Question about Bosch HES 24 / 6HES 242 / HES 247 Electric Kitchen Range
The oven timer and all the lights are flashing and beeping
Beeping started and even after reseting the circut breaker unable to reset clock and flashing and beeping wont stop
SOURCE: beeping
Thanks! I found this online, which shows how to run tests on the washer to see what might be wrong, which helped, too. Now if i can just find a few muscly people to help me move the dryer from atop the washer.
http://forum.appliancepartspros.com/attachments/washer-repair/42d1194897506-error-code-01-wfk2401test.pdf
from this page:
http://forum.appliancepartspros.com/washer-repair/2385-error-code-01-a.html
Posted on Nov 26, 2007
SOURCE: dishwasher blows circut breaker and shuts down about 5 minutes into cycle.
possibly your heater is shorting.
Posted on May 14, 2008
Cyril J
  • 45 Answers
SOURCE: Electronic Oven Control won't work after power failure
the pf=power failure
try unplugging unit for a few min then try again, but you may have a bad control
Posted on May 22, 2008
blueextc3221
  • 15935 Answers
SOURCE: GE Stove clock shows FFF and oven will not work
GE Error Code: FFF
Condition: Door motor safety circuit
Fix: Repair Electronic Range Control (ERC)
Usually, failure happens after power surge.
Thanks for using FixYa - a FixYa rating is appreciated!!
Posted on Feb 13, 2009
  • 23 Answers
SOURCE: The Bosch dryer will light up but will not start
The start button wears out on these. This is what happened to me. If you take a screw driver to make conneciton of the top of the start button, it should kick on. May take a second or two holding it there before it starts.
Posted on Aug 15, 2009
Display is flashing0.00 and auto. oven won't work, took out circut breaker still doesn't work. when trying to reset the clock high pitch sound comes on and have to turn oven off at wall to stop
It will not work if it is flashing, the timer needs to be reset to manual
If it will not reset, then It sounds like the timer is faulty, try a different combination of buttons when trying to reset it.
Hope this helps.
Feb 02, 2010 | Ovens
Oven comes on for 5 min then shuts down everything even the keyboard
Same problem here on JKP15WOW1WW. The cycle starts like this:
1) Open circuit Breaker
2) Open oven panel and push ribbon connector to ERC. Replace planel.
3) Close circuit breaker
4) Run to oven, notice clock flashing some time but not 12:00 and start Bake. Bake button beeps and starts bake coil.
5) Within 5 minutes hear a beep and all buttons on panel are unresponsive. Bake continues. if oven light is on it continues to glow. Only button that responds with a beep (and not to clear bake or oven light) is Clear botton.
Rinse..wash..lather...repeat...
Nov 11, 2009 | GE JKP15 Electric Single Oven
The electric circuit breaker kicked off and when it was reset, we are unable to get anything with the oven to work. the time comes on at 12:00 and then it starts beeping and a f 1 light appears
with kenmore F1 is a power failure in side the clock control
your whole clock will need to be replaced
go to www.appliancepartspros.com
type in your model number and look in the control section
Oct 20, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Oven turns itself on???? Timer beeping when family woke up???
Sounds like someone messed with your timer... Easy reset: turn the breaker off and back on...reset clock... woo hoo!
Jul 30, 2009 | Whirlpool RBS305PDS Electric Single Oven
Jenn Air Oven Model # SVE47600B Error Code F7
I have a jenn air SVE47600F.It just started beeping and giving a code 7.None of the controls work when it brings the code up,but controls work fine when code is not there. We have to turn the breaker off to reset it.Sometimes when we have been gone all day we'll come home and the range will be beeping and flashing a code 7
Sep 09, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Wall Oven won't work
I tried randomly pushing 2 buttons at a time, and when I pushed "Timer Off/On" and "Cancel" together it unlocked and is now working fine. The following day it beeped a lot for an hour or so (must have been catching up on previous pushes) but now is back to normal.
Mar 14, 2008 | Tappan 30IN ELEC IGNa Oven
Main oven failure
Shut off power at the mains breakers and restart. This may reset the unit.
Dec 10, 2007 | Smeg A2.5 Dual Fuel (Electric and Gas)...
Random beeps, oven almost starts itself
The touch pad may be defective. There is a membrane behind the buttons that will cause problems like that. The only cure is to replace the touch assy.
Sep 11, 2007 | GE Profile JKP18 Electric Single Oven
Beeping, flashing, oven door locked, display shows F-1
F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad) F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) BUT you also need to check the Oven Temperature Sensors The Oven Temperature Sensors should read room temperature, 70°F, the resistance is 1000-1200 ohms. make sure you pull off the wires to measure the sensor's resistance and it reads open it is bad. and you will have to replace it too. hope this helps.
Sep 05, 2007 | Jenn-Air SCE30600 Slide-In Electric...
Keypad Problem?
look on the back panel for any hole with a "RESET" label next to it. insert a small pin to reset your microwave
May 25, 2007 | Emerson MW8168B Microwave Oven
Bosch HES 24 / 6HES 242 / HES 247 Electric Kitchen Range Logo
93 people viewed this question
Top Bosch Kitchen Ranges Experts
Oloyede Monsuru
Joseph Hoffmann
Are you a Bosch Kitchen Range Expert? Answer questions, earn points and help others
