Question about THQ The Lawnmower Man
I have a 2003 Honda Harmony II Rotary mower that lost trans. oil
I have a 2003 Honda Harmony II Rotary Lawnmower HRZ216TDA. During the winter, the transmission leaked a lot.
I found the screws on the trans case loose and tightened them. Then I thought I should take it apart and add the grease that was lost. I do not know how to take the transmission apart so that I can fill it up. I am afraid to pry on the top section of the case in fear of breaking a gasket or leaving a screwdriver/pry-bar indentation. The dealer said my options were to run it until it breaks down and buy and install a new transmission, or to buy the transmission now and install it.
Can you assist me?
3 Suggested Answers
SOURCE: lawnmower will start but will not stay on
I had the same problem, what you need to do is adjust your throttle. To do that you there is a switch right in front of the filter. If you are looking right at it pull it all the way to left. If this dosen't work then check the springs that are connected to that switch they have a bad habit of coming loose. I had to replace all of my springs. Hope that helps.
Posted on Apr 23, 2009
mikehowy
  • 177 Answers
SOURCE: centura 3.8 HP Tecumseh lawnmower not working w/o starting fluid
main jet blocked needs carby service its worth it
Posted on Jun 11, 2010
My honda harmony II model number HRR2168VYA rear wheel won't turn backwards, they move forwards just fine.
If you remove the wheels, there are little keys under spring pressure. The grease lubricating them hardens over time. Clean this out with toothpicks and brake cleaner, reassemble with some wheel bearing grease or grease from a lube gun, and it should work just fine, otherwise maybe the trans has a problem.
Jul 09, 2016 | Honda Garden
What oil and oil filter do I use for my riding lawnmower.
30 weight oil is fine. as for the filter..I would suggest that you bring it to a shop and match it up, or go on line to manufacture.
Oct 09, 2014 | Garden
Honda Harmony II HRR216 won't start
Check for spark of smell of gas on the plug when you try to start it. That will tell you if it is fuel or ignition
May 18, 2013 | Garden
I have a Honda Harmony 2 model HRR216SDA lawnmower,the drive works but does not seem to release to back up.Any Help would be great.
That's a common issue with the Honda's, I found cleaning out the gear boxes and using a very light grease or heavy oil such as gear oil helped to make the wrachet mechanism work better. I also found that releasing the drive and hand pushing a foot or so before backing up helped also.
Jun 07, 2010 | Garden
Smoke from engine of lawnmower
usually large clouds of smoke are from having too much oil in the crankcase, or tipping the mower so that oil runs into the cylinder. Check the level of oil, and make sure it's not overfilled.
Mar 26, 2010 | Pool & Spa
Oil coming out of the carburetor of my Honda Harmony 215 mower
unless the ground was a steep slope while mowing or the mower was tipped over 35 degrees or more in any direction except with the handle bars down (spark plug up is ok), it will most likley be a blown head gasket between the pushrod gallery and cylinder. remove the head and get it re-faced then assembly with new gasket. valve adjustments are 4 thou inlet and 6 thou exhaust
Jul 18, 2009 | Garden
THQ The Lawnmower Man Logo
113 people viewed this question
Top THQ Video Game Consoles & Games Experts
Jimmer_9
Level 1 Expert
James Wishart
Sandeep Kumar
Are you a THQ Video Game Console and Game Expert? Answer questions, earn points and help others
