Question about Gateway Computers & Internet
Will not charge battery,have bought new battery, continues to go into not charging mode. Gateway model MA7 charger output 19.27v confirmed
If you are not getting any thing when just the charger is plugged in and either no battery or the battery is dead, but the system will run on a fully charged battery. There may be a problem with the motherboard that a DC jack replacement will not help.. some of the traces sandwiched in the mid-plain on the mother board might have corroded away and need to be bypassed .. check my blog for pictures on how this can be done. http://cegeekbook.blogspot.com/2010/07/gateway-ma7-mx6930-no-power-will-not.html
Posted on Jul 24, 2010
  • omarjorelhec Jun 14, 2011
    Hi, when you say " .. basicaly you need to short the center pin of the power jack to the closest chip on the system board... " what chip are you refering to?
  • 2,404 Answers
Sounds like either the power Jack on the motherboard is loose or the motherboard itself is bad.
The motherboard would have to be taken out of the laptop and where the power jack is, the solder points below it need to be resoldered so the connections are made properly and its nice and tight. If that doesn't fix the problem then the motherboard is bad. I would suggest taking the laptop to a repair shop cause the whole motherboard needs to be taken out and its alot of work.
Posted on May 11, 2010
Xantrex XPower PowerPack 300 will not charge even after replacing both battery and adapter. What else can I try?
Either charger has an issue or new battery is boogus. Check charger output for specs. Subject battery to a few discharge/charge cycles. If charger is definitely good and battery will not charge fully after a few cycles then you have confirmed that new battery is bogus.
Sep 06, 2017 | AMP Computers & Internet
Gateway T-6836 not charging
try to use another adaptor; with the same power
if the laptop steel not charge with the new adaptor; it can be battery or motherboard problem;
Feb 09, 2014 | Gateway T-6836 Notebook
Vectron wave toy doesn't charge
2Hz is probably the ripple current from the charger.
Apr 14, 2017 | Spinmaster Spin Master Air Hogs Vectron...
Battery is not charging with new adapter
Clean battery terminals with a stiff toothbrush, plus the new battery. If no change! charge circuits need to be checked for output voltage, if okay! new battery is defective, If no! the charge circuits in the motherboard are the issue "very rare"
Mar 18, 2012 | Gateway Computers & Internet
My NV5378u stopped charging, thought it was the charger wasn't,bought new battery, again does not charge, why
1)How to disassemble a Gateway NV52, NV53
http://youtu.be/ab0tt7LflHw
2)Gateway NV Laptop Repair Fix Disassembly Tutorial
http://youtu.be/f65ohS_EfdI
Dec 09, 2011 | Gateway NV5378u Notebook
Ericsson T28 Charging Issues? I have just received a refurbished Ericsson T28, I believe with a new battery, but when on charge the battery indicator flickers from 50% to 100% continuously but doesn't...
its the charger my phone did the same thing i did the same thing buy a new battery and try to charge it and did the same thing then i bought a new charger and it was charging good again but its the charger buy another one
Mar 21, 2011 | Sony Ericsson T28
My gateway netbook wont charge, they sent me a new battery but again it will not charge, what could be wrong?
The problem might be either from the charger or from the laptop.
To confirm and repair if it is the charger, all you have to do is to plug the charger on another laptop to see if it will charge, if it does not charge, then you know the fault is from the charger, and the solution is for you to replace it with a new one, before you replace it, try to connect another power cord to the charger, because sometimes the power cord might have been burnt, that have happened to me twice and replacing the power cord solved the problem. But if replacing the power cord does not help, then you need to change the power cord.
To confirm and repair if it is the laptop, plug in a new charger to the laptop, if it does not charge, then you need to understand that the charging port of the laptop is faulty and needs to be replaced, have a repairman replace the charging port for you.
Take care and good luck
Oct 31, 2010 | Gateway LT2021u Netbook
Every time i try to turn on my Gateway model MA7
  • the battery may need full charging, charge it for 4-5 hours, and it the problem persist it needs replacement.
  • for it works in power cord.
May 03, 2009 | Computers & Internet
1. isthe battery charging 2.isthe charger
You don't mention a make or model, so I can only give you general solutions. If the radio has a drop-in charger there may be a light to indicate charging. If the light comes on when the radio is in the charger, it's getting a charge. If you have a multimeter, DVM, or DC voltmeter you can check the battery voltage (charge) both before and after a charging cycle. You can also use the meter to confirm the output from the charger. If possible, replace the batteries with standard alkaline types and see if the radio works. I hope this info helps.
Bill B.
San Antonio
Apr 30, 2009 | Motorola Walkie Talkies 2-Way Radio
Computers & Internet Logo
549 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
