Question about NAD T752 Receiver
OSD for NAD T752
I can't seem to get the On Screen Display Menu to come up. I have the monitor out connected to video in on the TV. I have tried both Svideo and component connections. I do get a blue screen and the TV auto detects a signal but all I get is a blue screen. No menu options.
The blue screen indicates a proper connection (signal received by the monitor). Try selecting "amp" on your HTR 2 remote then use any directional button at the center of the remote, the keys which circle the "Enter" button. Hopefully you will then see the menu appear. Use the same directional keys to navigate the menus.
Posted on May 11, 2008
NAD T752 display totally lit up. FM sound works but no frequency display.
Sounds like display driver board {IC} has damaged. Contact any service technician. Electro help
Dec 08, 2014 | NAD T752 A/v Surround Sound Receiver
Tip
Diagnosing video problems on TVs and monitors
The first thing to always check is the MENU (osd - on screen display)
Push menu or display on your tv or monitor
- if the menu is clear, the problem is in the early stages of video or outside your device (could be the source (dvd, cablebox) or input connections
- if the menu is distorted, the problem is definitely a malfunction with your device the osd is generated from (tv menu distorted = 100% tv is problem)
* you can also use other OSD signals to troubleshoot - if the volume bar or display info (input label, info bar) is clear, problems are earlier in the circuitry or outside the device. don't be fooled by translucent menus or cablebox menus.
** osd is inserted in the picture in the later stages of video processing. if your osd is distored, suspect the circuitry after the video switch. this could be a bad LVDS cable, TCON or Logic board, or even a bad lcd panel, plasma panel, crt.
on May 21, 2010 | Televison & Video
"OSD LOCKED" box on my screen
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
* If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
OSD stands for "On Screen Display." It is an onscreen configuration menu included with various monitors. When you press the MENU button or one of the other buttons on the front or side of a monitor, the onscreen display may appear. The OSD typically includes monitor calibration options, such as brightness, contrast, and color adjustments. Some OSDs may also include horizontal and vertical position controls as well as tilt and keystone adjustments.
If you can't make adjustments to the monitor settings using the OSD interface, the onscreen display may be locked. You may also see the phrase "OSD Locked" appear when you try to change the settings. Some monitors include an option within the menu called "OSD Lock", which you can turn on or off. If this option is available, simply turn OSD Lock off and you will be able to make adjustments to the settings.
If your monitor does not include the "OSD Lock" option, you may be able to unlock the OSD by pressing and holding the MENU button on the front or side of the monitor for several seconds. If you try this method, be patient! It may take up to 15 seconds for the OSD to unlock.
VOTE ME
Dec 07, 2010 | Dell Computers & Internet
Unable to adjust the settings for brightness and contrast .
To adjust the display settings:
1. Press the flywheel control. The main menu appears.
The current display settings appear across the top of the main menu.
2. Rotate the flywheel to highlight an option. The name of the
highlighted option appears in the center of the menu.
3. Press the flywheel control to select the highlighted option, then
rotate the flywheel to adjust it.
Some options can only be enabled or disabled. There are also some
options that contain additional menus.
4. Repeat Steps 2 and 3 until you have made all your changes.
5. Rotate the flywheel control until Exit is highlighted, then press
it to exit the OSD control system.
OSD OPTIONS:
Contrast increases or decreases display image contrast.
Brightness increases or decreases display image brightness.
Horizontal Size increases or decreases the width of the display image.
Horizontal Position moves display image to the left or right side of
the screen.
Vertical Size increases or decreases the height of the display image.
Vertical Position moves display image to the top or bottom of the
screen,
Pincushion curves the sides of the display image inward or outward.
Trapezoid increases or decreases the trapezoid distortion of the
display image.
Degauss removes magnetic discoloration from the display image.
Recall returns most options to the original factory default settings
if the monitor is currently using a preset video mode. (See the “Video
modes” section in this guide for information about the factory preset
modes.)
Advanced Option opens the Advanced Option menu. Color opens the Color
Manager menu.
