Question about Whirlpool Duet GHW9150P Front Load Washer
Same as Before
Now I need to know how to get the dadblamed door to open...
  • Anonymous Apr 06, 2008
    I had the same problem. Kids had over filled machine and door was not shutting tight. I pushed on door and held it in tight while holding cancel button. WALA! door opened.
    President:
  • Whirlpool Master
  • 2,651 Answers
Remove the bootm access panel and reach up under hte handle of the door is a round plastic pull to manually releas the door lock/latch assy
Posted on Apr 02, 2008
SOURCE:
I need to know how to reingage a Craftsman garage door opener
All you need to do is cycle the door open and then closed.
Mar 15, 2017 | Building Materials
Door will not work open or close
Dave, Ensure nothing is blocking the safety lights and if they are on align them. If you know there is power to the unit, logic/circuit board is probably bad and needs replaced. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Why is there no power to my garage door opener
Garage Door Opener Repair How to Troubleshoot Openers
The Top 10 Reasons Your Garage Door Wont Work
How To Open Your Garage Door Manually when there is no power to operate it
May 27, 2016 | Building Materials
I need to know how to reprogram a remote control for a craftsmans garage door opener
Check this site.
http://www.buckeyedoors.com/tips/program-garage-door-remote.html
Dec 01, 2011 | Sears Craftsman LiftMaster Chamberlain...
Door on 97 Toyota T-100 lock is jammed and cannot open door
My door is also STUCK SHUT, I cant open it from the inside or outside. I understand I need to remove the door panel to fix the issue, but I need the door open to remove the panel. I know I'm not the only person who's went through this. How did you get the door to open? Please let me know how you got your STUCK SHUT door to open so I can remove the panel and fix it. Thank you, desperate T100 owner.
Dec 18, 2010 | Toyota T100 Cars & Trucks
My sharp R-798 has stopped heating food and the turntable no longer rotates?
Please check your door safey interlock micro switches.
If you need help with this, please let me know.
What frequently happens is because you probably open the door while the oven is running, (like most of us do) the little micro switches get burned and eventually cannot tell the oven that the door IS, indeed, closed. When the door is "open" (forget that you know the door is closed - the MACHINE needs to know it too) the oven will not turn on the heat.
If you need more info, let me know please.
Oct 18, 2009 | Microwave Ovens
My outside Craftsman keypad will not open the door but will close it.
Most likely if the opener will close the door, but not open it, the springs are fatigued enough to where the opener is exceeding the force limits established. If the door is really heavy the opener will not open it as a safety precaution.
The keypad is probably fine, but you need to have a professional garage door repair technician come out and take a look at the garage door hardware! Repeat: Do not work on the springs yourself!
Apr 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
The Drivers door won't open from the outside or the inside?
does it have electric door locks? maybe there stuck on lock. if thats whats up you will need to get someone thats got a slim jim to unlock it for you. most body shops have one. if anyone would know how to open your door it would them.
Jan 14, 2009 | 1990 Buick LeSabre
Whirlpool Duet GHW9150P Front Load Washer Logo
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
