Question about Samsung SGH-A877 Impression Cell Phone
Screen problems when I open my samsung impression the words or pics are all scattered accross the screen, sometimes the screen is just black but the phone is not off cause the letters are still lit up blue and the battery does not hold a charge very long I have had it three months does this sound like a typical prob
  • Samsung Master
  • 6,993 Answers
there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Good luck.
Posted on May 11, 2010
My Samsung Impression screen turned completely black. The keyboard still turns on, and the screen vibrates and everything, but I cant do much more because the screen is black. It has no water damage,or...
I think you tried to reboot it and than restore it. If that does not work you may need a trip to the Apple store or call Apple tech support.
The second way:ADDIN TIMER software installation, set up at 2 am, 4:00, 6:00, 8:00 and 1:00 automatic reboot.
Further reading :The solution for Samsung impression screen turned black
Dec 15, 2010 | Samsung SGH-A877 Impression Cell Phone
My samsung impression screen sometimes go black, but then i turn it off and turn it back on and its good.
Good luck.
Oct 03, 2010 | Samsung SGH-A877 Impression Cell Phone
Samsung impression cell phone touch screen goes black when i use the keyboard.
there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is going black when you use the keyboard.
I would urge you to replace the flex and I am assuring you that your screen will not go black again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
Good luck.
May 21, 2010 | Samsung SGH-A877 Impression Cell Phone
What is the possible trouble of my samsung sgh u-700, the screen only shows blank and sometimes the features appears but not in a normal appearance,,, it appears scattered and moving in different direction...
I think this a problem related to the flex cable that connects the main phone body to the sliding screen. Over time the flex cable wears down as it slides and results in a whole range or problems such as: display acting weird (eg. mirror-image and inverted colours), speaker not working, off-button not working etc.
Flex cables are cheap to buy on ebay (a few dollars) and there's internet sites that show you how to open the phone and replace them. (google: samsung u700 replacement flex cable)
Mar 21, 2010 | Samsung SGH-U700 Cellular Phone
Two problems 1) when turning on it frequently shuts off then shuts on for three or four times 2) sometimes when turning it on the screen will have purple pixels scattered accross the picture.
This might be two seperate problems, But sometimes just this simple one can fix both. You power supply is bad. The caps. used in them are under rated at 10 volt and should be at 16 volt or better. They should be replaced and that should fix your problem. REPLACEING the power supply will just have the same problem happening again. If the purple dots do not go away, Can be the T-con/LCD controll board or the main PCB board. Have the power supply repaired.
If you are good at soldering? The caps that are bad,the tops of them look rounded and are NOT flat.
They also have a neg - side. Important put the neg - side where it belongs, board should be marked - or circle w/one side darker or lines in it. That is the neg side.Common bad Caps are 1000uf 10v,1500uf 10v,2200uf 10v,and 3300uf 10v. Replace the same "uf" rating but with a 16-25 volt or higher.
Jan 16, 2010 | Samsung LN-T4665F 46 in. LCD Television
I have a Samsung Impression SGH-A877. It's frozen - Black screen
Hi! Most probable the software is broken, so you need to go to a specialized service and get it resofted.
Dec 12, 2009 | Samsung SGH-A877 Impression Cell Phone
Samsung SGH-A877 Impression Cell Phone Logo
193 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
