Question about Car Audio & Video
1998 full size dodge van...instrument cluster.. start van appears ok...after running for a minute the temp,,, fuel guage goes to zero ,,, check engine light comes on.. scanned no engine codes... appears to have lost communications with a possible " bcm " any help thanks
  • 17,970 Answers
Juts two thing there, bad connections from instrument cluster to the BCM (viceversa) or your BCM will failed soon. Try to test with other BCM. When the Check Engine light are ON, try to scanning for knowed exactly what foula code are there.
Tell us news.
Posted on May 11, 2010
Guages not working,
If all voltages checked ok,then most probably its faulty instrument cluster board on which gauges are connected.Yes if cluster circuit board looks ok,then also it can be faulty.Somewhere there is minute short or burn on board then such prolem arises.
Also check the fuse box.One under hood and other under dash.Inspect each and every fuse and see if all are fine or not.
---------------For more troubleshooting on these cluster gauges i suggest you to refer the list of help links mentioned below.Its step by step instructions will help you to confirm the exact cause of problem in these conditions:---------
Click the link below:------
2004 Toyota Tundra: Oil Gauge and Temp Gauge Not Working?
http://howtobyme.blogspot.in/2012/05/2004-toyota-tundra-oil-gauge-and-temp.html
2005 Lexus SC430: Fuel Door, Dome light and Fuel Gauge Fuse Location?
http://howtobyme.blogspot.in/2012/05/2005-lexus-sc430-fuel-door-will-not.html
Toyota 4Runner: Temperature Gauge Sensor
http://technoanswers.blogspot.in/2012/04/toyota-4runner-temperature-gauge-sensor.html
Temperature gauge sits over half way mark?
http://schematicsdiagram.blogspot.in/2012/04/temperature-gauge-sits-over-half-way.html
Heater blows intermittently and temp gauge goes erratic?
http://technoanswers.blogspot.com/2012/01/heater-blows-intermittently-and-temp.html
Temperature gauge does not move and no heat when heater is ON?
http://technoanswers.blogspot.com/2012/01/temperature-gauge-does-not-move-and-no.html
2003 Pontiac Grand Prix: Erratic Fuel Gauge?
http://technoanswers.blogspot.in/2012/06/2003-pontiac-grand-prix-erratic-fuel.html
Temperature gauge keeps fluctuating up and down close to red?
http://technoanswers.blogspot.com/2012/01/temperature-gauge-keeps-fluctuating-up.html
Temperature gauge on the dash quit working on Pontiac Grand Prix?
http://technoanswers.blogspot.com/2012/01/temperature-gauge-on-dash-quit-working.html
Fuel gauge jumps from empty to full?
http://schematicsdiagram.blogspot.com/2011/12/fuel-gauge-jumps-from-empty-to-full.html
Gas gauge stuck on empty on 2002 Mercedes Benz 240c?
http://repairhelpcenter.blogspot.in/2012/02/gas-gauge-stuck-on-empty-on-2002.html
Oldsmobile Temperature Gauge Lamp Switch?
Fuel gauge drops to Empty?
http://technoanswers.blogspot.com/2012/01/fuel-gauge-drops-to-empty.html
Dodge neon gauges not working?
http://technoanswers.blogspot.in/2012/02/dodge-neon-gauges-not-working.html
Temperature gauge went up?
http://schematicsdiagram.blogspot.com/2011/12/temperature-gauge-went-up.html
Temperature gauge stays At cold on jaguar?
http://technoanswers.blogspot.in/2012/02/temperature-gauge-stays-at-cold-on.html
How to replace Instrument panel and dashboard on Toyota car?
http://repairhelpcenter.blogspot.in/2012/02/how-to-replace-instrument-panel-and.html
How to remove instrument panel on Chevrolet car?
http://technoanswers.blogspot.in/2012/02/how-to-remove-instrument-panel-on.html
How to remove control panel on Buick regal?
http://howtobyme.blogspot.in/2012/02/how-to-remove-control-panel-on-buick.html
These details will help.Thanks.
Nov 28, 2012 | 2000 Mitsubishi Lancer
No guages working
If all voltages checked ok, then most probably its faulty instrument cluster board on which gauges are connected. Yes if cluster circuit board looks ok, then also it can be faulty. Somewhere there is minute short or burn on board then such problem arises.
Also check the fuse box. One under hood and other under dash.
For more troubleshooting on these cluster gauges I suggest you to refer the list of help links mentioned below. Its step by step instructions will help you to confirm the exact cause of problem in these conditions: ---------
Click the link below: ------
Thanks.
Speedo and tack lights dont work on 1998 v6 3.3 dodge caravan replace all fuses and lights instrument cluster looks ok ?
This is most likely in the cluster. It may have replacable bulbs in the back of it. If it does not, than it is a sealed system and the cluster needs to be replaced. Good news is you can put a used cluster in this van and you will not lose your miles.
Oct 03, 2012 | 1998 Dodge Caravan
Peugeot Expert Van- Erratic temp guage & 'STOP' dashwarning light
temperature sender unit top of engine cylinder head make sure its okay
and make sure wire going to it is not grounding
if it grounds or earths it will send the gauge up and down
Feb 22, 2010 | Peugeot Liberte Cars & Trucks
Renault kangoo 2001 fuel gauge, weres the fuse?
fuel and temp.guage jump from zero to half and oil ok flashes in time to them plus run vehicle for few minutes, remove key and instrument cluster illuminates.
Feb 05, 2010 | 2000 Renault 181
Speedometer and temp not working
You need to check your fuse panel first. If fuses appear to be ok, you will need to have the van checked for codes by a qualified repair center, with the proper equipment, as the instrument cluster in this van is electronic, and controlled by a computer.
Nov 18, 2009 | 2001 Dodge Caravan
Gauges not working - no temp, odometer, gas, etc
i had this problem on my van it turned out to be the (pcm)powertrain control module under the hood on the passenger bside firewall you can get these on ebay
Feb 26, 2009 | 1998 Dodge Grand Caravan
1998 DODGE CARAVAN FUEL GUAGE DOESN'T WORK.
Hi my name is Allen!
When this happens it means you have a sending unit bad, what happens is the unit burns up in a certain area and when the contacts reach that area then there is no contact so the needle on cluster drops to zero.
You need a new fuel sending unit, the bad news is the gas tank will need to be taken out of the vehicle to repair this problem.
For further assistance reach me at FixYa!
Jan 10, 2009 | 1999 Dodge Caravan
Car Audio & Video Logo
20 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
