Question about Nokia Cell Phones
My nokia 6030 was hard-locked and it showed ''cannot undo restriction'' when I put security code, so how can I reset or fully format the phone
    Problem Solver:
Posted on Feb 23, 2011
Phone restricted
I suggest you can approach Mobile-unlocker.com and specify the country,locked network of your Nokia 6030.Based on the availability you can get the unlock(restricted) code.
http://www.mobile-unlocker.com/nokia-6030/rs2wp9/
Jan 15, 2014 | Nokia Cell Phones
My nokia 6030 phone when i start the phone asking restriction code with undo (option) please help .
Hi visit Onlinegsmunlock.com to get restriction code for your Nokia 6030 mobile from network lock .Here they ask you the network name to which your mobile is locked and the IMEI number of your mobile .Then at last they deliver you code to unlock your mobile.
Nov 07, 2012 | Cell Phones
Phone restricted,
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Sep 12, 2012 | Nokia 6030 Cellular Phone
Nokia 6030 mobile phone displays Phone Restricted with an Undo option
If your Nokia mobile phone displays Phone Restricted with an Undo option and selecting Undo results in an Enter Restriction Code error, your Nokia mobile phone is Network Locked. This means your Nokia mobile phone has been restricted for use on one specific network and a Restriction Code or Unlock Code must be entered before the phone can be used with alternative networks.
You can get the restriction code from here
Theunlockarena.com
Aug 07, 2011 | Nokia 6030 Cellular Phone
Ok sir i have face the same problem with my cell phone so do the same what i have done-
when it requires the code just try 4444 it will work.
if it won't work then go to settings option in your menu and select "restore default settings" option.
Feb 23, 2011 | Nokia 6030 Cellular Phone
My nokia 6030 is asking for phone restricted code
Sounds like the phone has been restricted (SIM-locked) to some other operator/carrier.
Try with a Hard Reset, if same then You need to find out which operator's SIM cards it is locked to, and call their customer service to have it unlocked (they may charge for the code, if it is still under contract to them).
Best of Luck.Please rank me appropriately. If you want any clarification, Please get back to me
Feb 20, 2009 | Nokia 6030 Cellular Phone
6030 Phone restricted help my
hi..
sometimes the phone or mobile is locked only into a 1 kind of network sim.
try to insert different sim card to your phone.
Feb 12, 2009 | Nokia 6030 Cellular Phone
Forgot Security Code of Nokia 6030 HELP NEEDED
These Nokia Unlock Codes are Generated For Nokia 6030 with IMEI: 353938013704220 (DCT 4) Locked to Provider Bharti Cellular Telecom Airtel in India and will only work with this phone!
#pw+199254713704764+1#
#pw+709210520774721+2#
#pw+922392540025507+3#
#pw+083253702164061+4#
#pw+324566447257373+5#
#pw+788290400654304+6#
#pw+302846623000752+7#
How to Enter your Unlock Codes
Recommended CODE :#pw+302846623000752 +7#
  1. Remove SIM CARD !
  2. Type #
  3. Then press the * key 3times (you should get a "p")
  4. Then press the * key 4times (you should get a "w")
  5. Then press the * key 2times (you should get a "+")
  6. Then enter: 302846623000752
  7. Then press the * key 2times(you should get a "+")
  8. Then enter: 7
  9. Enter: #
IF UNLOCK SUCCEEDS YOU SHOULD SEE RESTRICTION REMOVED ON SCREEN, YOUR PHONE IS NOW UNLOCKED!
POSSIBLE ERROR MESSAGES:
  • If you get CANNOT UNDO RESTRICTION your phone cannot be unlocked remotely and you need to mail in your phone!
  • If you get CODE ERROR the above codes do not work for your phone DO NOT ATTEMPT TO ENTER THE SAME CODE AGAIN
    Repeat above instructions, but with the numbers from code 1 (#pw+199254713704764+1#) if code that does not unlock your phone STOP! .
Jan 06, 2009 | Nokia 6030 Cellular Phone
Reset master code for Nokia N73
If you know the risks, try this ONCE and ONLY ONCE and let us know if it works. You have only 3 to 5 tries and then it will be hard locked. After that you will need a cable thing-a-me-jiggy to unlock it. It will still work on your Network so no big loss.
#pw+314646531133130+7#
Remove sim first,power on the phone.
After the phone boots up, press #
Press * 3 times fast for (p) \
Press * 4 times fast for (w) IMPORTANT
Press * 2 times fast for (+) /
and the rest of the code---
IMPORTANT!!
Verify code before pressing the last #.
Pay attention. You only heve about two seconds.
Note:If nothing happens. Some Phones require that you to insert a non accepted sim. Before you do this, make sure the sim you use does NOT have a security PIN CODE. If it does, reset the security code to default 12345 with the original phone. Insert a non accepted SIM and turn it on. You will see "phone restricted", select the UNDO option,then enter the code in the restriction box and press ENTER.
"Phone restrictions off", it's unlocked.
"Error code" wrong code.STOP tell me.
"Not allowed" or "Can Not Undo Restriction" it's hard locked. Used up all your free tries!!
Pls let me know, if it works for u...
Jul 17, 2008 | Nokia 1600 Cellular Phone
Restriction Code for Nokia 6030
Yes, yr phone is locked to other network. You have to put undo restriction code in it. You may send your phones IMEI no(Without SIM press *#06# ) sent it to me I will generate the unlocking code and will send to u with unlocking input mathod. You will get fully unlocked phone.
Jan 04, 2008 | Nokia 6030 Cellular Phone
Cell Phones Logo
487 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
