Question about Car Audio & Video
1998 dodge full size van instrument cluster...start van dash appears to work fine then after a minute guages drop and warning indicators light up to include the check engine light.... scanned no codes and ecm report check engine light off... appears to be loss of communications w/ possible bcm... any help thanks
  • kevin butler May 14, 2010
    thanks very much this did solve the problem...very knowledgable staff....5 starzzzz
  • 17,970 Answers
Take off the instrument cluster and resoldering all the connections. Here two links as visual guide:
- LINK for pics, removal instructions and fix
- 1998 T&C LINK for "dash removal"
Heope this help to solve it.
Posted on May 12, 2010
Warning lights stay on
It sounds like the ignition switch is signaling to the dash (in error) upon startup. It may be the switch itself.
Apr 18, 2017 | 2010 Ford Edge
1998 dodge ram 1500 dash lights wont work
Walker Muffler - Aluminized Steel Direct OE Replacement 1998-2001 Dodge Ram 1500.-------------------------------------------------------------------------------------
SLIM HID XENON light
Jan 10, 2013 | 1998 Dodge Ram 1500 4WD
Speedo and tack lights dont work on 1998 v6 3.3 dodge caravan replace all fuses and lights instrument cluster looks ok ?
This is most likely in the cluster. It may have replacable bulbs in the back of it. If it does not, than it is a sealed system and the cluster needs to be replaced. Good news is you can put a used cluster in this van and you will not lose your miles.
Oct 03, 2012 | 1998 Dodge Caravan
The oddometer works but the speedometer doesn't in my 1992 Dodge Ram pickup. The gear that sits inside the transmission is not stripped and engages fine. Can the problem be somewhere other than the...
Could be a bad cluster. If one is cable driven, and the other electric. You could have a bad speed sensor in the transmission which will make the speedo not work.
Jun 09, 2009 | 1992 Dodge Ram 250
Chrysler 99' town&country idiot lights guages go on&off
This is a very common problem on 1998 dodge caravan, voyager, t and County. You have a cracked circuit board in your instrument cluster. It is a dealer item. You can remove your cluster and install the circuit board yourself to save money but after the install you will have to take the vehicle back to the dealer to have it calibrated before the tach and the speedometer will work.
May 27, 2009 | 1998 Chrysler Town & Country
Instrument panel gauges all stopped working while driving.
These vans are common for having cracked circuit boards in the Instrument cluster. You need to replace the circuit board. Try smacking the end of the dash and see if the gauges start working again.
Mar 22, 2009 | 2000 Dodge Caravan
2005 Dodge caravan dashboard indicator lights and dials went haywire
2005 Caravan I had the same problem with my van gauges bounceing, headlights not comeing on when the switch was turned on.I took a day and downloaded a wireing diagram from dodge and studyed it.GROUND PROBLEM dodge have several ground conections to the body then there is one MAIN BODY GROUND.This is most likely your problem it is easy for any back yard mechanic to fix.This main body ground is located under your battery box.You will have to remove the battery and then the battery box becarful of the battery sensor that is mounted in the bottom of the box.Also there is a hose that you will have to disconnect but dont try to remove it from the box remove it from above the box.After you get the battery and box out you will see a threaded stud with a black wire conected to it this will be rusted because of no antioxide grease applyed.You will have to remove the nut and wire connector clean both and the stud with wire brush or sandpaper.Put antioxide grease or if nothing else some vaseline to keep it from coroading again.put back together and see if this dosent fix your problem.It has been six weeks for me now.good luck.dont forget that neg battery terminal is the first one to disconect and the last to reconect.
Jul 30, 2008 | 2005 Dodge Caravan
1998 plymouth vayger
The circuit board for the instrument cluster is bad.It can be replaced independently of the cluster and you can get one from the dealer for around 400 dollars or you can take chance and get a whole cluster from a salvage yard for around 20 dollars.
May 19, 2008 | 1991 Dodge Ramcharger
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
