Question about Sony STR-DG820 Receiver
Display shuts off after a few seconds
Display comes on when input something, but shuts off after a few seconds. I want it on all the time. I believe my FIL did something to it while babysitting, but I have no idea how to fix it.
  • acbrodie May 12, 2010
    There's no dimmer button anywhere.
  • 757 Answers
Look on the front panel of the receiver or on the remote for a button labeled "dimmer". Press it repeatedly until the display shows at a brightness level that you prefer.
Posted on May 11, 2010
HK DPR 2005 is shutting off by itself after running for about 5 seconds
when you connect any device you should always have the power off. if you connect while power is on you will blow that input up after time. sorry for the bad news
Apr 13, 2014 | Harman Kardon DPR 2005 Receiver
Sony Bravia KDL-46NX810 shuts off with 3D input only
Well written question but I would first call Sony Customer service to see if known issue or if the data base shows any reports or recalls for this issue.......
Oct 29, 2012 | Sony KDL-46NX810 46 in. 3D LCD TV
Tv comes on only for a few seconds then shuts off
Something is getting heated up inside and might need servicing. I suggest not to keep using the TV as this might damage more parts.
Aug 25, 2012 | Sansui HDLCD-1900 19 in. LCD Television
Mitsubishi WS-65908 will not stay on
Its a color convergence problem from description:
If green light comes on for a few seconds and goes off:
On the front of the set (not the remote) press and hold both the menu and input (device) buttons at the same time for at least 5 seconds and release both.
Watch power light: it will blink a two digit error code, in your case I suspect it will be 2 blinks, 2 blinks and repeat several times.
Let me know error code and I will help.
Apr 16, 2012 | Televison & Video
I have this model and its been giving me probem with the picture coming on and if it came on only half the picture come on
It sounds like the inverter board for that side of set is bad(uses either one large or two small boards--if two small the one for that side is bad OR the main display panel itself is bad.
Seen more than a few of this brand come on with picture on one side and then the other side gets real bright for a few seconds and set shuts down.
Shutdown circuit will detect something is drawing a lot of current and shut set off.
This if the display panel itself is bad will not be worth fixing.
Some Plasma sets have same issue and use names like sustain board etc for the same function--they drive the display panel left side, right side or top and bottom.
Apr 12, 2012 | Philips 47PFL7403D 47 in. LCD TV
Hi there, everything seems to be working but there doesn't seem to be a signal going to the TV. Am just about to try using a HDMI cable. Do you think this will help?
What I did was initally hook up both the composite (R/W/Y) cables and the HDMI and switched between TV inputs until I found the display. Once I had the display (mine was on composite) I went to the settings, then display, and switched it to HDMI input. The screen went blank and I switched to my HDMI TV input and saw the display. I unplugged the composite and it was good to go. I also had to hold my finger over the power button for a few seconds when turning it on - I believe it resets the display to default, but it worked. Good luck!
In the event that it gives you a hard drive error shortly after, it's nothing to worry about. You won't lose anything and it will take a few minutes to run its course. Just make sure you never turn it off from the back of the system first, always shut it off via menu options.
Respectfully,
Don
Jun 02, 2010 | Sony Playstation 3 (PS3) Console
Vizio vx42l hdtv back light
If backlight went out then sound should still work. Are there any indicator lights to show power is coming on anymore? Try unplugging for 30 seconds, hit power button a few times, then plug back in and try to turn on. This drains any capacitors of power to attempt to reset (basically clearing the TV's throat).
Can also try something on a different input. If current input is composite, S-video, or component, try using DVI or HDMI connection as this uses a different board in the TV. If that fixes it, then at least you can try to replace one board instead of entire tv. :)
Apr 06, 2009 | Vizio VX42L 42 in. LCD TV
I have just purchased a Nvidia Geforoce fx5200 128MB 64Bit ddr tv/dvi card. I Have a E Systems203A tower and running windows XP. When I install the card and boot up the monitor comes on then shuts down...
After the display card is installed go to the bios setup and seletc the display card as first device. boot the system and right click My Computer +Properties + Hardware + Device Manager ( and in Display Adaptor Disable the device which you do not want to use. once done you will find the display.
Dec 14, 2008 | Computers & Internet
Jetway 15" m onitor
check your wire connectors if they are not messed up, or it might be something internal i believe you should return it where you bought it
Apr 11, 2007 | Jetway M1531S 15" Flat Panel LCD Monitor
Open Questions:
See all Sony STR-DG820 Receiver Questions
Sony STR-DG820 Receiver Logo
117 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
