Question about Tappan Microwave Ovens
Timer goes super fast
I tried to microwave a cup of coffee, pressed 30 seconds and Start. It ran for 2 seconds flashing all kinds of numbers and then was done. Any advice?
  • 883 Answers
SOURCE: Oster Microwave/Convection/Grill
first, get your money back or get a replacement for no charge. now, unplug the oven for 15 minutes and try again. if no-go, then some device is faulty that only a tech can find
Posted on May 28, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: Amana Microwave model ACM1460AB
Weak heating is usually a bad magnetron.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Nov 28, 2007
SOURCE: the microwave starts, then stops 2 seconds later
I tried a solution posted on another posting http://www.fixya.com/support/t242480-stops_cooking by placing the conductive plastic behind the control panel and it worked.
Posted on Jan 06, 2008
  • 220 Answers
SOURCE: Time count down on microwave oven
Unplug the Micro for about 5 minutes and plug it back in this will reset the board,it may have picked up interference from other electronics.If the issue continues have a technician look at it.
Posted on Sep 01, 2009
Testimonial: "This would have been very helpful if I hadn't alread figured it out on my own. Thank you."
  • 49 Answers
SOURCE: microwave timer counts down super fast
try unplugging it for about 15 minutes. if that doesnt work, you might as well get a new one. i fix everything myself for just the cost of parts and i have found that what parts cost for a microwaves, its cheaper just to buy a new one.
Posted on Oct 17, 2009
How do I enter a time of less than 1 minute? Bought a brand new Oster Microwave model OGZJ1104. I cannot figure out how to heat up a cup of coffee for example - for 30 seconds. The user manual has
Usually a quick start button along with dial to scroll down from one minute.check if any buttons are push click to see if they extend away from fascia once pressed or try select one minute then use main dial anti clockwise to reduce time.hope this helps.
Feb 01, 2015 | Oster Microwave Ovens
LG microwave intermittently runs
I would try troubleshooting the "defrost circuit". The behavior sounds like the microwave is cooking in the defrost mode, where it actively cooks then stops allowing the food to rotate and the heat to spread then actively cooking again.
Nov 06, 2013 | Microwave Ovens
Sharp microwave 8888 is flashing and I cannot remove
see this steps and fix it. God bless you
Reset the clock. Press "Clock" and the correct time, using the number pads. Press "AM/PM" if applicable, and press "Start" or "Clock" to confirm.
  • 2 Press "Timer On/Off" to reset the timer if nothing on the touch pad will operate. Use the number pads to select a new timed amount, if desired, and press "Timer On/Off" to start. Press again to cancel.
  • 3 Press and hold "Clear/Off" for three seconds if the timer will not function or is blinking when you touch the pads. This will release the "Child Lock" feature. Make a new touch pad selection.
  • 4 Disconnect power to the microwave if following Steps 1 through 3 does not resolve the blinking timer. Wait a few minutes, and then restore power to reset the microwave.
  • However if the problem persist the display board
    main control board is faulty
    Oct 02, 2012 | Sharp Microwave Ovens
    I lost the user manual to my 30 + cup coffee percolator and I need to know the amount of grounds to use when brewing coffee!
    Use approx. 1/2 cup of coffee to 10 cups of coffee....so for a full pot use 1-1/2 cups... then adjust to taste..
    heatman101
    Sep 09, 2011 | Microwave Ovens
    How much coffee grounds should I use for 30 cups of coffee made in a west bend 30 cup coffee maker?
    !/4 cup of coffee for every 8 cups of water or almost a full cup of coffe for your 30 cup pot...
    heatman101
    Sep 07, 2010 | Microwave Ovens
    Microwave timer counts down super fast
    Oct 17, 2009 | Sharp R-540DK Microwave Oven
    Sharp Microwave Oven Timer Counts Down Very Fast (Demo mode)
    Here is where you can download the manual
    http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
    Yes the problem can be undone also.
    Feb 09, 2009 | Sharp R-540DK Microwave Oven
    Kenmore Microwave stopped working.Mod# 87103
    To the guest who wrote:
    Aug 15, 2008- Won't run on start. the minute number flashes and same with the word TIMER on the top right.
    Clock will change but won't start..
    Did you ever solve this problem? I have the same one as of yesterday... this is a fairly new microwave, would hate to have to replace it so soon.
    Jun 16, 2008 | Microwave Ovens
    Microwave oven (nn-sd997s) stuck in DEMO mode
    Pressing "timer/clock" button 4 times turns on and off demo mode.
    Apr 26, 2008 | Microwave Ovens
    Microwave Ovens Logo
    22 people viewed this question
    Top Tappan Microwave Ovens Experts
    William Miller
    William Miller
    Mark Gough
    Are you a Tappan Microwave Oven Expert? Answer questions, earn points and help others
