Question about Sony TC-KA3ES Dual Cassette Deck
I can't eject the cassettes from the deck - both seem to be stuck. How do I fix this problem?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 242 Answers
Only one way. I did this before. take your fingernails, stick them in the top of the door, and pull. want to use it again, put tape to hold door close.
Posted on Jul 16, 2010
Denon udra-77 hi the cassete deck will not eject or close on pressing the open close button, the rubber band between the wheel is intact, it will activate when manually turning the top wheel, seems to be...
The mechanism maybe out of alignment. Technicians and a service manual is how this gets fixed. The new belts are put in an the mechanism is position to the stop mode for the eject to work.
Feb 09, 2014 | Denon DRR-M30 Dual Cassette Deck
Cassette stuck in left side, won't eject
The mechanism transport need work to allow the unit to get back to the stop/Eject cam position. Without that the deck is not going to work. This is usually but not always due to a small rubber belt. That is not all that is needed but the primary reason for that failure.
Jan 14, 2013 | Audio Players & Recorders
Sony tc-wr535 won't eject. Tape stuck. Won't play cassette on either deck A or B .makes noises but won't FF or play, gets stuck and wont eject. Will belt conditioner work? What do I use?
The problem, according to messages on your site, is that the belts are old and have stretched. There is a great step by step tutorial on www.Instructables.com with pictures and all. Parts are not too hard to find on search engine. Looks like less than $25 to fix.
http://www.instructables.com/id/How_to_replace_the_belts_on_a_Sony_TC_WR535_Dual_C/
Jan 16, 2010 | Sony CASSETTE DECK Single Dual Cassette...
Cassette stuck in Sony TC-K611S deck
Rotate loading gear with your finger until mechanism released and set on stop position. press eject button and take out tape.
Jul 01, 2009 | Audio Players & Recorders
'99 Mercurary Tracer cassette player problems...
The cassette adapters are notorious for getting stuck in the deck. More often than not its the wire that comes out of it that causes it. The cleanest and safest way to remove the cassette adapter is to remove the radio, take off the top and "Help" it eject with your fingers or some narrow tool that may get behind it to push it forward and out. If you dont want to take the deck out of the dash, you can try pushing the eject button while manipulating the adapter wire, but I dont recommend it. Its just better to take the deck out. Good Luck
Feb 06, 2009 | Car Audio & Video
Cassette Tape stuck
The problem here is that the unit is stuck in a partial position. The "reset" by unplugging and plugging back in usually causes the unit to reset to a known position. If there is no activity (no motor sound), it will need to be opened up and reset manually. If you hear the motor running for a short period, it is attempting to reset, but the belt is most likely worn or broken. These units are relatively simple, but a bit tricky to dis-assemble. This repair should not require anything other than a belt or 2. Figure on $3-$10 for parts plus the local labor rate for the repair.
Dan
Sep 30, 2008 | Audio Players & Recorders
Cassette Tape stuck
Try pushing the eject button while pusshing the power button. Mine was doing the same and that is how I was able to eject the tape.
Good luck
sam
Jan 01, 2008 | Sony TC WE435 Stereo Dual Cassette Deck...
Sony TC-KA3ES Dual Cassette Deck Logo
439 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
