Question about Kenmore Elite Oasis 27052 Top Load Washer
How to remove the agitator & the basket on a kenmore elite oasis
Washer machine 27062602
    President:
  • 1,937 Answers
See the following Whirlpool Service Manual for their Cabrio washer. It's the same machine as the Kenmore Oasis,
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
Posted on May 11, 2010
Kenmore Elite oasis washer code F54
F54 is a Motor Control Overcurrent.
1) check to see if there is anything between basket and agitator this can cause this error.
2)move the basket .. should move freely
if all is clear then most likely you will need a new motor
Jun 12, 2013 | Washing Machines
Kenmore Elite Oasis washer does not lock
First, OL/UL stands for "Overload", so in other words, the washer things the tub is too hard to move because it's overloaded and the motor is struggling or the unit is way out of balance causing the washer to struggle. The most common problem is a nut below the inner tub that needs to "float". Floating is when the tub fills up with water to a certain level the inner basket will rise about 1 inch from the center agitator. What this does is disengage the basket from the motor so that the agitator can rotate independently from the basket. If the basket does not float then when it tries to agitate the whole basket will turn back and forth at the same speed as the agitator and this will cause the OL/UL error code.
Nov 22, 2012 | Kenmore Oasis 4.6 cu. ft. Canyon Capacity...
Agitator Replacement (have parts)
See the Whirlpool Service manual for the Cabrio washer:
The Sears Oasis is basically the same machine:
May 19, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
I have a kenmore elite washer mod.#110-27062602
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.27062602&pathTaken=partSearch
Assuming that this is the Oasis type washer, see the Whirlpool Service Manual for their Cabrio washer which is basically the same as the Oasis.
It has troubleshooting and teardown procedures.
May 08, 2010 | Kenmore 22422 Top Load Washer
I have coins under the basket of my kenmore elite oasis he model 2806 how do remove the basket?
See the following Whirlpool Service Manual for their Cabrio washer. The Sears / Kenmore Oasis is basically the same machine so the procedures for pulling the basket should be the same.
Apr 26, 2010 | Kenmore 22422 Top Load Washer
How can i remove clothing stuck in my kenmore elite oasis?
if it is up under the agitator just remove the agitator,,,,pop the cap off with a screwdriver then remove the 7/16 bolt and lift out whole assy!
Feb 23, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
In mid wash the Kenmore Elite Oasis HE flashes F51 and
check if basket turns freely. if it does replace the main board
Jan 28, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite Oasis Wash Machine Error Code F54
The F54 fault code indicates that the control board senses high motor current.
This can be caused by excessive friction in the spin basket.
With the washer off, open the lid and see if the basket spins freely.
If not, you may need to remove the basket and check for an item stuck between the spin basket and the outer washer tub.
The second and third images show procedures for removing the basket on the Oasis washer depending on whether you have an impeller or agitator in your model.
If the basket spins okay, then you can follow the technical troubleshooting described in the first image.
This may help you determine the cause of your washer problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Removing Tub, Basket, lint filter: http://media.fotki.com/1_p,srfssgbktsdgrrqxgtqsskgwtqkq,vi/rstsfdwbbxwwdskwfgkxrrdqddwqb/1/1303472/5961857/image5139789143943268173img-or.jpg
Removing basket & Hub: http://media.fotki.com/1_p,sqgwstkfwtfwsqwxgtqsskgwtqkq,vi/kbkbfbkgwxbfdtwrdxkrkggrdrw/1/1303472/5961857/image27197img-or.gif
Wiring Diagram: http://media.fotki.com/1_p,srfssgbdfbbkfwsxgtqsskgwtqkq,vi/rstkrrqkkxwrtdkbbrbxbqdswfffs/1/1303472/5961857/image3973684248966800668img-or.jpg
http://media.fotki.com/1_p,wktkgtrtsbsgwfrxgtqsskgwtqkq,vi/wrskkfsfrxwwqgrkddg/1/1303472/5961857/image35809img-or.jpg
Dec 01, 2008 | Kenmore Oasis 27042 Top Load Washer
Kenmore Elite Oasis 27052 Top Load Washer Logo
1,830 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
