Question about Jenn-Air SVE47100 Slide-In Electric Kitchen Range
Jenn-Aire locked tight!
Dear electronic guru!!!
Jenn-aire door lock LOCKED! after self-cleaning - won't open, have unplugged for 2 days, etc, still is locked (hopefully clean by now), have never had an owner's manual, but have successfully oven self-cleaned before....
I turned the feature on, let it go for aprox. 6 hrs, it was still cleaning, had to leave and didn't want to leave that heat on if I weren't home, let it cool - locked and wouldn't open. Unplugged for 2 days, plugged back in, and lock still won't budge - I'll send biscotti if I can get it baked!!!!
Thanks for ANY assistance - Deborah my jenn air is a sve47500 or sve47600, conventional and convection, door locked, has already cleaned but will not open, tried cutting off breaker, etc and leaving off, fan continue to run and door remains locked, already cleaned and cooled off but door will not open, this has been over 24 hrs now...help
  • francis_g_de
    francis_g_de Feb 26, 2012
    I add this probleme this last week-end, I was about to get my hammer to "try" to open it, sorry for my poor english, but my girlfriend was beging me to try something else. What can i do else, i was having tried to cut off the breaker for a BIG minutes, no result, so I restart the auto-cleaning, and just touble tap on the stop button, and then the best ever sound just came off the oven, it was the sound of the door who unlocked, Hope it will help you!! Remember, before to use a hammer just take a big breath!!
    Genius:
  • 3,587 Answers
That relay/solenoid can get stuck quite easily..
you have a service contract on this?
Posted on Mar 28, 2008
  • Patrick Michaels
    Patrick Michaels Mar 28, 2008
    only way to do this is to remove the panel of the front door, and unhook that solenoid..Is this what you had in mind?
My Jenn-aire microwave says locked and has a picture of a padlock. I was microwaving bacon and had just put it some to cook ( my second batch per se) and everything was locked up. I tried pushing options...
Most likely you set a child lock (front panel lock) by holding a button too long (3 seconds). Without a model number, I can't be absolutely sure of the keypad lock for your Jenn-Aire microwave. Usually, the key will have a small padlock icon on it. Press and hold this key. On my microwave you press and hold Start to toggle the lock off.
On a Jenn-Aire JMW2430 and similar models, the Button Lock is activated by a several step process (More and Button Lock). However, pressing and holding the Start button will deactivate it.
I hope this helps.
Apr 19, 2011 | Jenn-Air Microwave Ovens
Started to self-clean, locked the door, etc. Had
Hi.
The appliance door is probably locked in consequence of the self cleaning cycle.
Unplug power cord, and allow the oven cooling down for few hours.
If the is still locked, then the high temperature generated in self cleaning cycle may have damaged the door latch, or the electronic control.
Parts must be tested to discover the fault.
Call Frigidaire at the number listed on the owners manual.
Regards.
Mar 03, 2010 | GE Ovens
How to turn off self clean oven Jenn air slide in older model after it is done cleaning
the self clean cycle will run for 2-3 hrs and the door will remain locked for another couple hrs while cooling let it finish and wait till the next day basically if it still wont open (sorta common) the door lock assy needs replacing.
Oct 08, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air stove locked
After the lock indicator light goes out, move the door lock lever to the left. The oven door can now be opened. Turn the selector and temperature knobs from clean to off AFTER THE DOOR IS UNLOCKED. If the temperature knob is turned to off BEFORE the door is unlocked, the door will not open. Forcing the lock will damage the lock mechanism. If this should happen, return the temperature knob back to CLEAN, unlock the door, THEN turn the temperature knob off. Source(s): Jenn-Air Grill Range with Self Cleaning Radiant Bake and Convection Oven models S136, S156, S161
Dec 10, 2008 | Ovens
Jenn Air oven door won't open after clean cycle
You need the repair man; not a diy project. Please contact me if you need further help and leave feedback. Thanks for letting me help you!
Nov 30, 2008 | Jenn-Air JGR8775QD Gas Kitchen Range
Jenn Aire lock for self clean in locked position
The LOCK INDICATOR light must be OFF. This can take up to one hour!!!
Do NOT force the door.
Leave the SELECTION and TEMPERATURE knob alone. The Temperature knob MUST be set to CLEAN
Indicator Light OFF, knobs set to CLEAN - OPEN the slide lever.
Lever open, set the knobs to OFF and away you go
Oct 26, 2008 | Jenn-Air Ovens
I have a Jennaire range and the control panel no longerworks to control turning oven on etc....first the LED display had went out. Now no touch pads work!
The clock is a very common problem the only way you can fix the LED display and it also controls the oven...replace the clock
Jul 11, 2008 | Kitchen Ranges
Jenn aire
Maytag-Maycop-Magic Chef-Jennair-Admiral
Oven Fault Codes:
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
May 10, 2008 | Jenn-Air WW30430P Stainless Steel Electric...
Try turning the oven tempurature all the way to the right (past clean). That is what unlocks mine.
Jan 12, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air SVE47100 Slide-In Electric Kitchen Range Logo
344 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
