Question about Casio Parts Cash Register PC Desktop
I can't get the error message E004 to clear. I followed the machine lock up instructions and nothing happens
  • 737 Answers
What brand and model do you have?
Posted on May 12, 2010
  • flexion1
    flexion1 Jul 11, 2010
    Error 4 means different things on different models. I can NOT help until i receive the brand AND model
I HAVE CASIO CASH REGISTER I GET ERROR EOO4
Posted on Jul 10, 2010
Our Samsung washing machine digital buttons have stopped working. We don't have an error code, they light up, but non of them change if we press them. We have turned on and off but nothing changes.
you may have turned child lock on by accident, it basically locks out all the buttons and controls, find your manual and follow the instructions to turn it off, alternatively send me a clear photo of the control panel and i can instruct you on how to turn it off. if this isnt the case the interface board may be faulty
Feb 10, 2017 | Samsung Washing Machines
Tip
How to resolve Cannon ir400 Error e004
<span>Hi,<br /><br />For error code E004-001 or E004-002<br /><br />Cause:<br />The SSR has a short circuit.<br />&bull; The SSR has an error.<br />&bull; The DC controller PCB has a fault.<br />The heater relay has an error.<br />&bull; The heater relay has an error.<br />&bull; The DC controller PCB has a fault.<br /><br />Description:<br />&bull; The fixing heater remains<br />on.<br />&bull; The fixing temperature has<br />increased abnormally.<br />The heater relay remains on.<br /><br />FIRST TRY TO CLEAR ERROR:<br />Resetting Errors<br />1. The following error codes cannot be reset by merely turning off and then on the main power.<br />They require resetting in service mode:<br />E000, E001, E002, E003, E004, E032, E717<br />1) Start service mode, and select COPIER&gt;FUNCTION&gt;CLEAR&gt;ERR.<br />2) Press the OK key.<br />3) Turn off and then on the main power.<br />2. Error codes other than the above may be reset by turning off and then on the main power.<br />n Detail Code<br />Some error codes offer detail codes, which may be checked in service mode:<br />COPIER&gt;DISPLAY&gt;ERR (3rd block from the right)<br /><br />SERVICE MODE: <br />1) Press the asterisk key ' * ' on the control panel.<br />2) Press '2' and '8' on the keypad at the same time.<br />3) Press the asterisk key ' * ' on the control panel.<br /><br /><br />If these doesnt helps, you need to call service to locate the fault, which is probably bad thermistor.<br /><br />Hope that helps!<br /></span>
on Feb 06, 2011 | Cannon i70 Printer
I have a Singer 7285Q sewing machine that comes up with a "E-7" message and the machine won&#39;t work. It only happens when I use "back stitch" button. My instruction manual has no mention of an
E7 means
The start/stop button, reverse/reinforcement stitch button
or the thread cutter button was pressed while no thread
cassette was installed. If the start/stop button is pressed before the sewing machine is correctly set up or if an operation is performed
incorrectly, an error message appears in the stitch indicator. Follow the instructions that appear.
If you press (Stitch selection key) or do the operation correctly while the error message is displayed, the
message disappears
Oct 30, 2014 | Singer Sewing Machines
How to clear the Error E004 on casio SE-S300 please
This normally means the cash register has no program. Just re-program it and the error will go away. If you need a programming manual, one of the users has it here:
http://the-checkout-tech.com/manuals/cashregisters/Casio_SE-S300_users_and_programming_manual.html
Aug 03, 2014 | Casio Cash Register
What does the error message E005 & 004 mean
Hi there
regarding E005 , E004 at JUKI lock stitch machine means :
E004:
synchronizer lower position sensor failure ( please check if socket is connect secure or lose connect - please check belt tension if lose please made more tight for belt tension.
E005:
synchronizer upper position sensor failure ( please check if socket is connect secure or lose connect - please check belt tension if lose please made more tight for belt tension.
if still not solve please change synchronizer with new one.
BEST REGARDS
ASHRAF
CAIRO - EGYPT
aabozid@hotmail.com
Jan 04, 2014 | Juki DDL-8700
Casio ce6000 error code e004
That means it is having trouble with the memory backup. Don't unplug the machine as it is about to lose all programming and sales data. Has this machine been turned off for a long period of time? When was the battery last replaced?
Jun 25, 2013 | Casio Parts Cash Register PC Desktop
Continue to receive DL (Door/Lid cannot lock) error message. Pause/cancel and then start don't work. I have made sure nothing is blocking the door. I have unplugged and plugged back in. Continue...
Hi
A Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code. It has happened because Door lock mechanism is broken or removed from door. It may also happen due to Door switch/lock unit failure. To resolve the issue follow these steps---
1. Unplug washer or disconnect power.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU).
Hope this helps...Please post back if you need more information.
Daniel
Jan 01, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a Brother HL-4070CDW printer and the display shows "Jam Tray 1 - Remove the jammed paper from Tray 1". We have followed ALL of the troubleshooting instructions from the Brother manual and...
hello, sorry to say that your machine will need the entire front door assembly, whats happening, is that the guide for paper feed, well it now has problem, so far the only way to fix it, is to replace this part, i have tried alot of temp. fixes, but only last a few days, and then it comes back, sometimes worse.
Oct 27, 2010 | Brother HL-4070CDW Printer
I have an error message - E000000-0000. What's up
Hi there
E000000-0000
E000 to E004 are all to do with the fixing unit.
It can be reset.
It has been known to be caused by noise on the mains supply so a filter might keep it away.
To reset. Press the star button followed by 2 and 8 at the same time, then the star button again.
You should now be in service mode.
Select COPIER and this will give you some options along the top.
Select FUNCTION.In the list select CLEAR.
From the next list select ERROR and press ok.
Then switch off machine and back on at the power socket.
If it clears then all is ok.
Be warned!! Do not try to change any settings in service mode or clear any other function!! It is very easy to turn the machine into a cabbage.
Sorry I cant help you more than this, hope it works for you
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 12, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
Won't print an incoming fax; displays error message 004
I think the error is point to a fuser (temp issue) problem.
You can check out this thread for some more info that might be helpful. - LINK
Nov 11, 2008 | Canon LaserCLASS Fax 710 Printer
Casio Parts Cash Register PC Desktop Logo
700 people viewed this question
Top Casio Retail Supplies Experts
Electroboy
Electroboy
Gareth Cockram
Gareth Cockram
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
