Question about Sennheiser CX 300 Consumer Headphones
The left side is not working
If i shake the wire it starts to work then if it comes out of position it will stop again is there any way of fixing it
  • Sennheiser Master
  • 5,020 Answers
You could have a look at my tip on repairing dodgy cables and plugs on headphones. Though if it will be any good with your type of headphone, is up to you to evaluate.
Posted on May 12, 2010
Why my 2005 ford focus doesnt start sometimes?
clean and re tighten the terminals
check the alternator and regulator are charging the battery
also depends on how old the battery is
if no better starter motor /soleniod sticking
Jul 01, 2016 | 2005 Ford Focus
The radio in my 2010 Chevy Traverse is acting up, the door speakers on the left side stopped working
There must be a brake in the speaker wires not all the way thou. U need to fallow the wires from stereo threw to speakers n u should find the problom.
Nov 08, 2015 | 2010 Chevrolet Chevrolet Traverse LT
My whole car will shake violently at times, help please?
Is the check engine light on again ? Have you checked the computer for trouble codes ? Have you had base fuel pressure checked ?
Jun 17, 2013 | 2001 Ford Escort ZX2
My fan wont works for about 2 minutes then it dies out and starts again randomly
COULD HAVE SHORT IN FAN WIRE.WHEN FAN TURN OFF AGAIN SHAKE WIRE TO SEE IF FAN COME BACK ON IF YES LOOK FOR DAMAGED WIRE.IF YOU SHAKE WIRE AND FAN DONT COME ON.MORE LIKE FAN MOTOR FAILING.
Jan 30, 2011 | 2000 Chevrolet Malibu
I have a mazda protege 2003 and my car stinks like rotten eggs when i put on the gas and on top of that, my engine light is blinking and my car shakes when i stop at a red light!
i have a 2003 mazda protege. this is the third time my check engine light has come on. the first time the car started to shake when i stopped at a light and the check engine light came on. i had a readout done and it said misfire. i took it to a garage and they changed my spark plugs and wires. 2 weeks later it came on again and my car started to shake whenever i stopped. readout said misfire. they fixed the coils. it has been 2 weeks since then and my car started shaking again whenever i stop and the light came on. what could possibly be wrong with it?
Feb 06, 2010 | 2003 Mazda Protege
Fix front side left power window on 99 montana
The left power window switch tends to get bad contacts and stop working. You can simply pull out the switch trims (there is a clip at the pointy part of the trim, start prying there) and change the switch. 95% of the time the switch is the problem but if you want to be shure , check youre positive and ground at the switch, then take off the door trim, find the two wires that feed the window motor and with a fused wire (20 or 30 amps) and a battery, feed them a positive on one side and a ground on the other and vice versa. if the window move and power and ground are ok, switch is falty.
Jul 15, 2009 | 2000 Pontiac Montana
Ignition problems
the expeditions had a problem with the rear wiper motor grounding out, i would try replacing the wiper motor first, as for the fuse blowing, it is blowing for a reason, fuses don't just blow. if the wiper motor does not fix you may need to have someone go thru the electrical pin point tests to find the short.
May 19, 2009 | 1999 Ford Expedition
Eas keeps lighting
eas works with 5 valves,compressor,
compressor works?(in the box left side undernhood,)there is als interferance with dooor switch,if one door open,no position change possible,
the message on dash is eas malfunction?,
opn compressor box,if nor running compresor,shake or slight hit,
reset to 0 position?,shut contact,take off relay for compressor,disconnect wiring on compressor(main,)switch on again,now place back relay,connect again,while contact on,wait some minutes,reset is done,cut contact,on again,and see the for message,
Apr 14, 2009 | 1999 Land Rover Range Rover
Watch stopped after not being used for several days
The shaking is not the best way to restart the automatic watch as it puts slight strain on watch balance wheel and hairspring (most delicate part in watch).
As watch balance wheel is positioned paralel(leveled) to watch dial, you have to spin your watch back and forth a few times quite quickly.
(Imagine you are turning steering wheel in your car- thats the right motion). Before doing that wind up your watch a few times manually.
Right after doing that observe the seconds hand and if it is ticking just a little bit or ticking back and forth and then stops- your watch has jammed gear train and this is the reason why it stops.
If you don't have seconds hand- after shaking your watch listen for ticking and again- if it stops after short run, the gear train is to blame. In this case you will need watchmakers help as special skills and tools are needed to sort this out.
Do not forget to rate, please.
Jan 10, 2009 | Rado Diastar Anatom Jubile watch
Our refrigerator/freezer will stop working (not cool or freeze) then days later will begin to work again.
It's either the start device on the compressor or you have a bad compressor. You'll have to pull it away from the wall and take the bottom back panel off to check the compressor. It will likely be real hot to the touch from what you described happening. If there is a little white colored box on the left side take that off and remove the wires, etc. and shake it... if it rattles and debris falls out then that's the problem. It's fairly common and they make a kit to replace it with a better designed part that's real easy to install yourself. If your compressor has a label on it with a blue indian head symbol, then you're out of luck as that brand pretty much sucks and is destroyed by heat. It would mean a new compressor and then you'd be lucky if the new one even worked from the factory. Avoid those Tecumseh compressors at all cost.
Jan 07, 2007 | Frigidaire FRS23KF7AB Side by Side...
Sennheiser CX 300 Consumer Headphones Logo
685 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Vito Vacirca Jr.
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
