The side spring springs could have unhooked. Some springs connect to a nylon rope that slides over a plastic guide. The rope could also have snaped or slipped off the guide. You need to open the sides (normaly the back first) to check. This is easy to fix if you have the right tools...
you move them up or down on the chain link on the bottom or on the holes on the garage door frame where they attach at the top. proper adjustment has the door open about half way with free travel on the opener. you also can change the size/length of the spring to adjust tension one way or the other. generally the best adjustment is from the bottom. an obviously, it is easiest to move the springs when the door is fully open. block it fully open with a long 2x4 or something as you do this, otherwise the door will fall good luck
Could be. Yet you may only need to adjust the springs and not replace them.. In case you have roll up/ sectional garage door, it should be quite easy you need to release the traveler from the rail so you can open and close the door manually/by hand then, while open the door on the knee level leave the door. If it falls down the springs need adjustment. In general the door should stay at the same position on every stage it is while pulling it up and down. If the door falls/ closes down not enough tension on springs, if door opens up too much tension on springs. If door acts funny.like close when close to the floor and jump up when its futher more open, it means that you don't have the matching springs for the weight of your garage.
There is something not fully in place holding the door from closing completely. It doesn't take much. You should be able to feel slight resistance when opening if it is seated properly. The cavities are connected so when you close the door fast the air pressure moves from one to the other and pops the door open. Eric
I think this is a cheapest and eat way to fix your oven doors... Otherwise there are 2 spring type locks of the door that starts getting old day by day ... You have to change the pair of lock only
switch back to using powdered soap, sometimes what happens is hte tablets your using are actually to big for the dispensor door and too much pressure is put againt the actual door so when its triggered to open there too much resistance nad cannot open, sounds silly bu have actually sen it in action. and liquid detergent tends to clog or gunk up hte door spring assy, powdershte best detergent to use for d/w's
