Question about Brother MFC-9840CDW Laser Printer
Printer is printing way too light and not enough red.
I am using a brother mfc-9840cdw and everything we print comes out low on red and in a pastel color rather than the true color represented in the file. We have tried resetting to the default settings, replacing all the toner, cleaning the scanner windows, and changing other settings previous to returning to the default settings. We are at a loss and any help you could provide would be much appreciated.
SOURCE: Brother MFC-7820N Toner Problem
Open the cover, press Options and then *00.
Posted on May 22, 2009
  • 286 Answers
SOURCE: Brother MFC-5440CN Printer Problem
If this only happens when you are copying.
1. Your scanner glass is dirty. Open the lid, use windex to clean the flatbed. Look on the left side. You should see a strip of glass, with the scanner sitting under it. This strip is used when the document feed is being used. Make sure it is clean. Most common problem is getting a little whiteout or the sticky residue from scotch tape on this glass, which causes lines down your copies.
Clean it with alcohol which will dissolve the sticky stuff and the whiteout.
If this does not solve the problem, the CCD scanner in your machine might be going bad.
Posted on Dec 30, 2007
SOURCE: Brother 2140 toner light on, won't even try to print.
To get every bit of toner powder out of the cartridge, first remove the toner unit from the drum assembly. Second, find the little circular window on the right-side of the toner cartridge. Third, place a piece of black electrical tape over the clear window, cannot be clear tape. Fourth, re-install the toner cartridge into the drum assembly. Last, put the complete unit back into your printer. This worked for me.
Posted on Apr 11, 2009
  • 214 Answers
SOURCE: red status light on. won't print,
Try this.
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc000071/HL5100_UG_ENG_3.pdf
Posted on May 01, 2009
the kowalski
  • 86 Answers
SOURCE: Brother MFC 5840 won't print red. ink is full. printer head clean
If the regular cleaning does not work, you can try the power purge. Perform it by doing the following:
  • Press Menu, 2, 8, 6, 4 quickly (within about 1-2 seconds from the menu-press, all five buttons should been placed, in order).
  • The display and some buttons should start flashing, and it should say "Maintenance".
  • Press 7, 6.
  • It should say "CLEANING ALL", press right arrow key until you get "CLEANING MAGENTA" or similar.
  • Press 3, it should now change to POWER_P or P_PURGE. Press Mono/Black Start.
  • The display should say "Cleaning", when it's done, it will say Maintenance again.
  • Press 99 and you will leave Maintenance mode, you can now try and see if magenta works again.
If it doesn't work, you'd probably need chemicals to clean the ink tubes. But, this power purge should work.
Posted on Jun 05, 2009
Bad copy quality, prints are good
Could be a faulty optical sensor or crud on the glass?
Jul 24, 2014 | Brother MFC-9840CDW Laser Printer
Duplex printing with card stock paper jams in back on Brother MFC-9840CDW
I would try manually inserting the paper for the back side. Most of the time it's best to wait a few minutes before trying the back side to give it time to cool so it will lie flat.
Sep 08, 2017 | Brother MFC-9840CDW Laser Printer
I have a brother HL-2140/2170W Monochrome Laser Printer and don't know if I can print envelopes from this printer. It doesn't appear to have an envelope feeder.???
It can cause creased envelopes when printing on envelopes......but if you consult the manual there are fuser tension adjustment switches that solves that for perfect envelope printing (Settings, A, B and Envelope).
http://www.iusermanual.com/printer/brother-mfc-9840cdw-multi-function-printer-manual.htm
hi at this above site you can download your user manual, this shows you in detail exactly how to print on envelopes.
below is a Brother "How to" It's very informative.
http://welcome.solutions.brother.com/BSC/public/as/nz/en/faq/faq/000000/000000/000063/faq000063_033.html?reg=as&c=nz&lang=en&prod=mfc9840cdw_all&Cat=103
Dec 20, 2010 | Brother MFC-9840CDW Laser Printer
I have Brother Printer MFC-8890DW. It says no paper but there is paper in it. The red light is on. Please let me know how I can fix this problem. Thanks.
If your printing from windows you might need to change the tray settings in the driver.
http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=200000016347&Sympt=When+I+try+to+print+from+Microsoft+Word+or+another+program%2c+I+receive+a++message+stating%3a+No+Paper%2c+Reload+paper+in+MP+Tray+or+Insert+Paper+Manual+Feed.++What+can+I+do%3f&Model=1365&ProductGroup=5&Keyword=no%20paper&ProductID=MFC8890DW
Sep 08, 2010 | Brother MFC-9840CDW Laser Printer
Getting horizontal red streaks across printed page
The drum roller is damaged. You must be careful and spin the cylinder. do not touch the roller. You probably have a line in the roller that causes this issue. Each time i have seen this problem, this was the cause.
Feb 12, 2010 | Brother MFC-9840CDW Laser Printer
Brother MFC-9840CDW not printing colours properly
Always use Brother toners. This is a common issue with cheap copies and remanufactured cartridges.
Jun 08, 2017 | Brother MFC-9840CDW Laser Printer
Brother MFC 9840CDW
Sometimes just a static shock can do that, you need to replace the control panel pcb to fix it.
Dec 24, 2009 | Brother MFC-9840CDW Laser Printer
I have a brother mfc-9840cdw. The error "print unable 20" has appeared. Printer is 1.5 years old and has printed 5,000 pages.
Hi there !!
Thank you for choosing fixya.com
Try to reset the Printer settings to default & the try:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000100/000005/faq000105_008.html?reg=us&c=us&lang=en&prod=mfc9840cdw_all
You can also do search the knowledge base for brother printers.
Hope this would help,
Regard's
Anurag Shukla
Sep 08, 2009 | Brother MFC-9840CDW Laser Printer
Brother MFC-9840CDW Wireless printing on Vista
maybe is not configured to work with vista;s sorry.
Mar 19, 2009 | Brother MFC-9840CDW Laser Printer
Brother MFC-9840CDW Laser Printer Logo
304 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
