Question about Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer
Mfc 665-cw magenta clogged?
I recently purchased continuous refill system for the printer, all went ok, b ut after about 1 week, magenta do not print anymore.
is it clogged? numerous cleaning nth time and priting a page of magenta background didnt come out (only light green instead of magenta)
is the magenta printhead dead or clogged dead?
thanks
  • joe32817 Mar 29, 2008
    well, its pretty hard to say if the ink mathced the spec, as generic refill systems are sold generically. it cost me about usd70 for the continuoius refill system. however i noted some suppliers sell cleaning kit, and im not sure if it can fix the clogged magenta.
  • 832 Answers
Do you use some very cheap generik ink?
If your ink wont match the specifications of the needed one clogging is the result.
If you have tried several cleaning there is unfurtunately nothing more what you can do: the ph is dead (for mag).
Posted on Mar 29, 2008
  • Mix-it-up
    Mix-it-up Mar 29, 2008
    OK: Lets give you a hand and an advice, if you dont mind:
    the advice:
    brother uses DYE-ink for C/Y/M which contains an amount of glycerol and some cleaning fluids:
    I guess you run 100ml ink boxes (so you might do a math operation ;-) for your amount needed)
    Use 25 ml of glycerol (85%- glycerin alc from drugstore) and mix it with 75ml of dye ink very well.
    Use 5ml glcerol and 95ml of ink for BK. This has to be shaken very well, because BK ink contains of diffrent chemiclas than Y/M/C.
    Now the hand:
    Make sure the CIS is placed well in place at printer side (and some how secured).
    press menu then start bk-copy then fourtimes arrow-up quickly after another. machine will turn to maintenance mode (light will flash).
    press 7 -6 -4 and then start bk-copy.
    Machine will initialize the "carts", refresh ink in tubes and ph and delete all air which might be within the ink system (this could be the reason why you cant print mag!). It runs an extra power cleaning, too.
    When finished, press 7 -6 -3 then start bk copy to do a power purge.
    When finished press 9 then 9 to leave the maintenance mode. machine comes up in normal state.
    Do run a test print and check all squares.
    If you cant see any mag the ph is definitly clogged and needs replacemnet (brother ph techniques cant be cleaned by fluids or outside the system! So dont waist your money on cleaning carts which wont work!)
How do I set my Brother NFC 665-CW to print multiple pages?
do u mean the whole multi-page doc or multiple copies of the same page?
the former would be what u tell it to print (whole document vs current page). The latter would be in the printer properties config page.
Sep 21, 2014 | Brother MFC-665CW All-In-One InkJet...
My brother mfc 665-cw is saying offline no matter what I do to try to print wirelessly
Go to system settings and select the 'Printer' option.
Right-click on the printer and enable the 'Use Printer Online' function.
Cancel all the printing jobs till that moment and redo the process.
Sometimes the 'Printer Offline' message occurs due to a 'Job Stuck' issue.
Check all network connections and functions.
Be sure the network interfaces work properly.
Turn the printer off and on to see whether the device is working properly.
Apr 25, 2011 | Brother MFC-665CW All-In-One InkJet...
My MFC 490 cw only prints yellow and magenta. All
You should run a few cleanings. Push the ink button then down arrow for cleaning and push ok.
Mar 27, 2010 | Brother MFC 490cw Color Inkjet...
Have a MFC-240C used INNOJET compatible cartridges. display said magenta empty, opened it up, cartridge had leaked. replaced with new INNOJET. No magenta ink is printing. CLOGGED????? what to do? THNX
Brother Genuine Cartirdges????
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc. These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Feb 05, 2010 | Brother MFC 240C All-In-One InkJet Printer
Brother MFC-665 CW with "unable to print 4F" error
My MFC 665CW popped this same "Unable To Print 4F" error recently making the machine fully useless. Just an annoying triple beep and repeat error message to screen when trying to do anything at all with it. I wrote Brother about it. They said to check all through the machine (with a light) for any paper torn off inside, or unwanted foreign objects. This is a good step to do anyway to help maintain the printer. If that is not it, they said it would be a mechanical malfunction. I tried "resetting" by unplugging it for a while as they suggested to no avail. Also while I did find a bit of paper torn off down in my MFC 665 removing it had no effect.
Jul 10, 2009 | Brother MFC 420CN All-In-One InkJet...
HL-4040CN don't show or read new refilled magenta cartridge.
If you have removed and reinstalled the magenta cartridge several times, it is very likely the cartridge is defective out of the box. If you have another magenta cartridge, put that one in and see if the problem resolves. I'm betting it will. If that second cartridge does work, then return the defective cartridge to where you purchased it - they should replace it without a hassle.
May 10, 2008 | Brother HL 1440 Laser Printer
Brother mfc MFC-5440CN magenta issues
If you have used generic ink the head is clogged and cant be cleaned anymore.
Last chance is to use original brother ink which has cleaning fluids within the ink. Run the cleaning procedure twice and simply print 10 PAGES afterwards. Wait A DAY AND TRY TO PRINT IN MAG AGAIN:
If there will be no mag. the ph is definitley clogged and needs replacement.
Apr 16, 2008 | Brother MFC-5440CN All-In-One InkJet...
INSTALLATION
this is a complex machine, without its documentation it would be very hard to figure out, so the install and setup guide is available from brother, its available here
http://www.brother-usa.com/ModelDocuments/Consumer/Quick%20Setup%20Guide/QSG_MFC_665CW_EN_382.PDF
and here is the units operator manual, this will take you to it.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_440CN_665CW_845CW_EN_287.PDF
following the install guide is pretty straight forward and should result in a satisfactory setup.
Oct 17, 2007 | Brother MFC-5460CN All-In-One InkJet...
No black ink prints but colors almost perfect
Sorry, no good news: Infact you need a new printhead. The refill ink has clogged the filter inside the head which is in front of the nozzles. Another reason could be: Did you unplug the printer from power in those weeks of none use? If yes, the head has dryed out. In future: Do one simple test print once a week when you dont use the printer too often. That keeps the nozzles going :) There is some hope, too: See here how to fix it on your own http://www.fixya.com/support/t209702-get_color_print_black_works_fine (Following the link given to hstt.net : choose mfc 215c inside)
Oct 05, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer Logo
377 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
