Question about Konica Minolta bizhub 350 All-In-One Laser Printer
Reds come out yellow, and facial tones are too red
When I print, what is supposed to be red, comes out yellow, and facial tones are too red. What do I need to do?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 108 Answers
It sounds like your machine needs to be calibrated. First try turning the machine off and unplug it for about 15 seconds. When you turn it back on it will reboot its software and stabilize the image units. If this does not correct the problem you can perform a gradation adjustment by:
1 Load 11 × 17 L-size paper into the 1st drawer.
❍ Letter C, A3 L or A4 C can be loaded instead.
2 Press the [Utility] key.
3 Touch [Admin. Mode].
4 Using the keypad, type in the administrator code.
❍ Touch [Enter].
5 Touch [Gradation Adjustment].
The Gradation Adjustment screen appears.
6 Press the [Start] key.
A test pattern is printed.
7 After the test pattern is printed, a screen appears, indicating how
the test pattern must be loaded.
8 Place the printed test pattern on the original glass.
❍ Align the edges of the printed test pattern with the document scales.
9 Place into the 1st drawer 10 more sheets of blank paper of the same size as the printed test pattern page.
10 Close the original cover, or the reverse automatic document feeder if it is installed.
11 Press the [Start] key. The printed test pattern is scanned.
12 Based on the scanned image, the gradation levels are automatically adjusted.
After the gradation levels are adjusted, the Admin. Mode screen appears again.
13 Repeat steps 5 through 12 three times.
14 Touch [Exit], and then touch [Exit] in the Utility screen.
Posted on May 13, 2010
I am printing in red but output is yellow
Check the ink levels- it sounds like your Magenta is out- HP deskjets use CMYK to mix the colors- C = Cyan, M= Magenta, Y = yellow, K = intensity (black). Red is usually a blend of Magenta + Yellow- so if you don't have magenta ink in your printer, when you try to print out something in red- it will come out yellow
Jul 01, 2011 | HP Deskjet D2360 InkJet Printer
Wiring
There are 3 wires on this siren. Red, Black, and Yellow. The red and black wires will give you the normal sound you hear from a siren. If you hook up the black and yellow, it will give you a continuous long tone. Normally, you hook up the black to Bell - and and the red to Bell +.
May 19, 2011 | Siren Dsc Sd 15w Ulf Surface Mount Siren...
My RX690 will not print red, what is supposed to be red comes out yellow. I have swapped in new cartridges and they are all in the correct locations.
Most likely the Print Head is clogged for that color. You can either do a head cleaning. If that doesn't work.
Take the cartridges out and put a few drops of isopropyl alcohol in the bottom of each head where the ink goes thru. Let that sit for a few hours, then reinstall the cartridges and run the head cleaning cycle a few more times.
Jan 08, 2011 | Epson Stylus RX690 InkJet Printer
My dell 5100cn printer is not printing red tones at all. Everything comes out in green tones. Has new toner cartridges and drum. What can I do?
The M6090 Magenta Developer is failing. It has lost it's magnetism. So the toner isn't ready to be transferred.
The Cyan Developer G6593 or Yellow Developer H6682 may be failing too, because it can't dependably hold all it's toner. One of those is probably bad too.
Whit
Item, Inc
Aug 17, 2010 | Dell 5100cn Laser Printer
Printing photos on glossy photo paper and prints are coming out in a red tone.
This is usually caused by there being a lack of either the blue or yellow colour, or both. Check their levels and replace as necessary.
Jul 12, 2010 | Epson Stylus Photo 900 InkJet Printer
Samsung DLP Facial Colors off after changing color wheel
Do you mean that red and blue are reversed? If so, you may need to remove a jumper, see end of linked article. Pinkish-yellow or orange sounds like a good description of skin tone, but perhaps too intense. If the color is too intense, can you just lower the color level with the color control? Or can you just change the tint with the tint control? Otherwise, see http://www.jangro.com/electronics/samsung-dlp-replace-color-wheel/ including the comments at the end.
Oct 11, 2009 | Samsung HLN4365W 43" Rear Projection...
Pictures coming out green
On a picture that you have printed, when you see an area of green, what color should it be? You probably have reduced flow of one of the "balancing" colors. Blue, Yellow and Red add up to Black. If your picture is supposed to be almost black and you don't have enough red, the color will pull toward the blue and yellow, giving it a green tint.
Aug 04, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Prints all yellow, with some blue and black, no brown
the problem is very simple the magenta ink the cartridge is over or the head is been blocked from where the magenta ink comes out,
because red colour requires ---yellow plus magenta(pink)----to make it red.and ----dark yellow plus magenta(pink) -------- for brown colour.
Nov 22, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
381 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