Language changes the display language for the OSD control system.
User displays information about the monitor’s preset modes.
OSD Manager moves the OSD control window on the screen.
Exit closes OSD control system.
Jun 21, 2010 | Gateway EV 910 19" CRT Monitor
When i press the power button to turn off monitor, i get a power button lockout message. how do i unlock the power button
I did not see anything regarding to the Power locked out function, may be it's time to call HP. Please post back what you find out from HP.
I look at HP WEBSITE: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01632269&tmp_track_link=ot_recdoc/c01643091/en_us/c01632269/loc:1&lc=en&dlc=en&cc=us&product=3770762
Locking OSD settings
When the OSD is locked, settings cannot be changed in the OSD menu. The OSD functionality is enabled or disabled by pressing the Menu button and holding it for 10 seconds. Upon disabling the OSD, an OSD Lock-out message is displayed for 10 seconds. When the OSD is locked and an OSD menu button is pressed, the OSD Lock-out message is displayed for an additional 10 seconds. When the OSD is locked, pressing the OSD menu button for 10 seconds unlocks the OSD and displays the main menu. Identifying monitor conditions
Special messages display on the monitor screen for the following monitor conditions:
  • Input Signal Out of Range : Indicates the monitor does not support the input signal because the resolution and/or refresh rate are set higher than the monitor supports. Recommended refresh rates are as follows:
    • For the w1858 monitor: 1366 x 768 @ 60 Hz.
    • For the w2338h monitor: 1920 x 1080 @ 60 Hz.
  • Monitor Going to Sleep : Indicates the screen display is entering a sleep mode.
  • Check Video Cable : Indicates a video input cable is not properly connected to the computer or monitor.
  • OSD Lock-out : When the OSD is locked, the warning message OSD Lock displays for 10 seconds.
  • No Input Signal : Indicates the monitor is not receiving a video signal from the computer on the monitor video input connector. Check whether the computer or input signal source is off or in the power-save mode.
  • Auto Adjustment in Progress : Indicates the auto-adjustment function is active and in process.
May 13, 2010 | Computers & Internet
How do I get the " OSD" to work!
Make sure that you are selecting the correct input on the TV for which input you are plugging the receiver into. Then press the OSD button on the receiver remote. If that doesn't work, try plugging the S video into a different video input, or use a different video input cable such as from the composite connection of the monitor out. Some reasons for having to do it this way is that some televisions may give priority to one input of identical type which is usually S video. For example if you are using the S video input on the front of the TV with a different device and then plug another S video cable to another input elsewhere on the TV, it may only display the picture through the S video on one input because it is using the same circuitry for both S video inputs and can't display picture from both of them simultaneously nor can you toggle between them even if the other device is not turned on. HOWEVER, there MAY be a way around this as well...try your picture-in-picture (PIP) and toggle to the PIP input that your receiver is plugged into. Still then if that doesn't provide you with the OSD of the receiver menu, then just change one of your S video inputs to a composite input.
Jan 09, 2010 | Yamaha HTR-5280 Receiver
Denon 3600 osd
So I presume you haven't done ANY setup as the OSD is necessary for all of it.
Somwehere in the manual it probably says to run a single RCA video connection from MONITOR to a suitable Video input on the TV. How your TV works is anyone's guess. Select the appropriate input.
The manual probably discusses SETUP and how to initiate it.
Jan 11, 2009 | Bose 901 VI Main / Stereo Speaker
No OSD on TV connected thru composite video (Monitor Out)
hello you need the s-video/sound usually four pins in each end connect to s-video not composite video..saludos
Nov 22, 2008 | Onkyo TX-SR606 Receiver
OSD not working (black screen)
Your 635 will not display the OSD screen through component. You must use either s-video or rca. It won't upconvert the screen menu this route.
I had one up until a week ago. There are two outputs on the back specifically for the OSD screen. I used a separate old 13" TV with s-video to do my setups. Hope this helps.
Sep 04, 2008 | Harman Kardon AVR 635 Receiver
NAD T752 Receiver Logo
781 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
