press the show key (top right arrow).
The display should now ask for an extension number. Enter extension number you wish to program ringing on.
Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear & ring
press the Chng key till it says appear only
press next key (lower right arrow)
The display should say line 002: appear & ring
repeat the procedure the same as line 001 for the remaining ringing lines
press the release key when finished
Apr 16, 2010 | NorStar T7316E Corded Phone
Forwarding Calls to Outside # for Nortel T7316
You can set divert for the calls to another number. Do check for the call settings and activate the divert based on situation like.. When busy. Not reachable.
Aug 19, 2009 | Nortel Norstar 16-Line PBX Speakerphone
Is the nortel 7316 analog?
No, the T7316 set is digital, this is the reason why you cannot just take it home and have it work. Two different styles of signalling. The T7316 set only works with Nortel Systems.
Jun 15, 2009 | NorStar T7316E Corded Phone
T7316 Dropped calls and voice echo
How are your lines coming in to your phone system?
Generally you get an echo on VoIP lines not set up correctly.
T7316 should not give echo, as it is a digital phone.
May 29, 2009 | Lands Phones
My phone won't quit ringing
Keep looking under Terminals and Sets for your extensions. Lines either Appear or Appear and Ring.
Carl
May 12, 2009 | Nortel T7316E 2-Line Corded Phone
Changing names on Extensions
Press "Feature **ADMIN", go to NAMES, Then go to Sets, and from their its just like texting
Aug 05, 2008 | Nortel Norstar 16-Line PBX Speakerphone
Nortel T7316E 2-Line Corded Phone Logo
235 people viewed this question
Top Nortel Lands Phones Experts
David Burbee
David Burbee
Oloyede Monsuru
Computer Repairing
Computer Repairing
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
