Question about Frigidaire Dryers
Dryer will not turn on, the start knob makes a quiet noise, but does not start. The belt is still connected, could it be the start switch or worse the motor?
  • Frigidaire Master
  • 8,220 Answers
Dryer will not turn on, the start knob makes a - 0720456.jpgThermal fuse is locatedupeer right hand corner of rear bulkhead. Look for air restrictions and correct that before replacing the fuse. More HERE
Posted on May 11, 2010
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
Whirlpool dryer won't turn on can hear
The switch you speak of is a mechanical switch with electrical contacts. If the spring inside gets rusty, it doesn't turn properly....replace it!
Dec 26, 2012 | Whirlpool Dryers
Dryer will not turn on. When I turn the knob, it makes a "buzzing" noise but will not switch on. Was working very well until now. Frigidaire Crown Series. FDEB23RG52
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 05, 2011 | Dryers
I turn the start knob and it just makes a buzzing sound
heatman101
Jun 06, 2010 | GE DBSR453EBWW Electric Dryer
When I turn the cycle control knob it no longer makes a noise
heatman101
fg
May 30, 2010 | LG DLG7188 Gas Dryer
Buzzing noise when i turn the timer switch
heatman101
Oct 06, 2009 | Bosch Nexxt WTMC 3300 Electric Dryer
My Maytaag dryer has a loud intermittent squeal. It will often work for 10-15 minutes with a quiet squieak or no noise, then the loud squeak starts up. I can turn the dryer off, but the squeal immidately...
I think the drum drive belt is slipping because it occurs more with a large load. Other possibilities are: A drum support wheel bearing could need lubrication or be replaced. Also some drum support wheels have a rubber coating that wears off causing misalignment and noise. Possibly drum gasket (sometimes felt material) where drum meets rear panel is worn allowing metal-to-metal contact--should be replaced. See the following for info about dryer repair including belt replacement:http://home.howstuffworks.com/how-to-repair-a-dryer.htm
Sep 21, 2009 | Dryers
I push the start knob and it makes a noise but does not start. It is a Kenmore 96281800 electric dryer.
Your belt is broken and the tub is not allowing the switch to remain on. If you take the top panel off you will see that the belt is broken.
Jun 24, 2009 | Kenmore 63942 Dryer
Fridiaire dryer not turning on (another ??)
Yes, I had the same issue. If I slam the door shut very hard then it would work. So I found the issue is the door safety switch not turning on when the door is closed. Simple fix is to put some masking or duct tape on the door so that it would push the switch when the door shuts. There is an indentation in the door in the top left corner where the door contacts the switch. This causes the door to not turn the safety switch on when closed. Simply fill in the indentation with a little tape and problem solved.
Jul 05, 2008 | Dryers
your drive belt is broke. remove the front panel and then the top panel and you will see there is no belt around the drum.
Dryers Logo
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
