Question about Sewing Machines
Babylock ellegante threading problems
I cannot get the thread to feed into the auto threader it is like something is too tight. i have took it apart and looked at it but cannot figure out how to fix it.
  • randyab Sep 30, 2008
    Our Ellegante' has had threading problems since we purchased it new. Sometimes it would thread, sometimes not. Then very often it breaks the thread during embroidery or sewing. We also get a "grinding" sound from the auto threading unit from time to time when it doesn't thread. This machine has actually been back to the BabyLock factory and they kept it for 2 months, it failed to function properly after only a few embroidery patterns. We are currently working with the distributor to solve this problem. We are thinking it is a design flaw in the machine.
    Nancy and Randy Abernathy
  • 106 Answers
It is something I cannot explain how to do on here, you need to be shown, would suggest you get in touch with a sewing machine tech.
Posted on Mar 28, 2008
Ellegante 2
try to search on www.ebay.com with part name and machine model
Apr 12, 2014 | Sewing Machines
Babylock ellegante 2
Threads bits/dust has accumulated at top thread sensor or the sensor need to be replaced
Oct 30, 2013 | Baby Lock Ellure
How do you replace throat plate on Babylock Imagine Wave serger
I had to replace the Needle Plate on my Babylock Ellegante machine and when I turned on the machine it told me to Turn off power and replace the Needle Plate. which I had already done. How do I fix that so I can sew. thanks Jan billawp@tds.net
Jul 14, 2012 | Sewing Machines
My serger, Babylock Imagine's looper threads are too tight. I have tried rethreading, adjusting the fine tuning screw and varying stitch lengths and widths. At the recommended setting for the 3 thread...
I am having this same problem today. The needle threads when pressed look almost like a flatlock stitch. There seems to be no tension. With BabyLock's auto tension system, I have no idea what to do. I've been on the phone with my dealer about this today and he is clueless as to what may be causing it. I guess it's time for a checkup.
Sep 07, 2010 | Baby Lock Imagine
AUTO THREADER CAME OUT
When you activated the threader, the needle was down and the threader came off or broke.
If it is not broken, you may be able to push it back into place.
Turn off the power and tip the machine back on some towels so it does not slip and with a flash light check the area where it fits and see if you can get it back into position.
If not, will have to thread the needle the old fashion way.
Check with your Brother dealer to see if they can look at the machine while you wait.
They may be able to get it back together or they will have to replace the threader.
It is possible they will have one in stock, or they may have to order it.
May 01, 2010 | Brother CS-8060 Computerized Sewing...
My auto thread component is not egaging the thread down to the needle.
Need more information. Is the auto thread component going down to the needle? Is
it missing the needle hole? If this is the problem, make sure that the needle position is in the correct position by pushing the needle position button. This will bring the needle to correct height for the thread to be inserted. I had a problem similar and it was because the needle was not in the correct position. When using the thread insertion press it slowly and watch to see where the insertion part is going.
Oct 29, 2009 | Brother CS-8150 Computerized Sewing...
Problem with my Babylock embroidery machine
I think you may have forgotten to put on the Q presser foot.
Feb 16, 2009 | Baby Lock Esante
Show me how to use the auto threader
Thread the machine to the point where the thread is in the needle bar thread guide. With you left hand hold the upper thread towards you. With your right hand pull down on the threader unit and twist it so the tiny hook goes through the eye of the needle and hold it there. Now take the thread that you are holding in your left hand and pass it to the rear of the machine under the small guides on the threader hook. Release the threader mechanism and the thread and the tiny hook should pull a small loop through the eye. Pull on this small loop (which will be on the right side) all the way through the eye.
Viola!
good luck!
Jan 31, 2009 | Juki TL-98Q
Unable to thread lower looper on Babylock Eclipse BLE1SX
On rare occasions lint can clog the yubes on these sergers. One of the first things I do is thread the wire through in the opposite direction. It will sometimes push the blockage out. The other option is to use an air compressor and again blow the lint out from the opposite side. If this does not work take it to a service man.
Dec 18, 2007 | Baby Lock Eclipse Serger
Sewing Machines Logo
396 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
