Question about Crown CE2000 2-Channel Amplifier
Fan works out of amp but not in amp ? ce 2000
Amp seams ok but one time failed works now with no fan start up when hot ! fan works when I hook power to it
3 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: i have a crown ce 2000 watt amp. channel 2 keeps turning off
Do you get any Fault indications?
Have you swapped the speakers around to eliminate them as external causes?
When the channel dies is the unit very hot and is the fan turning very fast (it should be if hot)? The fan could be defective, slow or airflow may be restricted.
Turn the amp off and examine the fan guard on the rear to make sure it is clear of dust and debris. Vacuum it out if necessary. With a small thin non-metalic object reach in and test the fan for free movement by trying to rotate it. It should coast.
Posted on Apr 28, 2009
dunnbiker
  • 8546 Answers
SOURCE: how does the fan works, does it stars blowing
It works on demand.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Crown-CE-2000-Amps-manual/id/22150ag314/t/2/
Posted on Apr 17, 2011
87 suzuki samurai ac only blows cold when it rains
Is the dash controls set in heat + defrost mode?
or
A/C only mode ( <<<<I will guess this)
you are lucky A'/C works after 27 years.. for sure.
that is an all time first. rains.
what is the outdoor temperatures?, one thing i cant guess.
what is your question, the above is a statement.
and can be true, heater off, A/C on. on any car. controls wrong.
I will try to rephrase it.
I'ts hot, outside and my A/C fails. not moving.
and seems to work a bit, when raining.
and works ok moving fast. why?
Checks (basic)
  1. A/C test. turn A/C only, on and recirc. mode.
  2. Does the cab fan blow hard? y/n
  3. Then see if the compressor clutch is engaged. (hood up)
  4. if engaged. see if front fan is on, fast running, if not, that important function is failing, more tests, ask.
RAIN issues.
fan in front of the A/C condenser failed?
if the front fan fails , the A/C will be weak, , not moving fast (car)
and will work better in rain, because the rain cools the condenser partially hiding the fact that front fan is DEAD.
that fan , to find it, look in the front grill. see it. that black fan
id bet it's dead'. (that dont mean it bad; per ce'.) it can be the relay
that drives it , that's bad, or the wires connecting either bad.
as we say 1s things, first the glance at the fan ,then more tests
if all this is greek, get the car serviced.
May 07, 2014 | 1987 Suzuki Samurai
Suzuku SX4 starting problems - fuel pressure
intermittent are hard to find.
as they say" if it ain't broke, you can't fix it" applies
but in truth, we lay in traps to find this.
this is true with all machines, not just sx4
facts: (random no starts) but always cranks fast.
only fails cold engine. never hot. (does restarts hot work?)
seems yes.
seems you have full 12vdc power at all times.
seems the engine is ok. as it is not heat rlelated or the classic hot soak fails.
so what is it.
well, its 1 of these.
1: lost spark, simple tests, do so when failed.
2: bad fueling. (too much or too little)
the tests for each failure are dead simple and work on any engine.
ask.
Jun 29, 2013 | 2009 Suzuki SX4 2.0
Blower fan not working
The resistor bank is bad for slow speeds, the switch is bad for high speed. In your test, you have voltage, but the switch wont carry the amps, to run high speed. Open circuits will not blow fuses. Replace both switch and resistor bank for all speeds. Make sure to clean leaves and trash from fan housing and see if fan spins freely.
May 17, 2017 | Cars & Trucks
Cooling fans not coming on before engine overheats and coolant is pumped out of the overflow.
2 things of what it might be........an airlock, caused by improper bleeding of the sytem, when it is topped up...or coolant temp snesor, has failed or poor wiring......
Oct 05, 2010 | 2000 Pontiac Grand Am GT
Cooling fans dont work wont shift i hook a test light to ground and hot it shows ground loss of
I have no idea what your post means but here is how fan works: Temp sending unit sends signal to the computer, computer sends ground signal to the relay, relay completes circuit to fan. A/C bypasses that and turns fan on automatically, so fan runs all the time with a/c on. Check fan itself by hot wiring it to battery. If it fails to go on, the fan motor has failed. All else needs to be tested using a volt meter to check power flow. Also make sure any fuses for system are good.
Sep 10, 2009 | 2000 Chevrolet Camaro
MY fan belt broke now the car won't start.
if ur fan belt broke n ur water pump is run by it look out knock senser usually controls ur injector pulse so yea it will not start crank too cam no
May 25, 2009 | 2000 Kia Sephia
I have a crown ce 2000 watt amp. channel 2 keeps turning off
Apr 27, 2009 | Crown CE2000 2-Channel Amplifier
Car suddenly started overheating
Welcome to fixya
this could be cause by the thermastate or the fan could not be working i would replace the thermastate and check fan make sure it is running when the car heats up
Aug 29, 2008 | 2000 Hyundai Elantra
Asus a8v fail
does the power supply fan run when switched on.
does the hard drive spin up .
Have you reseated the video card.
Jan 26, 2008 | ASUS A8V Deluxe Motherboard
Crown CE2000 2-Channel Amplifier Logo
111 people viewed this question
Top Crown Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
