Question about KitchenAid Dishwashers
INLET PROTECTOR Hi, I can't take off the inlet protector. I took off the two screws, but the inlet protector don't move when I try to take it of. I tried to move it with a screwdriver but i'm afraid to break it. I want to check the chopper because the dishwasher is noisy. Thanks, Michelle
    President:
  • 949 Answers
Hi Michelle,
I hope this is not a duplicate, I am having trouble sending things today and the last message I sent to you is not showing up on my end. If it is a duplicate I am sorry about that.
The inlet protector has a screw near the left side of it that you removed. There is a 'rim' around that screw hole, if you grab that rim with a small pliers and lift from the left side first the cover will come up.
Reply to this if you have questions. I can look for pictures if needed.
Phil
Posted on May 11, 2010
Testimonial: "Great ! I got it ! Thank you Phil ! Have a nice day."
I TOOK THE PLATE OFF THAT CUTS THE HAIR BY REMOVING THE TWO SCREWS, THE CLIPPERS ARE NOT CUTTING LIKE THEY DID BEFORE I TOOK THEM APART. ANY SUGGESTION ON LINING UP THE SERATED EDGES?
Hi, hold the unit upside down and loosen the two screws. Now, slide the plate to the right and make sure that it is straight with the cutting teeth. Tighten lightly the left screw, then check for straight, then tighten lightly the right screw. Again check for straight. Once you have the straight actually straight, tighten the screws more firmly. Test the unit. If it does not cut right. Loosen the screws slowly and move the plate 1 mm to the left. This is a matter of small movements to get it just right. You may have to move the plate a few times. Always, the screws need to be loosened and tightened slightly so as to keep the plate straight.
Mar 04, 2011 | Vacuums
Please Help! I installed 3 Moen Banbury single handle faucet/shower units. Water will not flow from either the hot or cold handle position from any of the units. I pulled a feeder pipe (pex) off each one...
were there any thread protectors inside the hot and cold inlets? sometimes they put Styrofoam pieces inside to keep debris out of the inlets and outlets. inspect inside of valve body through inlet holes thoroughly
Sep 16, 2010 | Moen & One Handle Tub & Shower Faucet
I need to clear debris from under the inlet protector. The two screws and the foreign object protector have been removed, but the inlet protector seems stuck in place. Is there a trick to pulling it out?...
Hi Steve,
I am not sure on what you are calling the inlet protector. Check out this link and let me know if it is one of the pieces that are called out here and the number it corresponds to.
This link shows how to clean out the sump so not every part in there is shown.
http://www.fixya.com/support/r4628450-poor_cleaning_or_noisy_pump_whirlpool_or
May 09, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
My palm z22 won't allow me to pass the calibration screen (clicking the bullseye target) I've tried removing debris from the edges, removing and putting back on the screen protector and turning it on and...
take the protector off and do a reset. Also make sure you don;t have any crud around the 5 way that is tyring to move things. The protector can be slighlty too big and cause this. It may look like it fits perfectly but causes this.
Mar 17, 2010 | Palm Z22 Handheld
I recently moved my Maytag refrigerator model MSD2554F from on part of the kitchen to another. It took me several days before I hooked the icemaker back up. I also replaced the water supply line for the...
Hi, Remove the line to the icemaker from the inlet vavle and blow through it. You can tell if it is blocked or not.
It might have frozen in the inlet tube through the wall of the freezer.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 13, 2009 | Freezers
Cobwebs in between screan and protector
It will take some effort to pull it off. start on the bottom pulling straight out from the box. Then work your way up then at the top wiyh the screen out away from the bottom lift slightly and it will come off. Hope this Helps You.
Mar 28, 2009 | Hitachi 50UX57B 50" Rear Projection...
Replacing water tank inlet valve gasket
Take a screw driver and set it between the chassis and the water inlet, bend the screwdriver and you will hear a "click" sound.
Best regards
/Mirran
Sep 07, 2008 | Saeco Vienna De Luxe Espresso Machine
Deluxe windtunnel by hoover
Check for a clog in the hose or the dirt inlet by the brush roll. When there is a blockage, the thermo protector will shut the motor off to protect it. That protector could be bad, or a problem with the motor. Is the brush roll turning freely and or is it froze up and won't move.
May 25, 2008 | Hoover Windtunnel Deluxe U54219RM Vacuum
Dishwasher
Plugged filter or spray arms .
Sep 30, 2017 | Dishwashers
WHIRLPOOL MODEL DUL300 GRINDING NOISE
You might have something bouncing around in the wash pump inlet in front of the "chopper". Remove the lower arm and upper arm supply tube. Remove the screws then remove the screen, accumulator and inlet protector. You should see debris in front of the screen. 0ca22aa.jpg
Dec 28, 2007 | Whirlpool DUL300 XTL Built-in Dishwasher
Dishwashers Logo
122 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
