Question about Speedo Aquabeat MP3 Player i
I just bought a brand new aquabeat, after transferring songs and charging it, the instruction says press the "ff" button and hold til the LED lights turn green to turn it on. I pressed it and at first it was orange then green but i did not hear any beep and as soon as i let go of the button the green light went off and there was no music
    Problem Solver:
  • 5 Answers
Try checking out www.speedoaquabeat.com. They have a troubleshooting section and links to customer support. It helped me.
Posted on May 23, 2010
How do i get the PMP80-4 to shuffle through the songs. Is there an instruction manual?
There is a led light in the upper right corner of the front. The controls are on the large round button in the center. To turn in on, press in the center of the button; the device will turn on and playback will begin. To turn it off, press AND HOLD the center of the button until the LED light flashes several times and then turns off.
To play, press the center of the button and the LED should come on and stay solid. To pause, press the center and the LED will blink once a second Press again and playback will resume.
Think of the big button as a clock face. Press at 12 for volume UP. Press at 3 for next track; HOLD for fast forward. Press at 6 for volume DOWN. Press at 9 for previous track; HOLD for rewind.
For shuffle, press at 12 and 6 together and hold for 2 full seconds. The LED will flash 4 times to show you are in shuffle mode. To go back to normal playback, press at 12 and 6 together for 2 full seconds and the LED will flash 2 times to show you are back to normal mode.
Feb 22, 2014 | Polaroid Shuffle MP3 Player
Speedo aquabeat 3g mp3 player is not charging. The LED light turns to green, but when I unplug it it won't work.
You are plugging the headphones into the unit and then trying to power up the unit, correct? The Aquabeat will not power up unless the headphones are connected to the unit and disconnecting them will shut the unit off.
Feb 19, 2010 | Speedo Aquabeat MP3 Player i
I've recently installed a new Brother toner, but the drum light is flashing and the Brother hl 5140 printer won't print
DRUM UNIT "spent"
It can be reset if the printing quality is good
To reset the drum follow the instructions below:
Press the cover release button and then open the front cover of the printer.
Press and hold down Go button until all 4 LEDs are lit. Once all 4 LEDs are lit, release the Go button.
Close the front cover.
Make sure that the Drum LED is now off.
Caution: Reset the drum counter only when you replaced the drum unit with a new one.
Oct 09, 2009 | Brother HL 5140 Laser Printer
Resetting the Drum counter on a Brother HL-2040
Hi.
Have you recently replaced the drum?
  • The Drum LED blinks if the drum unit is near the end of its life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one.
  • The Drum LED continues to blink if the drum counter was not reset when you replaced the drum. To reset the drum follow the instructions below:
  1. Open the front cover of the printer.
  2. Press and hold down Go button for about 4 seconds until al the LEDs light up. Once all 4 LEDs are lit, release the Go button.
  3. Close the front cover.
Aug 03, 2009 | Brother HL-2040 Laser Printer
Speedo aquabeat not playing
have you checked the volume level to make sure that it was not lowered by mistake? Just a thought.
Aug 01, 2009 | Speedo 7410061 MP3 Player
2 brand new, will not power up, fully charged, full of songs.
Did you remove protective packaging on batteries?
Jun 28, 2009 | Samsung YP-U3 MP3 Player
How to set the clock on the car stereo (Naxa nx-670)
I had the same issue. I bought my 671 mp3 car stereo from jujudeals.com and I was having the same problem. I called them up and they said that I have to go to clock mode. When in 'Clock Mode' you have to press and hold Select (SEL) and at the same time press FF/REV to adjust time. (Fast Forward adjusts hour, Rewind adjusts minute). If your still having problems contact the Naxa Electronics warranty department. Goodluck!
Jan 17, 2009 | Naxa Electronics NX-671 Car CD/ MP3 Player
Kidz Remote
RE: Programming a Kidz Remote by Kissel By helpmedave (Guest Post) 1x1.gifthe procedure to program the remote is as follows.
Find the setup button recessed between tv and cable buttons. Use a toothpick to press the setup button until the led blinks once, keep holding it until it blinks twice then release. press tv or cable button then enter the 3 digit code for the device you want to try. the light will blink twice if the code is valid. ( yeah i know you don't have the codes ) (me neither ) if you successsfully program it to control a device, you can then program each button as follows. hold setup button until light blinks twice.press tv or cable as needed. press 995 the led will blink twice . press the button to program. enter channel number you want (may have to enter 2 or 3 digits 08 008 etc)press setup light will blink once.m select another button and repeat to program all buttons you wish to program.to lock in settings, press setup until led blinks twice. good luck.Posted on 08/09/2007
Jul 16, 2008 | Televison & Video
I got my ipod locked its showing lock sign .
Is it a press and hold button to unlock or a slide switch, if it's a press and hold you may need to just press and hold the play button til the lock icon disappears.
Jan 19, 2008 | Apple iPod 4th Generation MP3 Player
Speedo Aquabeat MP3 Player i Logo
769 people viewed this question
Top Speedo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Speedo Audio Player and Recorder Expert? Answer questions, earn points and help others
