Question about Whirlpool Washing Machines
I have a Whirlpool Cabrio washing machine, M# WTW6400SW2. What does an F1 mean? and what is the correct repair?
  • 15,935 Answers
A fault code of "F" then "1" flashes when there is a primary control failure.
You will need to replace the machine/motor control assembly. Page 14 and 16, in the manual HERE will help you with this.
First unplug the machine for 20 minutes (minimum) to attempt to reset the board.
Thanks for using FixYa!!
Posted on May 11, 2010
What does an F-1 code mean on the display? washer will not start.
power problem
  • Whirlpool Fault Codes - AppliancePartsPros.com www.appliancepartspros.com > Appliance Repair Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • Washer Diagnostic& Repair - F1 Error Code power supply ... www.youtube.com/watch?v=BAVS9mI3JLQ
    • BY APPLIANCEVIDEO.COM
    • 4 MIN
    • 65K VIEWS
    2014-02-07 · Troubleshoot your trusty Whirlpool Top Load Washer that has these following symptoms: F1 Error Code At: http://www.appliancevideo.com To ...
  • Whirlpool Cabrio f1 error and how to fix it https://whirlpoolcabriof1error.wordpress.com Control board W10189966 will work with the Whirlpool model numbers listed at the bottom of this page. These models include the Maytag Bravos and Kenmore Oasis.
  • whirlpool F1 code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • 68 POSTS
    • FIRST POST: 2008-07-28
    2009-09-29 · Discuss whirlpool F1 code in Washer Repair. "whirlpool cabrio washing machine displays f1 code. have already pushed cancel and restart to no avail.
  • Cabrio Washer by Whirlpool F1 Error Code - Facebook www.facebook.com/CabrioWasherByWhirlpoolF1ErrorCode Cabrio Washer by Whirlpool F1 Error Code. 793 likes. Got the F1 Error Code? Tell your story! Share ALL your issues with this washer to warn others...
  • Whirlpool Fault Codes - Appliance Help Online appliancehelponline.com/whirlpool.html Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • May 04, 2016 | Whirlpool WTW8200YW Cabrio Top Load Washer
    My Whirlpool Cabrio (Model Number: WTW6400SW2) washing machine gets an F1 error signal 5 seconds after I power it on to wash something, I have to pause it and then restart it for it to work,
    Your machine needs a new control. The F1 code is an error within the main machine control, and it will only get worse the longer it goes. CLICK HERE for the part. Using coupon code 1050 will get you a discount on the part!
    Jan 12, 2011 | Whirlpool Washing Machines
    What does code f1 mean
    Hello
    Error code F1 means that the control of washer has either gone bad or about to go bad. This is a common issue with Whirlpool Cabrio washers. I have also seen them replacing the control without any charge, don't really know about the labor charges but they usually won't charge for the part. Please get back to me if you have any other questions.
    Kevin
    Nov 16, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    What does the code F1 mean?? We seem to be getting it a lot when starting a load
    The "F1" error code on the Whirlpool cabrio is quite common, and generally has to do with the control board. Replacing the control panel may resolve this issue. However, I believe Whirlpool is aware of the F1 issue with the Cabrio, and is fixing some machines for free. Please call 1-800-253-1301 for more details and see if you are eligible for a free repair.
    Thank you !!
    Jul 29, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    I have a cabrio purchased in dec of 2007.. model
    Hi
    Thanks for using FixYa. Yes you are right you can call 1-800-253-1301 whirlpool will send a tech. to fix it and pay for the part. Error F1 means primary control failure and to resolve this you’ll have to replace the machine control assembly. Please do rate the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
    Jun 05, 2010 | Whirlpool WTW6400SW Cabrio Washer
    My Whirlpool Cabrio WTW6400SW2 has a F50 error. I
    LOOK ON WIRLPOOL.COM AND LOOK UP CODES HIT THE CLEAR BUTTEN FOF35 SEC
    Apr 03, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    F1 code whirlpool
    whirlpool F1 code - Appliance Repair Forum THERE IS A RECALL ON YOUR WASHER,CALL THE FACTORY AND GET IT FIXED FOR FREE
    Dec 11, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
    F1 error on Whirlpool cabrio
    it means that the control board is not sensing the water pressure (this tells the machine how much water to put in the washer) in my experience you have to replace the control board which will cost over 200 plus labor which will be over a 100
    Dec 23, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
    Whirlpool Cabrio Washer Error message code F1
    f1 code means the main control needs to be replaced. pretty common repair
    Dec 12, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
    Washing Machines Logo
    89 people viewed this question
    Sal De
    Gerry Harvey
    Gerry Harvey
