Question about Raymarine ST60 A22012-P GPS Receiver
E22078 wind vane transducer Raymarine
Fix card (board) for E22078 wind vane transducer Raymarine. Anybody would have specs on the small electronic card inside the windvane transducer masthead Raymarine E22078
2 Suggested Answers
SOURCE: Raymarine ST50
http://www.defender.com/product.jsp?path=-1|344|295761|301233|320702|746011&id=823240
Posted on Nov 10, 2008
WHAT TRANSDUCE GOES WITH THE DS600X COLOR ..WHERE CAN I BUY ?
Hi
Airmar makes almost all of the transducers for Raymarine. From the Airmar FAQ section, your unit is listed. See the link below. Pretty much any marine chandler or Raymarine dealer should be able to order it for you.
Hope this helps
-Steve
Airmar FAQ What Airmar transducers are compatible with the Raymarine...
Feb 26, 2015 | Raymarine Ds600x Digital Fishfinder With...
I have a A22012 ST60 wind vane I need an new transducer what part number should I look for for replacement
Hi Greg!
What you're looking for is an E22078.
Here is a link from binnacle.ca, but I'm sure you can find them cheaper if you look around.
Hope this helps.
-Steve
RAYMARINE ST60 PLUS WIND TRANSDUCER MASTHEAD E22078
Jan 23, 2015 | Boating
Is there such a thing as a reset for the Autohelm WIND ST 50? I purchased a boat with one that showed proper wind angle but not speed. I removed the sender, greased both the wind vane and cuos. now
I assume you have an ST-50 or ST60 windvane setup. These are the calibration instructions from the unit manual for the ST-50. They are the same for the ST-60 and ST-60+ units.
Hope it helps you.
Initial Calibration Windvane Alignment
Before the unit is used for navigational purposes the masthead transducer must be accurately aligned to the vessel. Before this procedure is carried out the windvane should be linearised as follows.
1 . Powerup lhe ST50 Plus Wind instrument.
2. Tum the vessel through two complete circles, making sure that the windvane remains in line with the wind -the instrument will automatically linearise the windvane.
Alignment
1. Press and hold CAL for 2 seconds until CO is displayed by the LCD.
2. Press < > to move the pointer to the correct wind angle.- WIND
- Press < > once to move the pointer by 1 degree.
- Press < > for 1 second to move the pointer by 10 degrees/second.
The LCD will now display the applied correction.
3. Press and hold CAL for 2 seconds to exit and store windvane alignment.
Windspeed Unit Selection
1 . Press and hold CAL until Ul (Knots) or U2 (Meters/second is displayed.
2. Press CALwithin 8 seconds to change the windspeed units selection.
3. After 8 seconds the wind instrument returns to normal operation.
Nov 22, 2014 | Boating
Display only showing dashes ----- I have voltages on the 5 core cable from transducer to back of display .... what are correct values for these?
Try to identify if the fault is in the masthead unit or the display by using a known good unit ,or masthead or display.
Then have it repaired.
Feb 28, 2011 | Raymarine St60 Wind Vane Ducer E22078
St60 Wind Vane Ducer E22078: Where is the best place to get a replacement paddl...
Go on www.raymarine.com and search for a dealer in your area and they will be able to help you. The wind service kit sells for less than $30.
May 17, 2010 | Raymarine St60 Wind Vane Ducer E22078
The self-closing valve on our 13 year old ST60 speed transducer now only closes sometimes when the blank or impellor sensor is removed. We suspect that a spring is missing. We need a raymarine spare part...
Spring not available must buy housing and replace or if it is sleeved, buy housing and slide in new sleeve there are two different types, one has a removable sleeve with flapper
A long shot would be Raymarine tech support 800-539-5539
I can sell you the part 847-746-0100 technicalmarine.com
Feb 20, 2010 | Raymarine St60 Plus Package, Includes...
I have a E22078 Wind Vane. How do I check the wiring continuity at the cockpit without climbing the mast? Can I use a multimeter to read impedance up to the wind instrument?
You can read the motor/generator windings with a volt ohm meater. Is it dc or ac? You should be able to read some voltage as long as it is turning? If it is a dc generator it will read dc voltage at the slightest of wind speed. If it is an ac generator it may have to be above 5 mph to get a reading. No reading could mean a broken wire.
Sep 10, 2009 | Raymarine St60 Wind Vane Ducer E22078
Screen fog
Hi there... mine did the same the very first morning I took it out. I rang and sent it to the manufactures. It was a very common thing and they fixed it within 10 days. I have not had a problem since. It should not of happened in the first place though. I have read a heap of forums on this exact matter and i think you would be the 10,000 person with this very problem. I have also had big problems with my transducer... so overall I am not impressed with Raymarine.
All the best mate.
Jan 02, 2009 | Raymarine Ds500x Color Fishfinder: Ds500x...
Raymarine ST50
Oct 19, 2008 | Raymarine ST60 A22012-P GPS Receiver
Raymarine ST60 A22012-P GPS Receiver Logo
174 people viewed this question
Top Raymarine GPS Experts
Steve
Steve
Jon Piercy
Are you a Raymarine GPS Expert? Answer questions, earn points and help others
