Question about HP Photosmart M525 Digital Camera
The on/off button - tiny plastic fulcrum that holds it in place inside the casing, broke off, and hp don't carry the part any more. The tiny plastic part is normally attached to the upper part of the on/off button, and is so small, that attempts to superglue it were unsuccessful.
    Brigadier General:
  • 3,006 Answers
Then unless you can fabricate a total replacement part (doesn't have to look good, just functional) then your camera is now junk.
Unfortunately, except for semi-professional models, cameras are simply not designed to be repaired so spare parts support is very poor. Budget models such as yours are really only expected to last a maximum of around three years, some even less. You'll find very few digital cameras of any kind which have not suffered a terminal fault after around six years.
Faults like the one which you have are very unfortunate, but if they were better made then they would cost far more; due to the rapid advance of digital photographic technology there's simply no way that mass consumers will pay more for a gadget which is soon outdated..
Posted on May 11, 2010
Tip
Leakage problem at the bottom? Toastess International Kettle Model: TJK-103...
Leakage problem at the bottom…
Model: TJK-103 120V, 60 Hz, 1500 W
She was complaining that our kettle was leaking a bit at the bottom.
Warranty is over.
Here is what I did to fix the problem.
Unplug the kettle and empty it completely.
Remove excess residual water inside.
Remove the bottom cover by removing the screws holding it.
Gently remove the plastic ring screwed in place.
Now you will be able to put your hand inside the kettle and push the bottom out, toward the outside of the unit.
Take out the rubber seal and clean it. Ours was full of fine residue…
Gently dry it out and lube it with tiny bit of silicon.
Clean the inside part of the kettle before putting everything back together.
Make sure that you don’t squeeze any wires inside.
With a lot of patience, put everything back in place.
Make sure that the seal is perfectly installed. You can see it looking trough the plastic.
Kettle is now fixed and she is happy! ;-)
on Jan 23, 2008 | Toastess The Storm Electric Kettle
Broken power switch Neon Sign
It should have plastic click locks or tabs, holding it together. place a butter knife or putty knife in seam and go around the edges and pry out while feeling for the location of tabs with another thin blade. Once located pry in to release snap locks.
May 25, 2014 | Neon Sign Inc Retail Supplies
Where is the reset switch?
To perform a firmware reset on the HP Photosmart R707 digital camera, open the battery/flash_memory door, and remove the battery and SD flash_memory card. With the front of the camera toward yourself, and upside down, look for a tiny screw next to the battery clasp (holds the battery in place). About 1/4" (6.0mm) to the right of that screw is a tiny hole with a reset button inside it. Gently push a paper clip into it. Some people may feel a very slight click. Hold the reset button for 6 seconds. Place the battery back into the camera, but not the SD card. Power on the camera. Exit the date/time menu. Power off the camera. Place the SD card in the camera. Power on the camera. The firmware is now reset.
May 29, 2012 | HP Photosmart R707 Digital Camera
Dyson DC 25 power switch replacement
It a fairly straightforward procedure. Remove the accessory hose to expose 4 torx screws from behind that hold the front switch cover in place. After removing the screws, gently pull the front switch cover and carefully pry two plastic tabs apart using a small screwdriver that "snap" cover in place. The switches will be exposed. The electrical connectors each have a tiny lock button at the base of the terminal that you need to push to remove. Otherwise they won't pull off easily. Assembly is reverse with one note: You'll have to hold the plastic cover and push buttons together so they don't fall out as you place the the cover back on. Once you get it on, the plastic tabs will hold until you install the torx screws. Be sure to retest the push buttons to make sure there was no binding in reassembly.
If I may add one more thing- I believe all DC25's carry a 5 year warranty and switch failure is covered. I replace these routinely. If you call Dyson, they will likely refer you to an authorized repair center for replacement at no charge.
Regards
Feb 16, 2012 | Vacuums
POWER BUTTON STUCK IN MOGEL # GFDN240ELWW
I took off the front panel by removing the philips head screw behind the control knob. The front control panel will lift straight up. Remove the 6 philips head screws which secure the control board to the inside panel. When you lift up this module you will see the power button. It is made from cheap plastic including the hinge. Only way to repair is to either super gluie the hinge or replace the entire control panel. I think this is an extremely poor design, especially coming from G.E.
Jul 24, 2011 | GE GFDN240ELWW Dryer
The locker (latch) on my microwave broke. We just got the replacement part in the mail. Sears says we should be able to replace it ourselves. I see no screws to get inside the door. Does the plastic flange...
If there are no screws to hold the inside door cover in place then they are probably using snap or lock in tabs around the edges to hold it
in place. You will have to disassemble the door to replace the door latch. ----------
Its a latch spring assembly.-------- Click this link below and follow the door lock latch replacing procedure:---- http://technoanswers.blogspot.com/2011/07/how-to-replace-door-lock-latch-on.html ------------------- This will help.Thanks.Helpmech.
Jul 14, 2011 | Microwave Ovens
The on/off switch does not return to the front when switched on. Seems as if the spring behind the button is weak
jnorsworthy I don't know if the design still holds the same for the Power On switch in the Slimline S3100N, as it does for the Power On switch designs I am used to.
[The Power On switch is located inside the plastic Power On button ]
The one I am used to;
1) Has a square block like shape.
2) The square block is composed of two halves. The two halves fit together like a clamshell.
A) A metal cover with a hole in the center for the top half.
B) A plastic block for the bottom half.
Inside there is a 'plunger', if you will.
The plunger, or post, moves up, and down.
