How do I use the following DVD Drive on a Mac G4
ATAPI DVD DH20A4P. The Mac sees the drive. It opens and closes it but it does not show any disc insterted in the drive
I took the drive back to the store I gouht it from and it turned out that the drive was defective in the first place. They replaced it and all is well now. Thanks again
Posted on Apr 01, 2008
Why won't my MATSHITA DVD-RAM LF-D211A mount any blank discs on my desktop?
If you open up System Preferences and click on "CDs & DVDs" does it look like this?
.... Especially the top two items ....
Jul 20, 2014 | Apple Mac OS X 10.4 Tiger for Mac
Need drivers for Liteon atapi dvd a dh20a4p
This should do the trick.
http://www.bioticaindia.com/atapi-dvd-a-dh20a4p.html
Oct 30, 2010 | Computers & Internet
How do iget the bloody door open tp insert disc
Mac OS 9.2
  • Press the Eject key on Apple Pro Keyboard
  • To open the second optical drive on a Power Mac G4 (Mirrored Drive Doors) computer, press Option-Eject on the Apple Pro Keyboard.
  • Open the Eject application found in the Eject Extras folder. The Eject Extras folder is located in the Apple Extras folder on the CD.
  • Click the iTunes eject button (see Figure 1).
  • Hold down the mouse button when you hear the startup sound as the computer restarts.
  • Start up from Mac OS X and customize the toolbar with an eject button.
Mac OS X
  • In the Finder, Choose View > Customize Toolbar. In the window that appears, drag the Eject button to the toolbar, then click Done. Select the disc you want to eject in the Finder window, then click the Eject button in the toolbar.
  • Press the Eject key on the Apple Pro Keyboard.
  • If you have a keyboard without an eject key, press F12 (under Mac OS X 10.1 and later). Note: You must press the F12 key longer to prevent the tray from accidentally opening.
  • Click the eject button in iTunes (illustrated in Figure 1).
  • Start up from Mac OS 9.2 and follow the options in the section above.
Aug 18, 2010 | Apple eMac G4 Desktop
Disc drive wont open. i pressed the eject button on my keyboard but it makes a clunk sounds but wont open.
This wil show you how to take it apart if that becomes necessary. But try this instead. First hold the eject button down for 5 seconds. I that fails look for a tiny hole near the disc slot. Use a straightened paper clip and push it in the hole firmly. This should eject the disc. Another option is to use firmware to eject the disc. Follow these directions: To eject a disc with Open Firmware commands, follow these steps:
  1. Restart the computer.
  2. Immediately after the startup sound, press and hold the key combination Command-Option-O-F.
    Note: The Command key has the Apple and (commandkeysymbol.gif) icons on it.
  3. Release the keys when you see a white screen that says "Welcome to Open Firmware."
  4. At the prompt, type: eject cd
  5. Press Return, then wait a few seconds. The disc drive should eject any disc that is present, and "ok" appears behind your command when the action is complete.
  6. Type: mac-boot
  7. Press Return.
  8. Your computer should now start up normally.
  9. Instructions curtorsey eh.mac.ca
Aug 16, 2010 | Apple iMac G4 Desktop
I Firmware problem!!
check the jumpers are on master slave or both on CS Cable Select
Jul 15, 2010 | Dell Dimension 1100 PC Desktop
My DVD-ROM tray opens only after many tries.
As per your information you done all the basic work. Hope you use little bit of oil drop in the side of the tray. If not then try that .If no success then there is a small spring available for tray in and out function. You have to change that spring from a service center or if possible then at home.
Thanks and waiting for your reply.
Feb 04, 2010 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
My ibook G4 has stopped reading my external dvd drive.
If you external DVD drive connects via USB, try rebooting your iBook. (Sometimes a static shock will shut down your USB channel, and only a reboot will reset it.)
If this doesn't work, choose "About This Mac" under the Apple menu, then click on "More Info." Under Hardware, click on USB. See if the drive shows up as one of the attached USB devices. If it does not, the drive or cable may be bad.
If you have another computer available, connect your DVD drive to it. This will tell you whether the drive has failed.
Nov 14, 2009 | Apple iBook G4 1GHz 256mb 40GB Combo 14"...
When i insert a cd or dvd into mu MAC powerbook
Check to see if your discs are dirty. Clean them and try again. Also, check to see if you got heavy scratches on the discs. Also, click on the blue apple logo at the top of the screen, then click on about this mac,then click on more info. Under the hardware click on the disc burning title. Look at CD write and DVD write info to see what the burner will play. If no info is there, then your optical drive is disconnected from the logic board or your optical drive is toast. If your optical drive spits out every single disc, then that also means it needs to be replaced.
Nov 05, 2009 | FastMac (APP-5693) for PowerBook G4...
Dvd stuck in ibook g4 disc drive
Here's possibility 1: from the apple forums" We had a repair come in at work with excactly the same issue, I managed to correct the issue by correcting the CD-Drive connection to the logic board, the customer had a very VERY big smile on his face once I had fixed. I felt so happy after this repair, unfortunatly, it earned our AASP no money tho. But it made me happy to see a smile I caused.
Possibility 2: firmware command:To eject a disc with Open Firmware commands, follow these steps:
1. Restart the computer .
Note: The Command key has the Apple icon on it.
Open Firmware."
action is complete.
6. Type: mac-boot
7. Press Return.
Possiblity 3
If you can't get the CD to eject normally, reboot and hold the Option key. You'll see a startup drive select window. When the cursor changes to an arrow, (be patient, it may take a minute or two) then press your eject key, the CD will eject. You can also try holding the mouse/trackpad button down during a restart.
Jun 04, 2009 | Apple iBook G4 (Z0AZW13397068) PC Notebook
DVD player skips audio and/or frames
PowerBook G4 is at least a five-year-old machine at this point. A DVD drive can **** in lots of dust in five years. Try hooking up to an external DVD drive. If it plays the same discs with no problem, you need a cleaning or replacement. Frankly, an external DVD drive is cheaper than replacing your internal drive.
Mar 07, 2009 | Apple PowerBook G4 Mac Notebook
Computers & Internet Logo
126 people viewed this question
David Payne
David Payne
