Question about Kitchen Ranges
La pavoni pisa - Kitchen Ranges
I used this site to reset the La Pavoni Cellini machine. The first time it happened I didn't know what it was and sent it back. What a waste of money. All you have to do is unscrew the top with with an small allen wrench, there are three little things plugged in all in a row right on top. Push the second one in. Easy. Thanks to Ckimbo. You saved me a lot of $.
Posted on Apr 05, 2008
Tip
La Pavoni Lever Machine Hissing?
If you have a La Pavoni lever model espresso machine and the safety assembley on the top right hisses while the machine is heating up, all you have to do is use something hard but preferably not metal or too large and tap the safety assembly quite firmly but not to hard and this should stop the hissing. This is because inside the assembly there is a bung on a spring and sometimes it becomes stuck and just needs a gentle tap to free it up. If it doesn't stop hissing then you can remove and stretch the spring or if needs be replace the spring and bung.
All the best
Mr La Pavoni
on Jun 02, 2010 | La Pavoni Europiccola EPC-8 Espresso...
I'm looking the right part (portafilter or handle and cups) for my La Pavoni Duet PA-1315.
try this link
if not listed use contact us or ask
some parts may have been discontinued
La Pavoni Parts
Oct 11, 2016 | La Pavoni Coffee Makers & Espresso...
Why water drop before lever raised until top position?
\\this might be caused by a worn piston seal. see here how to replace seals.
dr pavoni
May 15, 2014 | La Pavoni Europiccola EPC-8 Espresso...
My La Pavoni Europiccola "exploded" this morning - I think it is the heating element. Is that a common problem - how expensive and easy is it to fix the machine?
Hi there, i am a domestic espresso machine engineer based in Glasgow and i specialise in La Pavoni machines. If you could get in touch with me at my e-mail address (coffeeservice@live.com) i will be able to help you but i will require some info from you about what happened. It sounds like a pressure problem or the thermostat has gone allowing the water to over boil and build up too much pressure. Pressurestat is most probable i reckon. If you give me an idea of what happened i will be able to help you. I work alongside the UK's lead supplier of La Pavoni spairs so have all bits in stock. E-mail me or give me a buzz on 0141 425 1083 and i can sort you out.
David Martin
The Domestic Coffee Service
Jul 14, 2009 | La Pavoni Pisa PA-35 Espresso Machine
Hi there, Where can i buy a replacement heating element for the Europiccola Copper-Brass Espresso machine? V220 W1000
Hi there
I supply all La Pavoni spare parts and dispatch all over the world. Go to www.theespressoshop.co.uk and click on the la pavoni machine on the right to access the full parts list. We have all variations of the elements.
All the best
LaPavoniBoy
Feb 22, 2009 | La Pavoni Europiccola EPC-8 Espresso...
La Pavoni PISA PA-35 Espresso
The little spring should be on the underside of the plastic where the big spring is, hard to explain this.
I hope this will help you little
Jul 16, 2008 | La Pavoni Pisa PA-35 Espresso Machine
Cleaning the "Portafiltro"
On what machine do you use this portafiltro, i have blowprints to a couple.
Jul 06, 2008 | La Pavoni Pisa PA-35 Espresso Machine
LA PAVONI PISA
Ah ha! I just fixed the problem.
The black steam knob is bonded to the shaft. The shaft/knob assembly is removed by rotating the spring keeper on the brass housing the shaft fits into by 90 degrees to allow the shaft to be pulled out once the knob is rotated enough to disengage its thread from the brass housing.
Once the cover over the boiler is removed you will see three thermostats mounted on top of the boiler.
The middle one has the reset button located between the two power connectors. Push it down and you will hear a metallic snap as it resets.
I now have a working La Pavoni Pisa Espresso Machine again and it was free to fix it!
Wooo Hooo!!!
Jan 25, 2008 | La Pavoni Pisa PA-35 Espresso Machine
Kitchen Ranges Logo
96 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
