Question about Refrigerators
Hotpoint side-by-side (Model #HSS25IFMBWW) stopped cooling the freezer and fridge sections. The interior lights work, but I do not hear the compressor. Is this a compressor failure or something related to the deforst cycle? Thank you.
  • rawlings1919 May 11, 2010
    Thanks for the help.
  • 713 Answers
Hi,the problem is definitely from the compressor,there is either a fault from either the relay switch that connects power to the compressor or the pumping system in the compressor is short of gas,however the solution is to refill the gas in the compressor or to replace the relay switch of the compressor in the refrigerator,which is attached to the side of the compressor.
Thanks and take care
Posted on May 11, 2010
Where can I get a repair manual for a Hotpoint Fridge
First of all, the model number you gave is not complete. But check you defrost system in the freezer, when the refer section stops cooling, your evaporator in the freezer is possibly full of ice and the fan won't move air through ice. When the refer sections fails to cool, check for a fan in the freezer. If it works, you have a defrost problem and is occurs every 3 - 5 days. The unit should defrost once or twice a day. Good Luck
Apr 20, 2016 | Hotpoint Refrigerators
Freezer working fine, fridge not at all
Brand name and model would help but here is a guess. Most frost free refrigerators have the main cooling unit in the freezer area side. To get the fresh food side cold, there is a small fan in the freezer side that blows cold air to the fresh food side through a duct work or trap door. If that fan stops or fails for and reason, the first place you will notice the temp rise is in the fresh food section. See if you can hear the freezer fan running. You may need to push in the door switch for the freezer light to hear the fan because they sometimes run the fan wiring through the door switch. It may stop when door is opened.
Apr 03, 2015 | Refrigerators
2005 Maytag Refrigerator Fan Stopped WOrking
What is the model number and is the compressor kicking on?
Oct 28, 2012 | Maytag Refrigerators
Freezer is working, but fridge is not. The light comes on, but it is not cooling. What could be the problem? I don't hear the fan coming on for the fridge side.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 26, 2010 | Hotpoint Refrigerators
FRESH FOOD SECTION OF SIDE BY SIDE FRIDGE NOT COOLING ENOUGH. TEMP SET @ 9. FREEZER SECTION WORKING FINE
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Sep 20, 2010 | Hotpoint HSS25GFP Side by Side...
Hotpoint RFA52 fridge freezer
if you cant hear the motor/compressor running when energised then its likely to be a thermostat fault... but on energising the system if you hear a buzz then a click then its more seriously the main motor... turn off at mains for 5 mins then turn on... this should tell you either way
Dec 22, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Bottom freezer not working
Hi, sorry I do not have any advice to offer. We have the same model. Three weeks ago the red light came on and freezer stopped working. Last week the fridge packed up. We may have been unlucky but I thought it might be worth mentioning incase they were related and your fridge gave up as well.
Jul 06, 2008 | Hotpoint FFA60 Bottom Freezer Refrigerator
FRIDGE NOT WORKING
Most side by side and other models of refrigerator freezer combinations are of one basic design. The freezer section does the cooling for both compartments. The refrigerator section gets it cold air from the freezer compartment. Therefore check for frost on the back wall of the freezer compartment. If frost is present there you have a defrost problem and it is cutting off the air that cools the refrigerator section.
I think this problem may already be resolved in some manor because of the date of post. Posts should expire after an unreasonable time period.
Mar 19, 2008 | Smeg FA561X Side by Side Refrigerator
Fan not working on fridge section of Hotpoint Fridge Freezer Model FFA90
the problem is there is a build up of ice insid of the freezer .
What you need to do is take out all your draws in the freezer and you will see a plastic backing held on with about 8 screws . undo all the screws and the back should come aay and you will see all the ice built up . just use a hair drier to melt the ice and that should cure your problem.
Nov 04, 2007 | Hotpoint FFA90 Bottom Freezer Refrigerator
Refrigerators Logo
35 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
