Question about Canon LCD PROJECTOR Multimedia Projector
LV-S2 My projector fires up fine, all the LED's come on and the fan powers up. But, I get NO light at all. I was sure it was the lamp, so I ordered a new one. Still no light. Just to be sure, I took the lamp out of a working projector and installed it. Still no Light! Dark as night. Any ideas? Thanking you in advance.
  • 115 Answers
Sir, The ballast unit of the projector is faulty which gives supply to the lamp unit. Open and check the smps with Ballast unit.
Posted on Mar 29, 2008
    Scholar:
  • 40 Answers
This a case of a faulty projector and needs either a replacement if within the warranty period or get repaired by a service center
Posted on Jun 17, 2008
Why would my projector refuse to start with a seemingly intact light bulb?
If you only have 300 hours on it it should still be under warranty. Before doing something to void that I would check with Optoma techs.
Jul 23, 2014 | Optoma HD20 DLP Projector
Canon lv- x5
1,Check the fans ,whether each fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Lampdeng Limited
Jerry
Jan 15, 2014 | Canon LV-LP12 Projector Lamp for LV-S1,...
Canon LV-S1 projector keeps shutting down after a minute or less
Jul 15, 2012 | Canon LV-LP12 Projector Lamp for LV-S1,...
I have a Canon LV-7350 that comes on for 15 secs then turns off.. everything is hooked up correctly. and I have swiched out the bulb to rule that out.. anyone ever seen this?
Hello :
It must be overheating problem . Check the fans . If the fans run properly , then you need to check the fuse or the power PCB [printed circuit board ] . If everything is okay with all of those , then I recommend you to replace the bulb .
Here I'll tell you how to replace it :
  1. Make sure that your power switch is off and that the power cord is unplugged from the electrical socket.
    It is also wise to unplug any other cables and label them in order to restore them in the right way once the lamp is replaced.
  2. In order to see the lamp, remove the access handle on the outside cover. You may need to use a screwdriver.
  3. Pull out the used lamp and clean the relevant parts using micro fiber products and not paper.
    Please note that in some projectors a small inside filter should also be replaced.
  4. Insert the new lamp into the projector carefully avoiding touching the glass of the lamp itself.
    Touching the lamp will deposit skin oil that will likely damage any new lamp during use.
  5. Reassemble the access panel, repluge the cables and power up the projector.
Things You'll Need:
Warning:
  • avoid touching the bare projector lamp
please rate !.
Apr 12, 2010 | Canon LV 7350 Multimedia Projector
Failed to lights up lamp?
check the lamp for bulges, black spots or fogging, and replace as necessary. if lamp is ok, replace the ballast.
Dec 28, 2009 | Canon LV-S2 Multimedia Projector
Projector won't power on. Plug it is and all I get
the lamp is past 2000 hours and needs replacing and the timer needs resetting.
Aug 17, 2009 | Canon LV-S2 Multimedia Projector
Canon LV-S1 New bulb but won't power up
Have you cleaned the filters? In this situation, the fan and power shuts down even before the bulb lights up and heats up the unit, but perhaps the unit can detect clogged filters.
You can download the manual here if you don't have one. Instructions for cleaning the filters are on page 37.
May 20, 2008 | Canon LV-LP12 Projector Lamp for LV-S1,...
InFocus LP725 light goes out after 10 minutes
The Projector will turn off after so many hours of running the same bulb module. The counter will turn on a replace bulb LED. Installing the new bulb module should reset the counter and turn off the LED.
Check the projector’s lamp to ensure that it is securely connected
in the lamp module. Make sure by removing it and reinserting it.
Check the cables for problems.
When testing, power up in this order. Projector, Computer monitor, Computer.
A minor power surge may cause the lamp to shut off. Turn the
projector off, wait at least 30 seconds, then turn it back on.
I hope these suggestions help
Feb 02, 2008 | InFocus LP725 and LP735 Replacement...
Cannot reset projector after new lamp installed
hi
Have you reset the lamp timer after replacing the lamp, if not then do so and see the user manual for that.
Viren
Jan 24, 2008 | Canon LV-LP12 Projector Lamp for LV-S1,...
Lamp problem
Could be an overheat problem, check any fans and filters are not clogged with dust, lack of ventilation and cooling will trigger a safety shutdown
Feb 06, 2007 | Canon LV-LP11 Projector Lamp for LV-7345,...
Canon LCD PROJECTOR Multimedia Projector Logo
177 people viewed this question
old marine
old marine
