Texas Instruments TI-86 Calculator
Problem for Texas Instruments TI-86 Calculator
Texas instruments ti-86 screen problem
By thuanien on Mar 28, 2008
Recently, I've used my old ti-86 and I saw too many lines across the screen that cut off the numbers appear on the srceen. How to fix that problem?
Comments:
Apr 01, 2008
- Thanks for your help but it didn't go away. there are vertical lines across the screen still.
Same Problem
Jul 21, 2008
-   also having the same problem. It looks as though there are lines missing.-   Guest
Apr 23, 2008
-   I have the TI-86 i am also having problems with the lcd showing horizontal lines across the screen covering up the numbers and images. i tried replacing teh unit with new batteries with no luck, what else can it be?-   Guest
Solution #1
posted on Mar 28, 2008
Somewhat Helpful)
Starkley
Rank: Guru
Rating: 87%, 113 votes
Remove and replace the batteries should be first step. Also, I believe these have a smaller button-cell backup battery as well. Replace and reset to factory settings (backup any saved info if you can link with another TI calculator).
Was this helpful?
Yes
No
Solution #2
posted on Mar 09, 2009
Very Helpful)
tantong
Rank: Guru
Rating: 86%, 185 votes
Hi I got a problem with Ti-86 which is a line of the screen pixel missing. I tried to increase and decrease the intensity of the screen (2nd and up, down). Also tried to go to MODE function. I have tried that for several times. It works great. The line of those missing screen pixel came back. I don't know why. Just try it.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Texas Instruments TI-86
Questions and Unsolved Problems for Texas Instruments TI-86
Do you recommend Texas Instruments TI-86 Calculator?
Answer
Answer
how do i recall a pic for a program on a ti 86? im doing :clrdrw then :rcpic and then im not sure... (More)
Answer
math final tomorrow!!!! my screen is entirely black when i turn it on and the contrast buttons do... (More)
Answer
My TI-86 calculator does not turn on. I changed the 4 AAA batteries as well as the CR1620 backup. I... (More)
Answer
How do I change the tax rate on the Texas Instrument calculator
Answer
When entering the numbers the second row cuts off teh bottom number on the screen and it looks like... (More)
Describe your Calculators problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Calculator Experts
Top Copier & Fax Repairmen
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