The post is allowed to move up, and down through the hole in the top cover.
The plunger presses against a thin, flat, disk, convex shaped piece of spring metal.
The outside edges of the metal disk are connected to one side of the Soft Power On circuit.
As the plunger is moved down (By the action of pressing against the Power On button), the metal convex shaped disk flattens out.
In the center of the plastic base is the other side of the Soft Power On circuit. The center of the flattened out metal disk touches a contact in the bottom, of the plastic bottom half of the switch.
When the Power On button is released, the disk goes back to the convex shape.
This generic ATX power on switch, is an example of the type of Power On switch I am referring to,
http://www.directron.com/atxswitch.html
You may find the above generic example is a replacement for the one in the Slimline S3100N.
This is HP Support, the support page for the HP Slimline S3100N desktop computer, and the Manuals page,
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&lang=en&product=3440586&
On the above page scroll down to the heading - Upgrading and Servicing Guide, and left-click on it.
(It's a PDF file, and may take a few seconds to download. May take a few seconds before you see the first page)
Shows how to open the computer case, and remove the Front Panel. (Front Bezel)
Computer unplugged from power, Observe Anti-Static Precautions.
Anti-Static Precautions:
Your body carries Static electricity.
Static WILL fry out (Short Circuit) the hardware components inside a computer.
1) Work on a table
2) Computer unplugged from power, computer case open
3) TOUCH the metal frame of the open computer case to relieve your body of Static
4) If you leave your computer in the middle of working on it, be SURE to touch the metal frame again upon your return.
Most Power On button assemblies have two tabs, or three, that protrude out from the body of the assembly. These tabs snap into place into the metal frame of the computer case, and into a rectangular hole. They have a hook on one side. Gently squeeze the tabs in, or out. Depends on which way the hooks face.
The plastic Power On button assembly generally has tabs that hold the Power On switch in place. These tabs are eased over to allow removing the Power On switch. You may find that the plastic tabs are brittle due to age, and the heat inside the computer through the years.
You can use a hair dryer set to low heat, and wave the hair dryer slowly back, and forth to soften the plastic.
Motherboard information:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00910076&lc=en&dlc=en&cc=us&product=3440586#N421
Oct 08, 2010 | HP Hewlett Packard Pavilion Slimline...
Replace on/off switch dimension 8200?
The On/Off switch is the Power On switch.
The switch itself is tiny, and is located inside the plastic Power On button assembly.
There are plastic tangs on the Power On button, which hold the switch in place.
I use a hair dryer set on low heat, to gently heat the tangs so they will spread easily, to remove the switch. (Move the hair dryer slowly back, and forth)
You can also set the Power On assembly in a bowl of Very warm water, to temporarily soften the tangs.
(The switch is no good anyway. Dry the plastic Power on assembly before installing the new switch)
This switch is usually a replacement,
To remove the Power On button assembly the computer case is opened.
BEFORE you start, the computer Must be unplugged from power, and you should observe anti-static precautions.
Your body carries Static electricity. Static will fry out (Short Circuit) the components inside a computer.
You can either,
1) Buy a $6 ESD wrist strap, connect the wrist band to your wrist, and connect the alligator clip to the metal frame of the open computer case,
OR,
2) You simply touch the metal frame of the open computer case to relieve your body of static.
(Again, computer unplugged from power.
Also, IF you get up, and walk away, when you return TOUCH the metal frame again)
This is Dell Support, and the Service Manual for the Dell Dimension 8200 desktop computer,
http://support.dell.com/support/edocs/systems/dim8200/
To open the computer case:
Click on Opening the Computer Cover
The computer cover opens like a clamshell.
Observe where the cables (Wires) go to the motherboard, from the Front of the computer case.
You may wish to make a drawing, and notes.
Dell DOES NOT state where the wires go.
If any wires are accidentally bumped loose, you will have a schematic made by you, of where they go.
As you proceed, state any problems you are having, and let's see if I can rectify them with information. Simply state in a Comment.
May 03, 2010 | Dell Dimension 8200 PC Desktop
Cover card open when it's shut
This problem is caused by the little piece of plastic that you flip down to hold the XD card in place. It has a nipple sticking out of it that is prone to breaking off. Unfortunately, this nipple (about 1/16" x 1/8" x 1/8") holds down a little button which tells the camera that the the plastic piece has been flipped down. Once the nipple breaks off, you need to find some other way to hold the button down.
I simply took a small plastic peg from an old boardgame -- a cribbage-board peg might work -- and whittled it down to fit the opening. Remove the XD card and you'll see the small 1/16" x 1/8" rectangular opening. There's a tiny, squarish black button inside. Use a toothpick or tiny screwdriver to carefully press the button in while the camera is on, and you'll see the error message disappear.
Once you get the idea, use a tiny Phillips screwdriver to remove the plastic piece that you flip down. There are two screws to remove, two little metal retaining brackets and a tiny metal rod. Be careful not to lose any of these pieces! Then gradually whittle your piece of plastic so it fits the rectangular opening snugly, and consistently turns off the error message. Then cut it to about 1/8" in length, insert it into the opening, and reassemble the rod, brackets and screws to hold it in place.
Now the little button will always be pushed in and the camera will be functional once again. Since the XD card has its own spring-loaded "locking mechanism" (you push to insert and push to remove), the piece of plastic you flip down isn't really needed in the first place. You can save it, anyway, just for the memories....
Apr 05, 2008 | Olympus Stylus Verve S / ?-181 mini S...
HP Photosmart M525 Digital Camera Logo
130 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
