Question about Motorola Mobility RAZR V3
How do you fix the white screen on a motorola razr? I have tried to reset the battery and reboot the device, however, all i get is a white screen screen. The phone works find, just now display (very weak display, mostly a white screen). Thank you
  • 6,993 Answers
there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Good luck.
Posted on May 11, 2010
Service center philippines
Your cell phone failed to restart or unable to load os after reset, try to remove the battery and again place the battery after few minutes, then try to switch it on. If the same problem persists then visit motorola service center.
Jan 16, 2014 | Motorola Cell Phones
Verizon Razr V3 with locked screen. Verizon
yes ,down load p2k or another flashing utility,then flash your phone
Mar 11, 2010 | Motorola Mobility RAZR V3
I have a Motrola Razr V3a. Occasionaly the screen
there is a problem in the power strip of your phone take it to any of the servicing centres of motorola and get it fixed
Nov 15, 2009 | Motorola Mobility RAZR V3
Lost unlock code
Depending on how many modifications, hacks, or customizations that you perform on your Motorola RAZR V3 phone, there may be situations where the phone becomes unusable or completely locks up. I have had visitors to the site report not being able to delete ring tones, text messages, or have other strange behaviors with their Motorola RAZR V3 phone.
If this is you situation, then you may be interested in performing a master reset (or “hard reset”) on your phone. The master reset will effectively restore your phone back to the factory condition, inclusive of all settings. Be warned, any data that you have not backed up, photos you have not transferred, calendar settings, or messages you have not saved will be lost! Make sure you do this first, if possible!
Here is how you perform a Master Reset on the Motorola RAZR V3:
1. Open your phone up and go to “Settings”
2. Next go to the selection for “Initial Setup”
3. Next go to the selection for “Master Clear”
4. Then select to confirm the option.
5. Now enter the security code which should be “000000”
6. Finally press select or ok and the phone will reset itself to the factory condition
Congratulation you have performed a “hard reset”, “hard reboot”, or “master reset” on your Motorola V3 RAZR and it should return to normal operating mode!
Trackbacks that led to this post:
hard reset motorolla razr v3
hard reset razr phone
wii master reset
hard reboot motorazr
how to hard reset a razor v3
master reset code for motorola v3
master reset code razr v3
master reset for v3 via pc
master reset motorola razr 2
master reset v3 razr with white screen
motorola v3m master reset
p2k commander
razor master reset
razr 3 and how to reset
razr master reset ebay
razr master reset password
razr master restart
razr screen master reset
reset razr
reset razr to factory
reset razr v3 to factory
v3 hard reset razr
v3 razr reset hard boot
Jun 14, 2009 | Motorola Mobility RAZR V3
Screen won't turn off. Goes white
Have you tried turning your phone off and removing the battery.
leave your phone off for like 15-20 mins.
then replace your battery and wait 15 seconds before you turn it back on it should help you.
May 29, 2009 | Motorola Mobility RAZR V3
My motorola razr v3 screen keeps going all white!?!
first, make sure your Razr has no physical or water damage. If it's a T-Mobile phone, there will be a red sticker on the phone behind the battery. That indicates the phone as been exposed to water damage. Could mean the phone is shorting out on you. Now, I would suggest if the is NOT water damaged, to powercycle (turn off and on the phone) daily. Just off for about 30 seconds. Not long at all. If the white screen continues, do a master reset. Settings, -intial set up-master reset-code is 1234 or if you put in a different security code.
This will work!
Jan 29, 2009 | Motorola Mobility RAZR V3c Cellular Phone
Invalid battery
Pull out the battery *while the phone is on*. Wait 15 secs then put battery back in and turn phone on. That should fix it.
Nov 13, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Motorola RAzr V3 - screen went black but key pads lights up
replaced the flexcable on the phone to have it fix
Jun 29, 2008 | Motorola Mobility RAZR V3
White screen
The next time your driving down the road and this happens increase your speed to around 70 mph role your window down check the display to make sure it hasn't rebooted, then fling it at the next roadsign if it doen't cut through the sign and fix its self sue motorola's **** *** for false advertisment!!!**** them
May 23, 2008 | Motorola Mobility RAZR V3
Heeelllllpppp
try tking out the sim card and battery and restart it if tht dosent work try taking them out again and restet or keep them in and reset
Apr 11, 2008 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
262 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
