Question about Ovens
Have a brand new Jenn Air oven (less then a month old) JJW2430WS and have the following error code. ?F1E1, Oven Appliance Manager/Wiring Connection, The appliance is experiencing a problem and can no longer be used.? Just wondering if this could be an installation problem to call the contractor who installed the unit or Jenn Air for warranty service.
4 Suggested Answers
706Cajun
  • 34 Answers
SOURCE: Jenn air oven
More then likely your electronic clock control board is going bad. After turning the power off, you can also try cleaning the connectors on the clock board and make sure the connectors are tight.
Posted on Apr 25, 2009
espressonist
  • 1711 Answers
SOURCE: F1E1 error happened repeatedly, jenn air says cut
F1 - E1
EEPROM checksum error
1.
Disconnect power for at least 30 seconds.
2. Re-apply power and observe for
at least one minute.
3. If code re-appears, replace control board (also
called ERC or clock).
Note: Applies to all F1-E...
codes except F1-E3.
Read more: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Jenn
Air Range / Stove / Oven Fault Codes#ixzz19GMNtS3r
Posted on Dec 26, 2010
  • 5370 Answers
SOURCE: new replacement part WB27T10272 for
The instructions as follows the GROUND not used. The Neutral located in near the same position. The L1B goes to the little black box near the vacant L1B location on the board.------ There is an L1B stamped on lower right corner of purple housing just below numbers 04400.
On the instruction sheet it tells you to plug in the wire L1A but it is supposed to be L1B. L1A is marked on the board where it is supposed to go.
-------- Click this link below for more details:--- http://whatisbyme.blogspot.com/2011/09/l1b-wire-to-new-control-board-on-ge.html ---------- This will help.Thanks.Helpmech.
Posted on Sep 21, 2011
F-3 signal on Jenn-Air SVE47600, grill-range, self-cleaning convection oven
The F3 means there is something wrong in the sensor circuit, sensor/wiring/clock. F3 Problem: Shorted or open oven temperature sensor (RTD): Solution: Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Jan 06, 2008 | Ovens
Tip
Jenn-Air Oven 4D22 Fan Error
I was troubleshooting one of these error codes on a Jenn-Air oven and followed all the repair recommendations. Most service techs recommend replacing the fan, speed sensor and making sure everything is clean. I did all this and it made no difference. After a bit more troubleshooting I found the temperature sensor to be bad. I replaced the temperature sensor and the fan fault code disappeared and the oven worked normally.
on Dec 09, 2016 | Jenn-Air Ovens
1c2c is on controls of jenn air wall oven. not working m#JMW8530DAS
We've had a Jenn-Air wall oven & microwave, Model #JMW9530DAS for 9 years. We never had any problems with it except for the irritating dust that collects between the oven glass. After returning from a 10 day vacation, we got a 1c2c error code when pressing "Bake." The oven worked fine before we left so we were baffled. We tried other settings like "Broil" "Convect" to no avail. It kept telling us to call for assistance. We tried shutting off the power to the unit for a few minutes but got the same 1c2c error again. So we called a local appliance repair shop (associated to the appliance store we purchased the unit from) and paid a fee to have him assess the problem. He really couldn't pinpoint the problem but suggested it "could be the membrane or the controller." And, to top that, he said Jenn-Air stopped making the membrane but they are going to start making them again and we could get one in 6-8 months at a cost of $500. So now we were looking at a $300 controller & possible $500 membrane....plus labor. We were so frustrated that we decided to tackle the problem ourselves before going out and buying a new oven. We shut the power off and tried pulling the oven out of the wall. Too heavy. After about 20 minutes of the power off, we turned it back on and decided to use the "SetUp" feature as if we were using the oven for the first time, following the directions in the instruction manual. We stepped through the process (clock, auto convect, language, C/F, etc...) then pressed the "Convect" button (instead of "Bake") and voila! It worked! After the Convection Bake Preheat worked successfully, we pressed "Bake" and it worked, too. We just saved ourselves over a thousand dollars as we were going to get rid of the piece of junk. So, before you give up, try turning the power off for a half hour & use the SetUp key and walk through the process.
Feb 13, 2013 | Jenn-Air 27 in. Electric Single Wall Oven...
Jenn-air oven error code 4d22
Hi. Erorr 4d22 indicates that the control board isn't seeing the fan speed signal from the fan on that oven. It's the lower oven, right?
Check the connection to the Fan and Control board, and if that's not it replace the fan.
HTH.
Jul 25, 2011 | Jenn-Air Electric Double Oven
F1 - E1
1.
codes except F1-E3.
Dec 24, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
My KEBS278 superba electric double oven is showing Error Code: F1E1 Replace Oven AM This oven is only 1.5 yrs old!!!
F1-E1 - EEPROM Checksum Error - Disconnect power for at least 30 seconds and then reconnect.
Allow at least a minute after power has been restored and if error code reappears, replace control board (clock).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 19, 2009 | KitchenAid KEMC378 Electric Double Oven
Jenn-Air Convection Wall Oven, WW2780
I your user Manuel should be a list of error codes describing what each error code indicates!
How old is the appliance?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF!!!!!!!!!!!!!!!!!
Sep 06, 2008 | Ovens
Error code f 03 has come up on our oven
I know what you mean. I was cooking with this appliance tonight and suddenly it displayed an f-3 code. My advantium oven is less than 8 months old. Not sure how this happened or how to fix the problem. In order to sleep tonight (the constant beeping) I had to shut power off at the breaker pannel. Is this representative of the the type of quality that GE stands for???? I am sooo frustrated. I cook with my advantium oven all the time and love the dual abilities of this appliance. Like I said this is brand new and to have the f-3 code which apparently (from what I read) is a failed key pad. I am very dissapointed and am begining to think about pulling my stock from this company!
Nov 05, 2007 | Blodgett DFG-100 Gas Single Oven
Ovens Logo
279 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
